Speed Density 2.0 (3D VE Tables, Baro)
Old May 6, 2011 | 01:26 AM
  #346
justastockevo's Avatar
is it possible to fight the heat soaked startup? say, by reading temperature off the sensor at ignition, maybe comparing it to fuel temp and enriching the mixture for a couple of minutes if that's above a certain value?
Old May 6, 2011 | 05:04 AM
  #347
golruss's Avatar
Originally Posted by And
hehehe thats cause the one the car has 0009 but the rom I had on the memory card with me (which was the same before the patches) didn't have those patches applied and because I uploaded it in work I quickly changed them, I've now corrected it
Good!
Old May 6, 2011 | 09:07 AM
  #348
RoadSpike's Avatar
Why not just move the sensor...
Its way easier than me coding something.
Old May 6, 2011 | 10:08 AM
  #349
And's Avatar
And
well some good and bad news, I've been using the car now all week and have noticed the cough only mildly now 3 times (much better than previously) and I only seem to get it now and again but its generally when slowing down on part throttle the accelerating again and it comes on the start of the accelerating and has only happened when in second gear
Will see if I can get it on a log
Old May 6, 2011 | 10:16 AM
  #350
RoadSpike's Avatar
That sounds a lot like it needing a little tip in adjustment bud.
Old May 6, 2011 | 01:34 PM
  #351
And's Avatar
And
I'm assuming this is the Async Accel Multiplier vs TPS delta? do you know how the values on the right (Factor) make a difference do I need to increase/decrease these?
Thanks
Andy
Old May 6, 2011 | 01:47 PM
  #352
RoadSpike's Avatar
Thanks
Andy
Should be a RPM version of that too if its going a little lean that will help.
Old May 6, 2011 | 02:51 PM
  #353
3gEclipseTurbo's Avatar
does the xml in the first post have all the fixes in it? I still have the orginal with only the 3 fixes.
Old May 6, 2011 | 02:58 PM
  #354
RoadSpike's Avatar
Nope was waiting on a validated fix list before updating them.
You were running the 9417 variant right? I haven't even posted those yet.
Old May 6, 2011 | 03:01 PM
  #355
Ya, Im gonna switch to the one where the baro max was reversed and see if its still good. When I was on it it never did the jitter/stutter.
Old May 8, 2011 | 02:03 PM
  #356
211Ratsbud's Avatar
Ive been fiending for the ability to go this route for a while. I used the scalling for my omni power 4 bar that was listed in the thread for that specific install, is there a more updated scalling that I should consider before making this leap?
I dont see the xml file for 88597215?
Old May 8, 2011 | 06:40 PM
  #357
RoadSpike's Avatar
XML file is on the front page..
https://www.evolutionm.net/forums/at...d-88592715.zip
I don't know why your concerned about scaling the program doesn't care one bit about it. All it can see is volts the scaling is just a clever way for us humans to interpret the meaning of those numbers into something we understand.
Old May 9, 2011 | 10:27 PM
  #358
Acree's Avatar
Has there been any progress on getting SD to properly work with closed loop on the Evo IXs?
-Acree
Old May 9, 2011 | 11:54 PM
  #359
RoadSpike's Avatar
-Acree
Not sure what you mean really the evo 9 doesn't have any of the ipw issues the evo 8 does.
Old May 10, 2011 | 10:58 AM
  #360
Acree's Avatar
I thought there were issues on tip in and tip out of closed loop. Isn't that why it takes so long to tune SD? You have to tune the whole table and keep the car in open loop the whole time?
-Acree
