IX Engine idle noise (belt?) (video)
Old Feb 19, 2010 | 07:54 PM
  #481
GG06MR's Avatar
Originally Posted by detroit pistins
in my case its not coming from the timing belt. and it does sound like the op's clip.
It may make the same, or at least a similar sound, but your issue is different than what the OP, myself, and most others with that sound are experiencing. The OP clearly states on post #37 and #40 that his issue was with the timing belt, and most others with that sound have already verified that the noise is coming from behind/inside the timing belt area on their car as well. I know that mine definitely is.
So...since yours is a different issue, it would probably be best if you started a new thread with video to show what you're experiencing, making sure to note that your issue is external to the timing belt area. That would be best for other Evo owners that could be potentially experiencing the same issue that you're having, and potentially help you to resolve what's happening with your car. Just my 2 cents.
Old Feb 20, 2010 | 01:43 PM
  #482
turbotalawd's Avatar
Im not running the mini battery and still have the noise. I replaced the accessory belt tensioner pulley thinking it was the problem but the noise is still there.
Old Feb 22, 2010 | 12:34 AM
  #483
Stockie's Avatar
So wtf is the cure, I just read this entire thread, n it helped me with nothin!
Any Gurus with a fix? No more scared rookies need to reply to this. Only knowledgable people, possibly its not even bad...
Old Feb 22, 2010 | 12:39 AM
  #484
x569's Avatar
Read post #464. I told everybody what the noise was
https://www.evolutionm.net/forums/7935335-post464.html
Old Feb 22, 2010 | 12:57 AM
  #485
Stockie's Avatar
How many miles since the clean? Has the noise reappeared?
Old Feb 22, 2010 | 01:06 AM
  #486
ssg_petty_210's Avatar
About a week ago, when it is cold outside and I begin to warm up the car before I even drive it, I start to hear a small squeak, as if the timing belt is warped or dry. I'm not sure, but it is bothering the hell out of me. I cant stand to have any imperfections to my car.
Old Feb 22, 2010 | 05:58 AM
  #487
detroit pistins's Avatar
suggestion: while its making the noise, spray on some belt lubricant and see if it changes its tone. if it dioes then there is ur answer.
Old Feb 22, 2010 | 06:48 AM
  #488
x569's Avatar
No, with grease on it the noise was gone. But I did not like the grease idea, so I took off the belt and put on a new one again. But Grease attracts dust and dirt. The noise is back slightly. This noise is better than dust and dirt jamming into the pulleys.
Old Feb 22, 2010 | 12:39 PM
  #489
halfnhalf83's Avatar
people are getting the noises mixed up. The noise that is the problem is audible when cold, or fully warmed up!
it is NOT normal.... its only a common issue that has yet to be resolved.
Old Feb 22, 2010 | 12:44 PM
  #490
GG06MR's Avatar
Originally Posted by Speed MR 857
I have checked with the dealer, this noise is normal. It's coming from timing belt tensioner roller. Now here it's winter thus noise is existing only when the car is cold. when it's hot, no noise. No need to worry about this noise as it's common and normal.
It's certainly common with the Evo IX, but not normal for a belt and pulley system to make that noise. There's a reason that, for example, the VIII's don't make that noise, so it's clearly a design and/or component issue that was introduced with the new MIVEC powerplant. I've yet to hear of any timing belt failures or anything like that because of this, but I'd certainly appreciate Mitsubishi providing some new components that will get rid of the noise permanently.
Old Feb 22, 2010 | 03:56 PM
  #491
Routybouty's Avatar
This.
I can't believe one of the shops haven't chimed in. I'm sure one of them has stumbled across some type of info.
Old Feb 23, 2010 | 11:04 AM
  #492
BlackMRSE's Avatar
Originally Posted by x569
I sent a letter to Mitsubishi of America and they have now called me and want to talk about the noise. (For me I have had the belt replace 2 times and the noise is louder than ever).
It looks like I will be able to get some sort of resolution. What they can do (which I read before considering the lemon law) is give me my money back , and a percentage of that goes to the dealer. With the price of used EVO's going down. I can find a fully built EVO 8 for about $20,000. Might be a good time to buy if I can return the EVO 9. I'll let you know what they tell me.
Could you please give us the address of where you sent your love letter to? I have a nice letter that I'd like to send them as well. I am about to have to replace mine for the third time as well. This is really starting to annoy me.
Old Mar 1, 2010 | 11:33 PM
  #493
samurai85's Avatar
So was this ever fixed? Seems like you are saying they just lubed your belts.
Old Mar 1, 2010 | 11:36 PM
  #494
samurai85's Avatar
I just read through the last 10 pages or so of this, and I have started recently having this problem as well. I get a squeeking sound sort of like the video OP posted. I only get it when the engine is a complete cold start, but it goes away as soon as the motor is warm.
I'm confused as to the problem OP and you guys have, if you guys having all the time or only when motor is cold.
People here are not clarify their fixes to what their initial problem was and how it occurs (cold or warm car?), or maybe I'm just not reading the full thread and only skimmed the last 10 pages.
Old Mar 2, 2010 | 04:16 AM
  #495
I4UnderPressure's Avatar
Ok well Mitsu just called me the problem was, in fact the accessory belt. I told him I did not believe him and I said "let it sit over night and start it in the morning and let me know if it still does it." (I actually put the belt on it this time a few thousands miles ago) and they cleaned the belt and the sound is supposedly gone. So if it comes back, then it appears that area needs to be cleaned out and watched more often.
1/29: Just got it back and they say that it was indeed the accessory belt. It is silent now. So everyone take off your belts and clean them up! Or have the dealer do it.
1/30/: Ok I have more info. I looked at the belt and touched it. It appears the mechanic put a layer of Grease on the bottom of the belt. Is this standard? I have never done this on any of my cars.
Well I don't believe him either. Because mine still does it after a new belt and me going under the hood with a stethiscope. It's definitely inside. From all the reading (AND ITS ALOT OF READING), I am sticking with what originally was said about the crank blade sensor or whatever rubbing the timing belt.
