IX Engine idle noise (belt?) (video)
Old Jan 13, 2010 | 10:59 AM
  #436
MJ23FE's Avatar
Originally Posted by halfnhalf83
it doesnt.... this noise/symptom is also there when warm. doesnt matter hot or cold.
+1
-Jalal
Old Jan 21, 2010 | 12:55 PM
  #437
detroit pistins's Avatar
for those having this noise issue, how much oil do u guys pore in ur motors, 4.8 quarts or 5 ???
Old Jan 21, 2010 | 01:26 PM
  #438
GG06MR's Avatar
I'm extremely **** retentive about not overfilling, so I usually put 4.5 qts. to start, drive it around to cycle everything through, and then top it off the next morning so it's level with the top mark on the dipstick. That usually equates to about 4.7-4.8 qts. total.
Old Jan 21, 2010 | 01:41 PM
  #439
and I am assuming u still get that nise correct?
Old Jan 21, 2010 | 01:43 PM
  #440
GG06MR's Avatar
Yep. Oil level and oil quality have zero impact on the scraping noise my car makes.....which is identical to the youtube clip in the OP's 1st post.
Old Jan 21, 2010 | 01:56 PM
  #441
a friend of mine just told me that he had the same issue with his ix and it was the alternator pully. has anyone tried swapping this?
Old Jan 21, 2010 | 02:01 PM
  #442
GG06MR's Avatar
If that's the case, then he had a different issue. All you need to do to make sure is remove your accessory belt. If it still makes the noise, then it's not one of the accessory pulleys. If it goes away, then your Evo likely has the same problem as your friend's.
Old Jan 21, 2010 | 02:02 PM
  #443
but what about if the pully is making the noise while its under tension by the belt?
Old Jan 21, 2010 | 02:05 PM
  #444
GG06MR's Avatar
That's the point. If the noise goes away when the belt is off, then you know it's one of the pulleys. If not, then then you know it's behind the Timing Belt cover.
Old Jan 21, 2010 | 02:13 PM
  #445
ah i c. didnt get ur statement at first.
is it safe to run the motor without the accesory belt?
Old Jan 21, 2010 | 02:23 PM
  #446
GG06MR's Avatar
No problem. It's not easy to explain, so I understand. And....yes, it's safe to run the motor without the accessory belt attached, but not for long, since the alternator won't be charging your battery with it off. More or less, you just want to take it off, fire up the car, take a listen to see if the noise is still there, and then turn it off so you can put the belt back on. Definitely no driving without it on though.
Old Jan 22, 2010 | 06:46 AM
  #447
Nitrotiger's Avatar
62k still whining in the cold weather so im not to concern with it. if it was a tensioner should do it all the time. and when the car warms up it's fine
Old Jan 22, 2010 | 09:59 AM
  #448
meltdown's Avatar
+1 ... 47k miles
Old Jan 22, 2010 | 10:03 AM
  #449
halfnhalf83's Avatar
it doesnt have to do with warm, or cold. it does it all the time. its not the whinning, its the scraping/rubbing sound.
i think people are getting confused....
it will do it when the car is fully warmed too!
Old Jan 22, 2010 | 10:11 AM
  #450
GG06MR's Avatar
What he said. Mine makes the scraping/rubbing noise most noticeably when it's really cold or really hot though.
