Forced Performance Evo Red Turbo data
Old Aug 5, 2008 | 01:22 PM
  #691
BlueDemon's Avatar
^I agree with Mellon on that one
Old Aug 5, 2008 | 01:39 PM
  #692
Phalse's Avatar
Interesting catch up on this thread, robert running race gas instead of 93 makes things alot more clear.
Old Aug 5, 2008 | 01:42 PM
  #693
9sec9's Avatar
I kinda like 1 gallon per mile and that's not at pump gas prices.
Old Aug 5, 2008 | 03:02 PM
  #694
Cali2MDevo8's Avatar
Registered User
Originally Posted by DSSA
You guys need to look up "hypermiling" and see what is actually possible.
People getting 55+ mpg out of regular civics, 128+ mpg out of Insights, etc.
Just messing around the other day on my way home from visiting family, I actually got 29 mpg (28.6) out of my Evo X over a 110 mile drive. Unfortunately, I think that might be a near-record with these things.
I'm sure if you take the highway and cruise the whole time without stopping ever, it's possible to get 30mpg. Everyone knows that.
Who cares about MPG. I want to see a RED on 93 octane running 23-25psi with supporting mods.
That's what everyone is waiting for. Not bickering about MPG
And Robert, where's that 100 octane dyno chart?
Old Aug 5, 2008 | 03:30 PM
  #695
PeteyTurbo's Avatar
GrocMax you are still the same as you were when the galant boards started, I love it!! I thought you dissappeared.. You taught me alot of what I know today and certainly helped me out alot back then..
and DSSA! WTF man show your face somewhere other then JNZ which I have never even been to in my life.
Back on topic I'd really like to see some customers that are not associated with FP put up some track times with openport tuning. We all know standalone is the way to go but I'm not going to run it on my car..I'd just like to crack off a 10 second slip on E85 and 30psi and get kicked off, if I knew that was possible I'd probably get one. You'd think a .7 gian in e.t. would be possible but it's not that cut and dry really.
I want to see some cars running stock ECU run at the track with this turbo and see how much mph they really pick up, this turbo sounds almost too good to be true given the $$ per HP ratio for stock appearing turbos until now..
FYI the red should be worse (slightly) then a stock turbo for MPG soley because of increased backpressure off boost in the hotside..IT's all tuning and nothing having to do with the turbo really.
On a side note I want to say that I think I can speak for 99% of us when I say 100 octane is "racing fuel" weather or not a specialty station nearby sells it at the pump..I have not seen it at the pump in over 10 years..And I do agree with another 99% of the people here that I think FP makes GREAT turbochargers!
Old Aug 5, 2008 | 06:07 PM
  #696
FathouseFab's Avatar
Robert, Are you still on the stock evo9 4th gear? What did the car mph in the 1/8?
You need somebody to test one on a bolt on, stock ecu, e85 car just let me know.
Fathouse
Old Aug 6, 2008 | 06:13 AM
  #697
CO_VR4's Avatar
C16, Q16, VP Import or similar is real race gas. 100UL is NOT.
The fuel curves and timing curve capabilities for real race gas, like C16, Q16, or VP Import are very different than those for pump gas, including 100 octane unleaded from the pump, and so is the fuel's capability for very high boost. Here in Colorado, there are stations that have 106 octane you can pump. It has nowhere the performance characteristics of the C16 that I've compared it to. Not even in the same ballpark.
As a good example of this fact, look at 9sec9's boost levels on the Red using VP Import compared to the 26 PSI Robert was running on 100 unleaded pump.
The point is that Robert's information is another set of data that is useful for those who are trying to get a better feel on what the Red will do. It's easily comparable to many 93 pump gas tunes that use the general range in boost level (26PSI). As Robert explained, it was used in his car because it's 100F outside and the Motec has no knock feedback control.
Old Aug 6, 2008 | 06:28 AM
  #698
scheides's Avatar
EvoM Moderator
Originally Posted by ForcedPerformance
I took the same car to the dyno weds of last week as a matter of fact, it did 470whp at 25psi. Want to see the dyno graph?
Ok, I'll scan it and post it up tomorrow.
My EVO9 is stock engine, stock head (never been off). We did "sneak" the ARP headstuds in there when installing the FP4R cams.
Stock intake manifold, stock upper IC pipes. Stock air intake pipe with non stock MAF meter and open element filter. It has 850cc injectors and a 342 fuel pump. Stock fuel lines and regulator. It has a Buschur race FMIC (you gotta have one of the these, especially in Texas), and a scratch built lower IC pipe. It has a 3" Works O2 housing and 3" DP and exhaust system, no cat. It has a exedy twin ceramic clutch (the HD one). It has a stock unported exhaust manifold, and a unported turbine housing. The turbo is the FP EVORed model of course.
I have since replaced the stock valve springs with our beehive style springs after noticing that the stock springs were sagging out after 15k miles on the 4R's with a daily 8500rpm rev limit and countless trips to that rev limiter.
The ECU is motec M800, but the ignition system is stock. Lots of stock parts. I like stock parts, I like popping the hood after those low 11 second passes and having people walk up and look really confused. BTW, I got 31mpg in that car on the way too and from the track, and it did even better a few days later on another trip, 37mpg.
Post up the graph already! This is a great example of what this turbo will do on your 'average' evo out there! 100 octane fine, I run alky injection, should see similar results!
Old Aug 6, 2008 | 06:48 AM
  #699
Phalse's Avatar
You can call it what you want, to me 100ul is race gas cause thats where i buy it around here, same guy that sells the VP ****. There is no pump around here that sells 100, there has never been a pump in any city ive lived in that has 100. Every now and then you run into a station that has Phillips b32/33 at a reasonable price, but either way I think its safe to say that most people assume 93 when you say pump, and I was merely commenting on the amusing fact that it seemed robert was trying to sneak in > pump results while alleging to a pump.
And I'm well aware of the disparity in performance between octanes, thanks..a even a few points can have a massive difference in trap when used properly.
Old Aug 6, 2008 | 06:58 AM
  #700
scheides's Avatar
EvoM Moderator
Dudes, drop the freaking 100 octane pump gas bickering, it's older than old, been around for years, and besides, it's getting way OT. This thread is about zee RED!
Old Aug 6, 2008 | 07:04 AM
  #701
tnt1106's Avatar
^ +1
Old Aug 6, 2008 | 08:39 AM
  #702
Shacochis06's Avatar
Buschur finally got mine in today thank god
Old Aug 6, 2008 | 08:44 AM
  #703
EvoBroMA's Avatar
Originally Posted by Shacochis06
Buschur racing finally got mine in today thank god
awesome! the red's are finally shipping!
report back - when you finally get it running.
Old Aug 6, 2008 | 10:11 AM
  #704
RazorLab's Avatar
These people trying to justify that 100 is pump gas and basically the same as 93 is probably one of the funnier things I have read on Evom in awhile.
Old Aug 6, 2008 | 10:19 AM
  #705
ForcedPerformance's Avatar
Guys, if I thought 100 octane fuel was the same as 93 octane fuel, why would I run 100 octane fuel? It has benefits, like less detonation. I need that, I don't have knock control and I want to run more than 22psi.
https://www.evolutionm.net/forums/sh...d.php?t=362140
