Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
Old Sep 25, 2007 | 01:20 PM
  #226
johnguam's Avatar
cool, good to know. but does MIVEC make a difference, like i stated earlier? I hear the 9 is different from the 8 and MIVEC does help with any kind of low end torque loss.
Old Sep 25, 2007 | 01:47 PM
  #227
mrfred's Avatar
Stock MIVEC settings are not optimized. A good tune with optimized MIVEC settings definitely improves low end torque.
Old Sep 25, 2007 | 02:44 PM
  #228
fimotorsports's Avatar
with MIVEC tuning, sure you can adjust the spool up and it will affect the low end torque. But as far as changing 2.75 to 3" with no mivec tuning, there should be no torque loss from what I have seen.
Old Sep 25, 2007 | 04:10 PM
  #229
johnguam's Avatar
Here's a response I got from a WORKS guy:
Yes, the 76mm DP will reduce low-end torque but the change is so small (4 to 6lb ft.) that you will most likely not feel the difference. The MIVEC does reduce this somewhat, but we have seen the reduction on the dyno. The Throttle Body does not help in low end torque and provides higher end power. The change occurs after 4K rpm. The Throttle Body improves throttle response, so it does lower the torque peak by 50 to 75rpm, but it doesn't change the torque average.
Old Sep 25, 2007 | 04:33 PM
  #230
CEB Unit's Avatar
Well just in case anyone is interested I have an AMS 3in downpipe brand new never used for sale. 225.00 + shpping
Old Sep 25, 2007 | 04:47 PM
  #231
tookinkee's Avatar
I have the full tanabe concept G blue exhaust....downpipe and all...BEST fitment ever....also the downpipes with the flew in them are due to improper fitment. The tanabe fits up to your stock components or the full exhaust. Im happy with the quality and fitment. NO ISSUES....also JDM quality....
Old Sep 25, 2007 | 09:58 PM
  #232
johnguam's Avatar
i've also been hearing that the 3" downpipe really pays off when you get the cams upgrade. also, the cams do bring back any low-end torque, if low-end torque was an issue...
Old Sep 25, 2007 | 11:07 PM
  #233
CarbonKrazyEvo9's Avatar
I have the Megan 3" DP. Perfect fitment on my Evo9 and it did not hurt my pocket.
Old Sep 26, 2007 | 08:34 AM
  #234
Mr. Evo IX's Avatar
+1 great fitting/looking/performing exhaust. Fit's MR with ACD perfect as well.
Also, TTP's 3" DP fit the IX as well although I think the flex section was kind of close if I recall.
I will never purchase another HKS exhaust part. Their expensive catback rubs the driveshaft on a IX and people still continue to recommend their junk. HKS exhaust sucks, has taper, small DP, rubs exhaust.
These are the only 3 that I have first hand experience with.
Old Sep 26, 2007 | 08:52 AM
  #235
TTP Engineering's Avatar
We have about 7 units left in stock.
Old Sep 26, 2007 | 09:23 AM
  #236
SPANKED's Avatar
Tanabe DP fits beautifully but it's only 2.75" and with all this debate over 2.75" vs. 3" I'm questioning whether I should sell it and go to a 3"....
Old Jan 7, 2008 | 11:27 PM
  #237
heSOshAdy's Avatar
I have the Tanabe DP as well and I need to figure out if I should get a 3" DP.
I have upgraded cams and the e-bay O2" housing and do not want to sacrifice my low end torque unless the peak gains are significant!
Old Feb 16, 2008 | 10:57 PM
  #238
hytek369's Avatar
i wished the works dp was cheaper.
anyone know if the buschur dp works with stock cat or aftermarket HFC like perrin or cobb?
Old Feb 17, 2008 | 06:16 AM
  #239
David Buschur's Avatar
Yes, our downpipe works with any 3" aftermarket cat that I have seen to date. If you are sticking with the stock cat though you will want to order our 2.5" downpipe, running a 3" downpipe up to the stock cat is not a good idea.
Old Feb 17, 2008 | 07:46 AM
  #240
Zeus's Avatar
Kinda like running a stock cat at all
If you HAVE to have a cat, there are nice 3" 100 cell metal substrate units to be found.
(NOT from me BTW)
