new live map app
Old Jan 10, 2011 | 07:35 PM
  #271
nitai3g's Avatar
Originally Posted by fjo_newport
Just an FYI you need to change a few parameters in the altmap vectors to get live mapping to work (at least for 96532706). Fortunately there is a XML def for it and it is labeled well. I've attached a pic to illustrate what I am talking about.
This table just points to what maps you are using, so I have my alt-maps set to RAM were the livemap program can make changes. If left stock as when the hex file was downloaded they point to ROM so any changes made don't actually effect the car.
EDIT: These changes need to be made in ECUFLASH not livemap. so this is a general FYI as it was not obvious when it was not working for me.
ok cool now i know why none of my changes were taking place.
Old Jan 11, 2011 | 09:33 AM
  #272
fjo_newport's Avatar
Glad that helped you out. Maybe I'll put together a "How-to".
Old Jan 11, 2011 | 11:35 PM
  #273
ziad's Avatar
for the guys who have downloaded a new version is around the corner. i have noticed a few bugs and have fixes and some more features.
until then i have taken off the app from the server. sorry about that. but u will be happy i promise
AFR autoTune, and YAVDR (yet another VDR).
EDIT: if someone can help me do an how-to, or better make a manual that would be awesome. it means i can spend more time on development and not on documentation. i have some old notes that might help the someone.
Old Jan 11, 2011 | 11:52 PM
  #274
Raptord's Avatar
Any plans to support 88590015 v7 roms?
Old Jan 12, 2011 | 08:03 AM
  #275
nitai3g's Avatar
thats so awesome Ziad! Your the man! Cant wait to see how this one works. i used the last one to tune my car ill tweek it with the new one and see how that auto tune works. thanks again for all your hard work.
Old Jan 12, 2011 | 10:50 AM
  #276
And's Avatar
And
will we be able to specify the target AFR at particular rpm's for the software to get to?
Old Jan 12, 2011 | 11:12 AM
  #277
92LaserRs's Avatar
Anyone willing to convert my 96531706 over to 96533706? Apparently im missing something when im copying all my stuff over.
Old Jan 12, 2011 | 11:44 AM
  #278
And's Avatar
And
missing? they use the same xml def's so you should be able to go through each def and make sure they are the same
Old Jan 12, 2011 | 02:42 PM
  #279
ziad's Avatar
raptoid, currently no plans. i will have a look one day.
yes andy, currently its hardwired so if u want a different profile u need to change it everytime u start the program. i should be able to fix that, so someone can save their map for later useage.
but u can change cell by cell what afrs you want the program to target. so basically u have what looks like ur normal fuel map. with default values already put in. you can then change them to what suits u. then the autoTune trys to target the map.
Old Jan 12, 2011 | 03:01 PM
  #280
ziad's Avatar
sorry guys the app will have a slight delay.......... santa came slightly late.... but i got something cool to test on my car, and it does not have livemap on it (yet)
Old Jan 13, 2011 | 12:23 AM
  #281
And's Avatar
And
ooooooh what is it?
also is it possible to put a second Y axis on the graph on the right hand side?
Old Jan 13, 2011 | 04:49 AM
  #282
Icem@n's Avatar
Its not compatible with OP2 so i will have to wait till a newer version is released that will work with my OP2 cable. How soon do you plan to make that update so that whoever have the OP2 can give it a test for you?
Old Jan 13, 2011 | 01:10 PM
  #283
ziad's Avatar
honestly it will be quicker to put aside $5bucks every week and getting a 1.3 cable (u dont need the flashing one just the cheaper logging one would be fine tooo) then waiting on me to do OP2.
Old Jan 15, 2011 | 10:49 AM
  #284
l2r99gst's Avatar
I tried patching this ROM probably about a year ago, but no one tested it. It's probably sitting somewhere in this computer if you want to give it a go. I'm not even sure if it works, but if not, I know it's 99% there.
But, I have no time to help anymore. You have to know what you're doing and how to setup the LiveMap program to test it out. Maybe once Ziad or someone releases some documentation on the LiveMap app, you can test it out.
Old Jan 15, 2011 | 10:57 AM
  #285
Raptord's Avatar
I've never tried setting it up so I don't have any experience with it, but maybe I'll give it a shot if/when, like you said, some documentation is available.
