Buschur Racing 50 trim turbo kit......
Old Nov 26, 2006 | 08:17 AM
  #121
David Buschur's Avatar
Yes, you can unbolt your current complete stock turbo kit and put this one back in, it will come complete and bolt right in place of stock.
This turbo should easily make more power than the LT and more on pump gas as the turbine wheel is quite a bit larger.
Old Nov 26, 2006 | 08:19 AM
  #122
smokedmustang's Avatar
Originally Posted by davidbuschur
Up to the bottom of page 6.
I have no idea how this is going to perform compared to the 35r. It will spool faster, that's all I can say for now. With the lbs/min it flows it should make some serious power.
Should have dyno graphs and pictures of the kit 1st week of December.
The non water cooled subject. Too many people read crap on the internet and swear to it. They read the hype from the latest expert and go with that too. Fact is one of the best performance cars of all time the Buick Grand National was turbocharged, non water cooled and those turbos go over 100,000 miles all the time. Fact is many of the installs we do even on ballbearing turbos, that are suppose to have water lines, we don't hook them up. We bypass them for the little bit of weight (talking little here) but mostly the ease of working on the car/turbo in the future. The water cooling, in my opinion, is slightly over rated.
Thanks David for the clarification. This info from you is good enough for me!
  #123
Stock EVO turbo IS WATER COOLED.
The 50 trim on any 4g63 will perform close to the same.
Old Nov 26, 2006 | 08:26 AM
  #124
MalibuJack's Avatar
Will you make just the turbo/O2 housing available to bolt up to an existing setup? I swap turbos based on my driving needs every so often.
How about a quick disconnect kit so I can do the swaps faster??
Old Nov 26, 2006 | 08:28 AM
  #125
Paul Nelson's Avatar
The turbo on a Cummings diesel is just oiled cooled and runs 500,000 miles.
Ive put almost 200,000 miles on my Cummings dodge ram with no problems with the turbo
http://www.holsetaftermarket.com/aft...er%20works.php
Here is a write up on how a non ball bearing turbo works for anyone who is worried about cooking the oil or from road racing. Ive got alot of friends around that run non ball bearing turbos and never have had any problems.
Old Nov 26, 2006 | 08:31 AM
  #126
MalibuJack's Avatar
fwiw I don't always hook up the coolant lines, its just messy to do the swap when their connected.. I have them connected now that my 35r is on the car for a much longer duration, but it was a pain when I was testing different turbos..
Old Nov 26, 2006 | 08:39 AM
  #127
whitey4d's Avatar
Originally Posted by CaymanEvo3
WOW! Can someone frickin put a Price for the Kit so we can know and hurry up with the results david or else this thread is goin to be from usa to China!!!
According to ur info u have a EVO 3 the EVO 3 has a different engine set up then the EVO 4-8 4G63. The EVO1-3 4G63 is very much the same as the DSM engine.
Old Nov 26, 2006 | 08:42 AM
  #128
whitey4d's Avatar
Originally Posted by RSGuy
the stock turbo is not water-cooled...
wrong. it is.
Old Nov 26, 2006 | 08:49 AM
  #129
boostingevo8's Avatar
Damn 2k....for a 50 trim kit! I know where my tax refund will be spent this year!
Old Nov 26, 2006 | 09:05 AM
  #130
Turd Squirter's Avatar
I'm getting giddy. This should really be something to follow in the way of turbo upgrades. Thanks DB for the info and the gyno post. I'm still wondering if the guy you replied to gets it.
Old Nov 26, 2006 | 09:35 AM
  #131
SIGSP2340's Avatar
Dang..... and priced below $2k.......
Old Nov 26, 2006 | 10:41 AM
  #132
Agent-Smith's Avatar
Yeah I hope this turbo turns out. Definitly looking to be right up my alley.
  #133
shift_fast's Avatar
so when is this kit going to be ready for release?
Old Nov 26, 2006 | 11:06 AM
  #134
l2r99gst's Avatar
You have to take into account that diesel engines have much lower exhaust temperatures that gasoline engines, so water cooling will not be needed. You can't really compare diesel turbo applications to gasoline turbo applications in that respect.
Water cooling may not be needed for a turbo in our cars, but it's just a little extra added insurance. It really just comes down to preference and how long you will be using that turbo or how often you will be changing out turbos.
There are advantages and disadvantages either way. It's up to the particular person and his/her setup that will dictate the right or wrong answer.
Eric
Old Nov 26, 2006 | 11:25 AM
  #135
I might have to bolt this puppy on my car, and see what she does!
