IX Engine idle noise (belt?) (video)
Hm, just letting you guys know, my Evo 8 is making the sound after 100,000 km service:
http://www.youtube.com/watch?v=YwrV23Eou6Q
For what it's worth......I used to have the idle metal scraping noise relentlessly, but I have not heard it ever since switching to GSC S2's with beehive springs about 1500 miles ago, which included raising my warm idle to 950 rpm. Weird huh?!
The noise gets SIGNIFICANTLY worse when I have the brakes on and ride the clutch a little, as that makes the RPM fall.
The noise gets lesser and lesser as it reaches 1K rpm. So when I first startup my car (cold), no scraping noise... but once the car warms up and the idle falls below 1K, thats when the noise starts.
Here's what my research has come up with.
Crankshaft Angle Sensing Blade
Part# 1840A006
Crankshaft Camshaft Drive Sprocket
Part# MD326852
Crankshaft Pulley Washer
Part# MD377400
Crankshaft Pulley Center Bolt
Part# 1101A022
I'm want to replace these parts when I do my Timing Belt Service and am trying to source the parts as we speak. At least I'll know that new pieces are installed and won't be worried.
-Jalal
Part# 1840A006
Part# MD326852
Part# MD377400
Part# 1101A022
-Jalal
Hi MJ23FE,
Mind to share the link you bought the item for belting change.
My time also around the corner... the item above can be use on JDM EVO 8MR?
Hopefully the could ship the item to Malaysia...
Thanks in advance
Thanks in advance
For my 60k service I will be installing the following:
MAP
-Water Pump
-Balance Belt Tensioner
-Balance Belt*
-Timing Belt*
-Timing Belt Tensioner
-Timing Belt Tensioner Pulley
-Timing Belt Idler Pulley
-Serpentine Belt (w/AC)
*Gates Racing Kevlar Belts
CBRD
-Crankshaft Angle Sensing Blade
-Crankshaft Camshaft Drive Sprocket
-Crankshaft Pulley Washer
-Crankshaft Pulley Center Bolt
All are OEM
Mitsubishi Parts except the Timing Belt and Balance Belt. This is all being installed by CBRD on November 29th. Woot woot!I would double check with MAP to see what would be different between the VIII and IX. Off the top of my head I know that the Water Pump's are different.
-Jalal
