Post exact weights of weight reduction you have done!
Old Jan 10, 2012 | 04:23 PM
  #616
EvoDan2004's Avatar
Originally Posted by badev0
Post pictures of it when you are finished
Ok. I broke my cutting wheel so tomorrow when I buy a new one ill finish up what I started and post up some pics.
Old Jan 10, 2012 | 04:27 PM
  #617
StreetThisEvo's Avatar
Nevermind the bar I'm digging the yellow floors lol
Old Jan 10, 2012 | 04:31 PM
  #618
EvoDan2004's Avatar
Haha yea its awesome. I wonder what people think when they buy there flooring back in the 60s. My downstairs is being re modeled and the floor is last to go. I picked up some carpet but I'm not using it until the painting is done and this floor is ripped up.
Old Jan 11, 2012 | 09:05 AM
  #619
badev0's Avatar
I just purchased a scale now so tomorrow I will start weighing and posting #'s of stuff I have removed from the car.
Old Jan 11, 2012 | 10:34 AM
  #620
03whitegsr's Avatar
More data, good for those few out there interested in creating a kinematic model of the rear suspension.
Everything here is from the rear, one side only. As always, +/-0.2 lbs
Code:
E-Brake Assembly    	5.0	Cable, Back plate, Shoes, Hardware (one side)
Hub Carrier              	9.4	Carrier and wheel speed sensor
Upper Control Arm    	4.4	Ball joint nut, no other hardware
Toe Control Arm        	2.4	Ball joint nut, no other hardware
Hub Bearing Assembly	7.4
Axle                  	13.4	axle nut included
Trailing Arm       	4.0	Ball joint nut, no other hardware
Lower Control Arm        	3.6	No hardware
Old Jan 11, 2012 | 01:42 PM
  #621
EvoDan2004's Avatar
i need help from someone who has a dash in the car. or at least know's what i am asking for.
i can not remember or figure out what these arms hold up or bolt too. i circled what i am asking one of you guys to go to your car and look at. you will need to remove the lower plastic cover ''where your knee's are when your sitting in the car''
i modified mine and im thinking i can just remove them. but i do not remember if there is a need for them.
Old Jan 12, 2012 | 10:35 AM
  #622
EvoDan2004's Avatar
Bump for above response
Old Jan 12, 2012 | 10:48 AM
  #623
B.J.@ToxicFab's Avatar
If no one else gives you an answer by tonight, I'll check it out after I get home from work.
Old Jan 12, 2012 | 10:52 AM
  #624
EvoDan2004's Avatar
thanks. all you have to do is remove that lower panel. im pretty sure there not being used. i think they where for other brackets that normally get removed.
Old Jan 12, 2012 | 11:07 AM
  #625
Those square brackets that run around the steering column? Looks like it...
Old Jan 12, 2012 | 11:11 AM
  #626
EvoDan2004's Avatar
yea. they do not bolt to the column and when i test fit everything back in the car there seems to be nothing that is bolted to these things. im sure there was at some point but i figured it was stupid and removed it doring my weigh reduction stange 1. or was it stage 2 or 3. hum.
also while i am here. does anyone know if the evo with AC AND THE EVO rs WITHOUT A/C have the same heater cores? i wonder if the RS heater core is lighter then the evo's who had A/C
Old Jan 12, 2012 | 11:20 AM
  #627
David Buschur's Avatar
Delete the pieces you have circled.
I removed some misc crap under the hood of the RS I won't ever use again today. The strut tower bracket, A/C line bracket, Air bag brackets and clutch line bracket..........now I have to sad it and paint it where I took the spot welds out, it's way more work than I wanted to do for .9 pounds..............but it is 410 grams and that's a lot! hahahahah
BTW, that is what happens when you drink beer with Curt Brown!
Old Jan 12, 2012 | 11:25 AM
  #628
EvoDan2004's Avatar
david. thanks. so far i got the bar 3.8lbs lighter. now ill go delete these brackets and trim up a few spots. ill post some finished pics when im done. i also have a few other things i want to do to the bar. my goal is 8lbs.
as for those bits you just removed i am sure that cleaned it up beautifully too.
david did you pull your RS heater core? do you know if the evo's with ac and rs without a/c used the same core's or is the RS lighter. if you removed yours do you want to sell it?
Old Jan 12, 2012 | 11:38 AM
  #629
They have to be the same, all US RS's came with A/C. Are you able to pull the A/C and still have the heater work? If not then I imported the JDM non-A/C stuff for my car so I could keep the heater and delete the A/C like it was suppose to be in the first place. If that's the case I can sell you the same parts I used.
Old Jan 12, 2012 | 11:51 AM
  #630
EvoDan2004's Avatar
i removed the a/c all the way up to the fire wall. after that i do not know what is left. is there a kit on your site i need i can buy?
i removed those brackets. it now weigh's 15.2lbs. my stock bar weighed 20.8lbs. 5.6lbs off the bar. and i still have some extra idea's. i need 2.4 more lbs.
