Post exact weights of weight reduction you have done!
Old Apr 30, 2012 | 08:39 PM
  #1246
EvoDan2004's Avatar
Originally Posted by StreetThisEvo
Ding ding ding
You are correct it is off the gas pedal. Two 14 mm nuts and slide the throttle cable off and out it goes. I simply took a air grinder and cut it off and re-installed the pedal. Feels just like it did before.
really. WTF do we need that for?
Old Apr 30, 2012 | 08:41 PM
  #1247
StreetThisEvo's Avatar
No idea the pedal is already spring loaded and when the cable is hooked up it feels just like it did before.
Get it out of there
Old Apr 30, 2012 | 09:06 PM
  #1248
EvoDan2004's Avatar
anyone know the weight of the stock fuel tank?
Old May 1, 2012 | 05:06 AM
  #1249
B.J.@ToxicFab's Avatar
Check out post # 531...it's around 40lbs without fuel pump assembly.
Old May 1, 2012 | 07:51 AM
  #1250
I'd love to take the stock tank and cut it in half to make a half tank. Plus have a -6 an bung welded to it for the return line. It would still hold 7 gallons or so I'd think.
Old May 1, 2012 | 08:02 AM
  #1251
badev0's Avatar
Or you could contact Andrew @ http://www.frontlinefabrication.com and have him make you a bolt in stock location aluminum fuel cell that has the stock sending unit flange
Old May 1, 2012 | 08:44 AM
  #1252
EvoDan2004's Avatar
i drive my car on the streets so my thought was to do the AEROMOTIVE 15 gall fuel cell with built in A1000 fuel pump. its lighter then stock yet is 15 gallon rather then 14. kinda a bonus for me.
cutting the stock tank would be nice but it wont hold enough fuel for me.
Old May 1, 2012 | 08:51 AM
  #1253
EvoDan2004's Avatar
40lbs. damn thats heavier then i though.
Old May 1, 2012 | 03:13 PM
  #1254
03whitegsr's Avatar
Realize the stock tank holds more fuel then you can use because of the saddle design.
Yeah, the "transfer nozzle" is there for when you are on flat ground but any corner load or acceleration will quickly put fuel back on the useless side and end up starving the pump. I never ran my stock tank lower then 1/4 tank, which was about 10 gallons out of it.
I think the actual tank holds closer to 17 gallons, even dropping to a 10 gallon tank you would still have roughly the same useable fuel load, but would cut about 40 pounds off the car compared to a full stock tank. The benefit though, you don't have to worry about starving the fuel pump when you run low on fuel.
I picked up a 5 gallon ATL vertical cell that weighs like 8 pounds. It is setup so I could swap it out in the future for a 12-15 gallon "well cell" with internal pump feeding an external surge tank for road racing.
Old May 1, 2012 | 04:51 PM
  #1255
EvoDan2004's Avatar
The aeromotive fuel cell I was looking at has a built in fuel pump and baffling system as well. I'm guessing i will not need a surge tank either right.
Anyone know how reliable the A1000 fuel pump is.
Only down side I can see to this is not being able to use the stock fuel gauge to indicate fuel level.
Old May 3, 2012 | 05:58 AM
  #1256
antilag_200's Avatar
Time for me to contribute to this thread
Removed rear ashtray and cup holders
replaced it with 0.5mm carbon fiber plate
Old May 3, 2012 | 07:28 PM
  #1257
^^^Awesome!!And you took my idea! haha...I already removed my ashtray but I am keeping the cup holders for now. Quick question, where did you get the .5mm carbon fiber sheet from? I looked on ebay for a bit but didn't find anything I liked...Let me know, thanks!
Old May 4, 2012 | 11:19 AM
  #1258
korizmo's Avatar
Just got my car weighed today with 1/2 tank of gas. 2003 Evo RS
Small battery, front crash beam removed, intercooler sprayer removed, egr removed, window washer system removed, Lighter exhaust, oil cooler delete
3100lbs exactly
3268 with me in it..
Now I need to figure out how to shave 100lbs to reach my goal weight.
Old May 4, 2012 | 11:24 AM
  #1259
^^^Read through the 84 pages of this thread...lots of ideas! haha...
Old May 4, 2012 | 11:31 AM
  #1260
korizmo's Avatar
One item is gonna be getting rid of is my massive megan radiator that holds 2.5 gallons of fluid. Getting a half rad with slim fan should shave a nice number off.
