Post exact weights of weight reduction you have done!
Old Oct 11, 2012 | 07:51 AM
  #1471
EGbeater's Avatar
Originally Posted by B.J.@ToxicFab
^^^Nice! Didn't know you gutted both, actually I probably read it before but forgot. After you painted the inside of the gutted hood & trunk black, it looks good! Much better that way than if you didn't paint it, kinda looks like they are supposed to be like that.
So how long have you been running the car with both of them gutted? Exterior wise, have the hood or trunk start to sag at all?
Thanks; the hood has been gutted since 12/09; the trunk since summer 2011. Neither has sagged, or started to look weird, and I don't expect them to.
I know you have posted it before, but what does your car weigh now?
I've actually added back a lot of weight recently... aero stuff (DIY front splitter, much taller custom risers for my APR GTC-300 wing, including reinforcements to the inside of the trunklid where the wing mounts, and 1/8" stainless steel guy wires/turnbuckles to eliminate lateral flex) and I've added a 60952 Autopower bolt-in roll bar, which is 61.4 pounds. I realize the bolt-in roll bar is not very good for actual rollover protection due to the possibility of the feet punching through the sheetmetal floor of the car, but it does also provide an excellent mounting point for the shoulder belts of my six-point harness.
So my car's certainly not very light anymore... over 2900 lbs. Even before, it wasn't all that light, because abiding by the ruleset for SCCA SM class restricts you from doing most of the "easy" weight removal, such as gutting the entire interior. For SM, basically all you can do to lighten the interior is remove the rear seats/seat belts and the audio equipment, and replace the front seats with lighter ones.
Old Oct 11, 2012 | 12:17 PM
  #1472
Boosted Tuning's Avatar
Thanks for that very informative post, EG.
Old Oct 11, 2012 | 02:22 PM
  #1473
EGbeater's Avatar
Always glad when my obsessive-compulsive nature is viewed as "informative" by others.
Old Oct 11, 2012 | 11:23 PM
  #1474
dtrackstar's Avatar
What's your guys thoughts on removing stock exhaust manifold heat shield. Obviously it'll shed some weight but what about performance wise
Old Oct 12, 2012 | 08:47 AM
  #1475
03whitegsr's Avatar
Took some weights from door items:
Front Window - 6lb 4oz
Front Window Motor - 2lb 13oz
Front Door Panel - 5lb 0 oz (everything that can be unscrewed was removed)
Side View Mirror - 2lb 8oz
Front Door Hardware - 4lb 1oz (everything else in the door except the window trim items, including speaker)
Rear Window - 5lb 5oz
Rear 1/4 Window - 1lb 4oz (includes seal)
Rear Window Motor - 2lb 13oz
Rear Door Panel - 3lb 7 oz (everything that can be unscrewed was removed)
Rear Door Hardware - 1lb 14oz (everything else in the door except the window trim items)
Total is 70lb 10oz removed.
With lexan and flat carbon door panels, I'm thinking right around 50 pounds lighter.
Old Oct 12, 2012 | 01:59 PM
  #1476
Wheatley's Avatar
Front Door Hardware - 4lb 1oz (everything else in the door exect the window trim items, including speaker)
Rear Door Hardware - 1lb 14oz (everything else in the door exect the window trim items)
Thank you, Ive been wondering exact weights for a few months now. Did you by chance weigh an empty stock door shell?
Old Oct 12, 2012 | 04:32 PM
  #1477
johnnnyjeans's Avatar
hey guys, after removal of sound deadening materials, you guys get more road noise?
I would like a light weight & quieter evo, is that even doable?
Old Oct 13, 2012 | 12:44 AM
  #1478
griceiv's Avatar
Old Oct 13, 2012 | 11:18 AM
  #1479
Originally Posted by griceiv
haha i know right. what was i thinking. its an evo.
Old Oct 13, 2012 | 02:18 PM
  #1480
StreetThisEvo's Avatar
I still want to know the weight of the door crash beams. Anyone??
Old Oct 13, 2012 | 06:59 PM
  #1481
AreSTG's Avatar
i just removed all that **** recently. Haven't driven with the rear seats back in yet. With the back seats removed, the sound is the same to me with/without the sound deadening. I have a crazy loud exhaust, that is mostly what I can hear, and the rocks/sand pelting the rear fender area from sticky tires.
Only noticeable change, (keep in mind my loud exhaust), is that I now can hear a whine coming from the t-case or something up front, maybe trans. No deathwhine, just whatever used to be blocked by the firewall I think.
The Evo is stupid loud from the factory. I think the sound deadening is just about pointless as it's loud even with it.
Old Oct 13, 2012 | 10:16 PM
  #1482
thanks. just exactly what i needed to hear. the evo is crazy loud from the factory. so sound deadening or not. doens't make any difference. unless you do the whole freaking car.
Old Oct 16, 2012 | 09:34 PM
  #1483
Boostedx11's Avatar
For those of you that have removed the srs system, I am pulling all of the wires from the module to each of the sensor shortly. Also note some have said removing the srs module removes the srs dash light... not true
Old Oct 16, 2012 | 10:14 PM
  #1484
Just pull the bulb out from the dash. Thats what I did.
Old Oct 17, 2012 | 12:01 AM
  #1485
Originally Posted by streetthisevo
just pull the bulb out from the dash. Thats what i did.
+1
