Buschur Racing 50 trim turbo kit......
Old Dec 1, 2006 | 07:52 AM
  #181
NIevo's Avatar
Originally Posted by davidbuschur
The topic is about a 50 trim kit that is under $2,000 (hopefully). It does not use any stock parts, as was said by someone else. It uses our cast/coated manifold, a non ballbearing 50 trim turbo, SS 02 housing, oil feed and return lines are supplied. It is not water cooled. It is internally wastegated.
Sorry Dave, that was my bad. That makes the value of it even better, if it works. Your making my decision on a new turbo harder be the day.
Old Dec 1, 2006 | 08:23 AM
  #182
Spooldyou's Avatar
I think the 50 trim is a Great option. Great for a daily Driver, tons of power. tons of response, Great Torque. Very well suited, Instant Boost, ( compared to larger 30 series) 500whp Capable. You wont be disapointed. Dave makes a Great product. I have tons of his stuff on my car !
I chose this turbo but i went to the dark Side and bought a 35r!
Old Dec 1, 2006 | 09:12 AM
  #183
DSMu4ia's Avatar
Very interested to see a decent shop doing some Borg Warner ETT testing.
Old Dec 1, 2006 | 10:15 AM
  #184
deadbeatrec's Avatar
sounds good but i think i still want the FP3065, its the middle of the line up. bigger then a 50trim, smaller than a 35R.
Old Dec 1, 2006 | 12:38 PM
  #185
AFI Turbo's Avatar
A few have ....The results weren't as stellar as borg warners claims...That s200 vs. t67 is completely apples to oranges... really there is NO info to be gained from that test. How can you compare one turbo @ 25psi and the other @ 32psi, and there is NO way the t67 is maxed at 25psi lol
Old Dec 1, 2006 | 06:25 PM
  #186
Frenchy4g63's Avatar
how about instead of everyone speculating and guessing at what parts are going to be used and what the numbers will be, just listen to Dave and wait until he comes forth with the results. If the numbers aren't as impressive as everyones been guessing then people think Dave is at fault, which he is most definatly not. Just be patient and I'm sure we'll have some numbers very soon. I have the feeling that a lot of people are getting some bad information, just give it some time.
Old Dec 1, 2006 | 07:15 PM
  #187
go_evo_go's Avatar
The way things get mixed up and turned around..................wow.
I have no idea what either of these 50 trims are going to make for power, work on the street, 1/4 mile or road course.
I have no idea which turbo is going to outspool the other.
This is why WE do testing here, we get bashed for it half the time and called liars but the haters in the group but WE do the testing.
Two kits are being talked about.
The other kit I just mentioned is going to be just like our normal $2995 GT30/35R kit we offer now except it will be a 50 trim and I am going to try and use a 38 mm wastegate on it to further drop the price.
Thank you for the clarification David. Cant wait for the results.
Old Dec 2, 2006 | 12:49 AM
  #188
HPF Kyle's Avatar
dave...i think i heard from the "shodan" that the borg warner turbo's operate much more efficiently at higher pressure ratio's than garrett's do. Have you heard/experienced anything along those lines?
Old Dec 2, 2006 | 01:38 AM
  #189
94AWDcoupe's Avatar
They werent trying to show you that the s200 was better performer than a t67. They were simply showing what the turbo was capable of on a well setup car. If ones goal was 550whp then one could use this comparrison as valuable info and choose a s200 rather than the laggy t67.
Old Dec 2, 2006 | 06:47 AM
  #190
evolvedmb's Avatar
Are all of these numbers coming from a Mustang dyno or dynojet?
This would be a nice upgrade for me from the WR turbo, as I already have an alky kit on top of this potential turbo.
Old Dec 2, 2006 | 08:56 AM
  #191
AFI Turbo's Avatar
lets see a s200 vs. gt3076r instead then
Old Dec 2, 2006 | 10:58 AM
  #192
RenoEvo's Avatar
+1000
Old Dec 3, 2006 | 06:06 AM
  #193
barflea101's Avatar
bump for progress?
Old Dec 4, 2006 | 08:53 PM
  #194
SWOLN's Avatar
Can anyone tell me if the wheels (ind and exd) are different between the non-BB, and the BB ? I mean, I realize its a 50 Trim, but you would think that one could expect a quicker spool out of the BB just with that information. The idea being "less oil used on a BB 50 trim would cause for less drag, or windage if you will, creating a faster spool." The other thing that could create the faster spool is that the compressor impellers are made of titanium, if in fact the 50 trim is actually the s200.
Old Dec 5, 2006 | 12:41 AM
  #195
RoadSpike's Avatar
Trim is an area ratio used to describe both turbine and compressor wheels. Trim is calculated using the inducer and exducer diameters. As trim is increased, the wheel can support more air/gas flow.
The BB and non-BB are describing if the turbo uses ball bearings or a sleeve. The ball bearing turbo's spin slightly faster and cost more than their non-BB conterparts.
