IX Engine idle noise (belt?) (video)
When I had this problem with my old EVO I used CRC belt conditioner. It actually made more noise for a little while and than it went away after a few weeks and I never heard the noise again even until the day I got rid of the EVO.
We often do a test to confirm cas plate scraping belt edge.
And a pen of dri lube or door cleck grease just touched on the inside edge of the belt while running often confirms suspicions.
And is most likely the tensioner pivot arm bush twisting or any other misaligned bearings.
sorry if its already been mentioned.
But not always a major concern if it goes away.
I would inspect the belt edge periodically if your concerned.
This is going to sound really stupid, but I removed my AC this winter and put on a new shorter acces. belt and did a bunch of other engine work (none of which involve the timing belt area) and now my noise is gone? I highly doubt it is fixed but I'll report back after a few weeks of use or if the noise comes back before hand.
2. Where would one acquire such a belt?
As I thought, the noise came back after a few hot/cold cycles. I knew it was too good to be true. lol.
To answer your questions:
1. This belt can be used with all the AC components still on the car. The belt is just shorter and it would not go around the AC pulley.
2. I got my belt from Napa. There was a AC removal thread on here I found that had listed about 4 different brand belts with their part numbers that would fit with out the AC. I think my Napa # is 25060569, I'm at work right now so I cant go check it.
Mitsubishi Motors North America, Inc.
PO Box 6400
Cypress, CA 90630
Well I don't believe him either. Because mine still does it after a new belt and me going under the hood with a stethiscope. It's definitely inside. From all the reading (AND ITS ALOT OF READING), I am sticking with what originally was said about the crank blade sensor or whatever rubbing the timing belt.
Either way Mitsubishi blames me because it was not a "Mitsubishi belt"
Hey Guys,
It seems I get the squealing belt noise only when it rains outside... I have a 2004 evo 8. Any ideas on how I can stop this from happening? I have about 56k and don't plan on doing a timing belt or serpentine until around 60k.
Thanks!
Thanks!
The problem we are having isn't the belt squealing. Its a metal on metal noise not squealing. Do you have your undertray on and all the plastic covers in the passenger side wheel well? Thats prob ur issue.
hey turboalawd,
I have been getting a more prominent sound especially when it rains. Its the metal on metal rotational sound but can you explain what that sound has to do with the plastic covers in the passenger side of the wheel well? Is it rubbing? thanks again
I think hes asking if the liners and undercover are installed because if there not water is splashing on the belt causing it to squeal.
If you dont have the liners or undercovers on, water could be splashing up and causing the belt and or pullies to be making the noise you are experiencing.
damn i'm also starting to have this sound on my ix... but mine's only when its colder... after driving for awhile the sound disappears... or if u rev abit more the sound also disappears
