Whats new with the new 20g
Old Oct 15, 2006 | 02:24 PM
  #136
Zeus's Avatar
Old Oct 15, 2006 | 03:15 PM
  #137
CO_VR4's Avatar
Originally Posted by CBRE
I will put my car with this new turbo up against any car with a 50 trim set up for $1000.
I'd put a showroom stock Evo with you driving up against a 50 trim...
Old Oct 15, 2006 | 04:58 PM
  #138
Erik@MIL.SPEC's Avatar
How about your car with this turbo versus your car with a BB 50 trim
Old Oct 15, 2006 | 05:00 PM
  #139
MR. Birdie's Avatar
I wonder how much power will be added to a evo ix with the current 20g-9-5. With all the bolts on and flash on pump gas.
Old Oct 15, 2006 | 10:23 PM
  #140
rotgg's Avatar
i too want to see what he says about that
Old Oct 15, 2006 | 10:32 PM
  #141
sylvester31's Avatar
i'd do that if i could have you drive both cars at the same time .
Old Oct 16, 2006 | 03:03 AM
  #142
CBRE's Avatar
Alright you got me, I don't know what to say! I know FP's Green turbo worked well, my FWD with just a VPC it ran 135mph on it but was much lighter than my EVO. For an easy bolt on with great drivability im still for the new turbo.
Old Oct 16, 2006 | 06:23 AM
  #143
David Buschur's Avatar
Alright, let's just get the entire story out there right now as it is going to be out there before it is over with anyway. What I should have done was kept my mouth shut about this to begin with and just set records and ran fast at the shootout like I did. Problem with doing that was everyone knew I had our "20G" on my car then and I didn't want to mislead people into thinking 10.8 at 128 mph was possible on our standard 20g, so I leaked this information out and it has now blown up into this.
Here is a description of the DSM GREEN turbo from FP's site:
"The Receipe
The Green turbo is a Mitsubishi/Garrett hybrid, with a compressor flow of 730cfm, and around 500hp. The turbine wheel is the larger TD06H rather than the TD06. Testing showed no increase in response using the TD06 in place of the TD06H and the smaller TW only reduced overall turbine flow. We pioneered the Mitsu/Garrett hybrid design to make use of the bolt on convenience of the Mitsubishi housings, and the super efficiency of the Garrett compressor wheel. We modified the Mitsubishi bearing housing to include our exclusive Monster thrust bearing which isn't going to be found in cheap immitations. The Green utilizes a modified TD06 compressor housing with a 3 inch inlet. The outlet faces down, and thus the Green bolts up just like a standard 20G turbo. Cast aluminum 90 degree compressor outlet elbows are available to give the Green a stock 2G fitment.
Looks good on paper, how's it work?
The Green has proven its effectiveness on numerous 1G and 2G DSM applications. Curt Brown's 1G AWD race car ran a 10.7 @ 130mph with no nitrous. Loren Jacobs' full weight 2G AWD street car ran 11.5 @ 125mph, also without nitrous. The bottom line is, this turbo hauls ***. With anything this sucessful you will see inferior copies offered by "dormroomracing.com" type wannabe shops. Don't get taken by a parts slinger who is going to "order your turbo in", we build our turbos in house and have the reputation you can count on for reliability and customer service.
You want fries with that?
The Green is available in both internal and external wastegate configurations. For externally gated applications, we highly recommend Tial wastegates. Your Green can be further customized with 7cm2 or 8cm2 turbine housings, and polished compressor housings."
So that is the description of the Green turbo. It doesn't say it is a 50 trim wheel, maybe it is, I have never run one so I don't know.
Robert told me he wants to call the new turbo he has developed for the EVO the "EVO GREEN" model. Is the turbo the same as the one described above? No. Is the compressor wheel the same as the one used in this DSM Green? No.
The compressor wheel in the turbo I have and Curt has is the wheel I have named our 20G, which is the same as the white rabbit wheel.
In the end regardless of what the internals are in this turbo is the name going to be the FP Green, probably. Is it the same as the DSM GREEN turbo, absolutely NOT.
It would be like building a custom car out of your garage and calling it a Corvette, you can name it whatever the hell you want but it isn't going to be an actual Corvette.
So the 50 trim crap is absolutely 100% incorrect IF infact that is what is in a DSM green turbo. This turbo uses the same "20G" compressor wheel with a larger turbine wheel.
Now stop your damn argueing.
Old Oct 16, 2006 | 06:33 AM
  #144
lexat20's Avatar
So when are they available?
Old Oct 16, 2006 | 06:53 AM
  #145
Jim_Patterson's Avatar
read the thread, dave already said.
Old Oct 16, 2006 | 07:47 AM
  #146
EvoBig16G's Avatar
Is the "Evo Green" going to be the same turbo as the "20G-9-5-LT"? Or are there actually 2 different bolt on turbos coming out? Are they all being built by FP Performance?
Old Oct 16, 2006 | 07:49 AM
  #147
deadbeatrec's Avatar
i love people going back and forth asking these asinine questions. when it comes out, im sure David will put pics and post all the specs on it here first. u guys need to stop the bickering because he isn’t going to let all the details out just yet. only time will tell so just be patient. thanks and good night.
Old Oct 16, 2006 | 07:53 AM
  #148
Soon2BEVO's Avatar
Thanks for finally clearing up this little debate here.
ATRAX, hate to say it but you were wronggggggg JK! Although you were correct in assuming such a thing since its kind of misleading from an informational standpoint calling the new turbo an EVO GREEN. Anyway, glad things are cleared up!
Old Oct 16, 2006 | 09:36 AM
  #149
justchil's Avatar
Thank you David. We can only hope everyone learns to read
Old Oct 16, 2006 | 03:50 PM
  #150
Deepseadiver's Avatar
Good info David! When is the next update? 1 week? 2 weeks?
