IX Engine idle noise (belt?) (video)
Old Jan 30, 2010 | 11:01 AM
  #466
XdsEVO8X's Avatar
Its also could be the timing belt rubbing the cover there was some issue with that awhile back something about the belt bein to weak and stretching.. hope that kinda helps
Old Jan 30, 2010 | 12:08 PM
  #467
evodom1's Avatar
the cover of timing belt (I meanb plastic cover of camgears) is uninstalled...
Old Feb 1, 2010 | 01:34 PM
  #468
21Evo-lution's Avatar
Originally Posted by x569
Ok well Mitsu just called me the problem was, in fact the accessory belt. I told him I did not believe him and I said "let it sit over night and start it in the morning and let me know if it still does it." (I actually put the belt on it this time a few thousands miles ago) and they cleaned the belt and the sound is supposedly gone. So if it comes back, then it appears that area needs to be cleaned out and watched more often.
1/29: Just got it back and they say that it was indeed the accessory belt. It is silent now. So everyone take off your belts and clean them up! Or have the dealer do it.
1/30/: Ok I have more info. I looked at the belt and touched it. It appears the mechanic put a layer of Grease on the bottom of the belt. Is this standard? I have never done this on any of my cars.
I might have to try this also!
Old Feb 1, 2010 | 03:25 PM
  #469
turbotalawd's Avatar
Did you check if the dealership also put some grease on the timing belt? Also how old is your accessory belt? have you ever changed it?
Old Feb 2, 2010 | 09:16 PM
  #470
x569's Avatar
I changed that belt myself at 30K (with a Non--Mistubishi belt). Not sure if they greased the TBelt. I doubt it...
Old Feb 2, 2010 | 09:19 PM
  #471
mc14's Avatar
I also have this sound, ive heard it is normal for VIII's And IX's
Old Feb 3, 2010 | 02:33 AM
  #472
Yamahar1's Avatar
I have the same sound in mine.
Old Feb 3, 2010 | 02:33 PM
  #473
Its funny ive never heard any other evo (8 or 9) make that sound. I thought it was mostly common with 9's no?
Old Feb 19, 2010 | 05:03 PM
  #474
Any updates/info from anyone?
Old Feb 19, 2010 | 05:18 PM
  #475
detroit pistins's Avatar
I replaced the belt on mine, and it reduced the noise alot. but didnt remove it completely. however, now that the weather is starting to warmup, the noise doesn;t come on sometimes.
Old Feb 19, 2010 | 05:41 PM
  #476
btw how many people are getting this noise and are using a minibattery?
the reason why iam asking, is cuz the mech told me that it could be a possibility that the alternator is over working to recharge the battery at start up since it might be low on voltage. not sure how much of that is true. but i do have amini batt on mine so...
Old Feb 19, 2010 | 06:09 PM
  #477
GG06MR's Avatar
That's all external of the timing belt, tensioner, crank sensor blade, etc., so it wouldn't impact it. Tell your mechanic to think of ideas for stuff behind the timing belt cover.
Old Feb 19, 2010 | 06:20 PM
  #478
behind the timing belt cover as in inside of it, or close to the firewall?
ya i didnt buy what he said, but just thoguth of throwing it out there.
is urs making the same noise? and what have u done to it so far if so?
Old Feb 19, 2010 | 07:22 PM
  #479
GG06MR's Avatar
I suppose inside of the timing belt cover is a more accurate way to put it. It's just that the alternator is external to the longblock, and driven by the accessory belt, which has nothing to do with the noise the OP and many others like myself are experiencing.
As far as mods go as of the time my car started making the noise, it had a TBE and an APS BOV. That's it, so it's clearly a Mitsubishi OEM parts/component issue.
Old Feb 19, 2010 | 07:31 PM
  #480
in my case its not coming from the timing belt. and it does sound like the op's clip.
