IX Engine idle noise (belt?) (video)
Old Jan 11, 2010 | 08:25 PM
  #421
aqualime's Avatar
Might as well make your complaint anyways detroit. Good luck guys!
Old Jan 12, 2010 | 06:27 AM
  #422
GG06MR's Avatar
Originally Posted by Spoolin69
100% yes this will be covered by your 5 year 60K warranty.
-Shane
Assuming they admit that the problem was not caused by the customer. For example, I brought my car in to the dealership literally telling them that the problem was with the timing belt, crankshaft blade, etc., and they returned it to me stating that the accessory belts were "overdressed" and billed me $150 to spray degreaser on them. The belts of course had never been "dressed" to begin with. No surprise, the car made the same noise again within a week. When I eventually have 3 days where I can live without my car again, I will definitely be taking it back to those jokers and demanding they get someone to work on the car that has a clue.
Old Jan 12, 2010 | 06:40 AM
  #423
GG06MR's Avatar
Also, has anyone taken their car to the dealership 4 or more times for this issue? If so, and your IX is still under 60K miles, any chance you want to test the lemon law? I just did a little research on this, and it looks like that would be enough to be able to file for a refund. Just thinking that if there are enough people that are unhappy about this, and willing to stick it to Mitsu for refunds, then they might be more willing to do something about the problem before all of their IX customers with problems decide to get refunds.
Old Jan 12, 2010 | 11:41 AM
  #424
x569's Avatar
To Everyone: Be sure to read post #389
https://www.evolutionm.net/forums/7847291-post389.html
This appears to be the problem.
Will the EVO 8 Sensor blade fit the EVO 9 and will that fix the issue? hmmmm...
Old Jan 12, 2010 | 11:54 AM
  #425
06EvoIXmr07's Avatar
Thats what i want to know.
Old Jan 12, 2010 | 07:07 PM
  #426
4xforce's Avatar
Just a bump and a reminder to visit the NHTSA site and register the complaint. There is enough of us here to get our problem resolved if we just file a formal complaint. It only took me 5-10 min. Let this issue get resolved on mitsu's dime!!
Old Jan 12, 2010 | 10:13 PM
  #427
turbotalawd's Avatar
Just filed my NHTSA complaint. My noise started last August at 21xxx miles.
Someone stated that its the timing sensor blade. My 1g talon used to have a similar blade between the balance shaft belt and the timing belt (not used for timing just a spacer) and had the same exact markings on the back but my talon never made that noise.
Old Jan 13, 2010 | 06:52 AM
  #428
MJ23FE's Avatar
I have an Evo 9 and these diagrams are from the 2006 service manual.
I'm at work so the pictures in the link posted in the above quote do not show up. However, if it is in fact the Crankshaft Angle Sensing Blade, then here are some photos of it.
You can see how it could potentially be mounted too close to the belt causing it to rub and create the noise we have all been hearing.
-Jalal
Attached Thumbnails IX Engine idle noise (belt?) (video)-crankshaft-angle-sensing-blade-1.jpg   IX Engine idle noise (belt?) (video)-crankshaft-angle-sensing-blade-2.jpg
Old Jan 13, 2010 | 07:14 AM
  #429
MJ23FE's Avatar
I just had a horrible thought: What if this is another case of Crankwalk? They say some of the 2G DSM's have crankwalk. One symptom is "Ticking or strange noise from the pulley side of the engine when clutch is depressed." Also they say (quoting overbore.com) " ...causing the crank angle sensor reluctor plate to come into contact with the sensor." Looking at the exploded view (EVO) shows the crank angle sensor is (of course) behind the crank sensing blade! I don't think so, I hope not. But the 2G Talons have quite a few more symptoms, none of us have reported those.
I hope it's not crank walk!!!
-Jalal
Old Jan 13, 2010 | 07:22 AM
  #430
detroit pistins's Avatar
if it is the crankshaft sensor blade or crank....etc why does it only appear when its really cold out?
Old Jan 13, 2010 | 07:25 AM
  #431
penthouse's Avatar
pretty normal valves sound from evo 8, 9 especially cold start up
Old Jan 13, 2010 | 08:04 AM
  #432
MJ23FE's Avatar
Are you commenting on the video linked in the very first post or just talking about the sound your own caar makes?
-Jalal
Old Jan 13, 2010 | 08:11 AM
  #433
penthouse's Avatar
-Jalal
from the original op post.
Old Jan 13, 2010 | 08:29 AM
  #434
MJ23FE's Avatar
If that's the case then the rotating/rubbing sound your hearing is not valves. It's definitely a belt.
-Jalal
Old Jan 13, 2010 | 10:10 AM
  #435
halfnhalf83's Avatar
it doesnt.... this noise/symptom is also there when warm. doesnt matter hot or cold.
