Forced Performance Evo Red Turbo data
Old Aug 4, 2008 | 08:56 PM
  #661
CO_VR4's Avatar
Originally Posted by GrocMax
On a lousy 1.83 60 ft. Needs driver mod.
Oh, and if y'all want to split hairs, technically it *is* pump gas, EPA approved for sale at a public conveyance 100 UL. Drive into the big Mobil station in Van Alstyne TX, slide CC, fill 'er up.
If y'all want to play with fire here in the heat of summer with 93 octane fuel and no knock control, go for it. It is plain stupid when this stuff is available down the street for 15-20 dollars more per tank than 93.
Doesn't seem complicated. Just read it. 100UL. No knock control on a Motec? Since I don't have 5K to buy one I'm somewhat unfamiliar with what's included. If any computer does not include knock control, I'd be keeping the octane in the "super safe" range, too, I guess... The boost levels are pump gas range, though, if your timing is adjusted...
BTW, I got almost 40 miles to the gallon last year for a 40 mile run. Yep, from the Continental Divide to Morrison, Colorado. Never dropped below 80, either.
Old Aug 4, 2008 | 09:11 PM
  #662
KevinD's Avatar
i've done that too heading back from winter park last summer in the evo. but your mileage going down STEEEP hills is obviously going to be better then going back up the hill (prolly around 10mpg).
here in DFW there aren't mountains to drive down though, so 36 mpg over the course of a tank here is just not possible with an evo driving normal (and by normal i mean you can accelerate as slow as you want, but at 70mph, your not getting 36 mpg period.
and Groc,
Once you pass a car under power or go thru the gears quick from a stop your fuel mileage goes into the toilet. Most people do not have the right foot discipline required to get good fuel mileage. It takes no more fuel to keep an EVO rolling at 65-70 MPH as it does a Geo Metro of the same weight, rolling resistance, drivetrain friction, and cD.
metros weigh half as much, much less rolling resistance, less drivetrain friction, and most likely a better cD (much smaller profile, and evo is not even remotely aerodynamic), yet a metro is barely going to get 36mpg at 70mph. can a metro even go 70 mph?
Old Aug 4, 2008 | 11:10 PM
  #663
RazorLab's Avatar
If you want to start something, just start it, don't hint around.
How about this. If Robert is running 100 octane, just say it, don't hint around with "UL" that 99% of the people on the forum might not understand.
Don't call me out for trying to clear the air. You and Robert are "hinting" more than I am. Don't think that just because you work at the company affords you immunity from the masses.
Just answer the question for the masses. 93 octane or higher for the 124 traps?
I'll say 100 octane UnLeaded until you tell me otherwise. I do think that everyone was thinking this was done on pump gas. Using motec without knock control should not be a scapegoat for misleading everyone.
God forbid a FP turbo gets tested on less than race gas before being released to the public...
Old Aug 4, 2008 | 11:20 PM
  #664
Cali2MDevo8's Avatar
Registered User
Originally Posted by razorlab
Who wants to start bets on when a customer outside of the circle actually gets a red?
I'll start at 1.5 months. That's how long it took me to get my green when they where "first" announced.
Originally Posted by Cali2MDevo8
This is Day 20 from the start of the thread.
1/2 way there..........
Day 28 and counting.......its been 4 weeks now.
I think your going to lose this bet partner
Old Aug 4, 2008 | 11:24 PM
  #665
RazorLab's Avatar
Amazing, and it was said they had 15 ready to go...
Old Aug 5, 2008 | 02:35 AM
  #666
EE's Avatar
EE
They already started shipping some of the first 15 turbos... now it depends on your position in the waiting list...
The test was done at 25 psi, 100 oct won't give you 100 bhp at this boost level!
Trent's car made 30 whp more on race gas when compared to 93 octane, not to mention the race gas tune had 8 psi more than the 93 oct. tune...
Furthermore, the motec has no knock control, maybe the extra octane was used for safety???
Elie
Old Aug 5, 2008 | 06:40 AM
  #667
sparky's Avatar
The FP Red turbo has a non-HTA compressor wheel doesn't it?
Old Aug 5, 2008 | 07:20 AM
  #668
CO_VR4's Avatar
I think the Green has a non-HTA compressor wheel.
The Red has an HTA compressor wheel.
Old Aug 5, 2008 | 07:36 AM
  #669
sparky's Avatar
Cool, and thanks, COVR 4. I was hoping that it was non-HTA, which would leave the door open for an even faster spooling HTA Red version in the not so distant future.
Old Aug 5, 2008 | 07:44 AM
  #670
tnt1106's Avatar
My pops had a bright red metro convert, they will go 84 wide open on a very long stretch of flat or down hill road. Maybe the hard top does better? Oh, his was hevily modded with a Suzuki Bandit muffler and open air filter and and and... water injection milage? he used to get high 30's from Dallas to San Ant.
Old Aug 5, 2008 | 07:46 AM
  #671
sparky's Avatar
You're right that the current FP Green has the standard 5-bladed non-HTA, "White Rabbit" wheel. Remember that FP designed the 1mm smaller HTA wheel now used in the FP White for the ill fated HTA Green turbo, but it didn't interface well with the higher mass, "LT" turbine.
  #672
Mellon Racing's Avatar
I think it's pretty important to be forthcoming with the mods/boost/octane/race weight etc.... to help people make a wise purchasing decision based on someone elses e.t./mph/dyno numbers.
Old Aug 5, 2008 | 07:48 AM
  #673
EVO8LTW's Avatar
It still seems unclear whether the red will outperform the green without either very high boost and/or exotic supporting mods.
Old Aug 5, 2008 | 08:08 AM
  #674
sparky's Avatar
Agreed, Chris! I am wondering whether Robert's car was running a 93 octane tune and they just threw in the 100 unleaded as a precaution against possible detonation, given the prevailing test conditions, the record Texas heat, and the fact that the MOTEC has no knock control.
The boost levels were a safe 25#, which is a pumpgas boost level attainable even with a stock IX turbo on 93 octane. I look at the use of the 100 octane fuel in this particular case as merely a safeguard against destructive detonation.
In fact, and you would know this better than most, for sure... if a car is tuned for 93 octane pump gas and you just throw in 100 octane unleaded without retuning for the different characteristics of the new fuel, doesn't it give less than ideal AFR's? Won't the 100 octane fuel's different specific gravity, density and burn characteristics throw the tune somewhat off?
Old Aug 5, 2008 | 08:20 AM
  #675
depends on the fuel used but yes simply adding race gas on top of a pump gas tune is likely going to have you very rich.
with my evo when it was tuned to 11.5:1 on 93 octane if I put in c16 it would drop to 10.5:1 area and flat run sluggish if the AFR, timing and boost weren't adjusted to take advantage of the better octane.
