Air Filter Shootout Test - Results!
Old Jan 13, 2009 | 07:56 PM
  #211
Oil Doc's Avatar
AMSOIL Ea Air Filter media removes 5 times more dust than traditional cellulose filters and 50 times more dust than wet gauze
This use to be on the Donaldson site except it said Nano-Fiber instead of AMSOIL..
We buy the Patented Media from Donaldson and we are the only company that can buy it.
Doc
Old Jan 13, 2009 | 08:08 PM
  #212
shadow1's Avatar
Oil Doc - you are still just quoting a product brochure. I was interested in the actual raw data.
Old Jan 13, 2009 | 08:25 PM
  #213
Wicked E's Avatar
Originally Posted by Oil Doc
If the filter has been washed, there is not enough oil on it.
And no where did I mention that I put the bag over the filter and rubbed some oil on it after it was dry. I was not happy with it being drenched with oil like it was dunked in a can of oil like a drunk being sobered up. Didn't know I had to explain EVERY detail of what I did to mine...
-E
Old Jan 13, 2009 | 08:37 PM
  #214
VRSF Tiago's Avatar
I'm pretty sure CBRD even said that this filter needs to be oiled in order to filter correctly.
I'm guessing it's filtered for a reason.
Old Jan 14, 2009 | 07:01 AM
  #215
scheides's Avatar
EvoM Moderator
Ok, its been ****-***ing cold here so have not had a chance to think about the car until today. The other morning it was -21F, prolly about -15F when I went out to install the new MAF & filter setup. Just started the car and verified that the maf at least registered in evoscan and it did!
Drove the wife to work today and on the way to my office did a few rips and logged it. It's so cold here I half thought about just skipping it, but I had to be sure the new maf read correctly. AFR's are 10.8-11.2, just as I'd expect with the old setup on pump gas. Driveability with the new filter is awesome, and power seems right in line with what I'd expect.
Wind chill is -29F but I had to snap a pic in daylight with my phone. The JMF spark plug cover and exh mani heat shield were xmas presents, just got those on a few days ago as well.
Old Jan 14, 2009 | 07:04 AM
  #216
MR Turco's Avatar
ok well since i did wash the filter with dish soap i went back last night and use a few sprays of filter oil i had from my old K&N kit. So now it is "lightly" oiled.
Old Jan 14, 2009 | 06:54 PM
  #217
wizzo 8's Avatar
If I could get an amsoil filter to fit I would buy one. My acd is in the way though
Old Jan 14, 2009 | 08:37 PM
  #218
scheides's Avatar
EvoM Moderator
Originally Posted by evane
it would be a good idea to test the full intake system, along with the aps cold air intake and the arc intake box
OMG you lucked out, and guess what, the results back up what we already know: the stock intake system SUCKS:
https://www.evolutionm.net/forums/ev...rc-airbox.html
Old Jan 14, 2009 | 08:48 PM
  #219
codean's Avatar
K&N filter oil is not ment to be used on a foam filter.
Foam Filters need to use there own type of oil.
Old Jan 14, 2009 | 09:50 PM
  #220
Meevo's Avatar
Do you guys think I can fit an amsoil air filter in, and do I need a MAS thing or do I already have one? I really don't know much about air filters etc., so I don't know anything of what I need. Would anyone be able to tell the mounting flange diameter? Is it 4.5 inches?
If not, how come a'pexi is so much more expensive?
PS sorry for the dirty engine bay =]
Thanks!
Old Jan 15, 2009 | 04:49 AM
  #221
shadow1's Avatar
You have the same K&N 1005 filter that I have. The flange ID is 4.5". That is likely a TurboXS intake kit with their MAF adapter. Apexi is expensive cause it is Japanese.
Old Jan 15, 2009 | 05:33 AM
  #222
MR Turco's Avatar
Seriously?
Old Jan 15, 2009 | 05:49 AM
  #223
VRSF Tiago's Avatar
Seriously?
I've heard the same.
Old Jan 15, 2009 | 06:37 AM
  #224
Meevo's Avatar
Thanks, does that mean I don't have to buy one of these?
http://www.maperformance.com/vibrant...tion-1995.html
And that the intakes from the test will just bolt right up?
Do you think the amsoil will fit in there?
Otherwise, I'll probably go with apexi, heard good things about the filtering, and it's got a good curve.
Is the apexi oiled? I like that the amsoil isn't.
Sorry for million questions!
Old Jan 15, 2009 | 07:27 AM
  #225
MR Turco's Avatar
according to the intarweb you are correct. How annoying.
