fpevo green dyno numbers
Old Feb 20, 2007 | 07:09 PM
  #361
blockhed79's Avatar
so you'd def make over 400..
Old Feb 20, 2007 | 07:10 PM
  #362
Nitrotiger's Avatar
Yep im using the car for road racing so i am going to work on the suspension now but the green is calling me!!
Old Feb 20, 2007 | 07:33 PM
  #363
joedr's Avatar
EvoM Moderator
We will see how the green turns my car!
I am getting the rest of the supporting parts for the turbo upgrade.... Inj, cam(s),LICP, ported mani, O2 housing.
Hopefully, I will be able to reach or exceed my goal of 400 WHP and 120-125 MPH trap speed in 1/4 mile.
Can anyone post the thread of the evogreen in a IX?
Old Feb 21, 2007 | 01:33 PM
  #364
GGBaller's Avatar
I am starting to like this Green.
Old Feb 22, 2007 | 10:08 PM
  #365
blockhed79's Avatar
joedr you'll def be able to hit 400 or more it all depends on the parts you choose and the tune.
Old Feb 22, 2007 | 10:11 PM
  #366
HOSrt4's Avatar
Originally Posted by Nitrotiger
i have 390 right now with a reflash
What are you mods?
Old Feb 23, 2007 | 01:02 PM
  #367
GrocMax's Avatar
Originally Posted by johnjonfenomeno
Sorry to break the news .. but my car was redynoed...the issue i was havving with my car was due to using a 3.5 BAR map sensor... This was causing major issues once my sensor was maxed out what it did was shut down my alky trigger switch..(My alky kept spraying but my fuel and ignition map was being reverted back to my pump fuel and ign) thus causing a rich condition on those high rpms and thus the major backfiring... I upgraded to a 5.0 bar map sensor and had the car retuned... 446 whp 426 tq.. I will post the new graph soon and anyone who wants to see the log with the 3.5 bar i will post that too.. Unortunately another problem they saw was upon spool up my turbo cartidge seems to have gone off balance.. You hear a grinding sound.. almost like metal on metal.. So my turbo will have to be replaced.. Good thing this is under warranty..
50trim vs Green II " It aint over till its over" coming soon to a YOU TUBE near you
So you were running 35+ PSI boost pressure vs. his 20 something?
Old Feb 23, 2007 | 01:20 PM
  #368
Willie Dynamite's Avatar
No, where are you getting that from?
Old Feb 23, 2007 | 02:18 PM
  #369
EVOpacoIX's Avatar
I think I have made up my mind and go with the FP green along with gsc s1 cams. Hopefully I will put down 400 or more whp. An IC upgrade will be needed by then right?
Old Feb 23, 2007 | 02:33 PM
  #370
johnjonfenomeno's Avatar
He prally calculated that I was maxing out my 3.5 bar sensor..
Yes I was spiking pretty high and this caused the maps to switch and toggle in and out and that cost me plenty of power.
Old Feb 23, 2007 | 04:45 PM
  #371
thatguy's Avatar
It would be a good idea.
Old Feb 23, 2007 | 05:57 PM
  #372
joedr's Avatar
EvoM Moderator
blockhed79,
That is my target... 400WHP with near to stock spool. That should be enough to get me into the low 11s I think.
My current trap speed is around 109-110 most of the time. I think that is good for low 12s which is what I ran a couple of months ago.
I just ordered the LICP and the IC. I will be ordering the ported/coated mani and coated fabricated O2 from PPi. Missing the injectors! PM me if you have 780cc or higher at a good price!
Not sure If I will get the cams to go along with it! Any suggestions on parts based on your experience with the green to get to my goal? Mine is a IX... so not sure what else to get.
Old Feb 23, 2007 | 06:03 PM
  #373
DS-03evo's Avatar
Will the 20glt be capable of a 120 trap on 93oct?
Old Feb 23, 2007 | 06:09 PM
  #374
joedr's Avatar
EvoM Moderator
With the flow rating at 47-49... i would think that it should! Maybe with the use of some cam(s) for the needed top end.
Can anybody confirm this? I am also interested on this!
Old Feb 24, 2007 | 03:17 AM
  #375
kjewer1's Avatar
120 will be tough. I'm personally expecting something in the ~118 range, for whatever that's worth. It would certainly be a fun goal to shoot for!
