Air Filter Shootout Test - Results!
Old Jan 6, 2009 | 01:31 PM
  #121
Kracka's Avatar
My theory on the Apexi:
My theory on the airflow (as shown in the graph) is since it has the goofy neck-down adapter more air is flowing through the center of the MAF being metered therefore not as much on the sides being unmetered. This would also explain why the Apexi filter had the richest AFR's since the car is actually getting less air than the MAF thinks it is.
Old Jan 6, 2009 | 01:38 PM
  #122
scheides's Avatar
EvoM Moderator
Originally Posted by l2r99gst
No baro logged scheides?
No borometer logged, sorry guys.
Remember, just because the MAF shows that the apexi read higher, does not mean that it *actually* reads higher. You'll notice that the afr richens up (as kracka said above) on that filter. Perhaps its a maf scaling issue, perhaps not, who knows.
Old Jan 6, 2009 | 01:45 PM
  #123
eTiLiKo's Avatar
@s2kracka : one question on the Amsoil filter,it is 6" lenght,isn't too much long for a correct clearance under the hood?
Old Jan 6, 2009 | 01:52 PM
  #124
Kracka's Avatar
Ultimately that will come down to your intake pipe, but with the Buschur I believe it will fit. If you also have a Buschur intake pipe and would like me to test-fit it on my car let me know. Otherwise, I suggest just measuring very carefully to be sure you have the proper clearance needed.
Old Jan 6, 2009 | 02:01 PM
  #125
allday10sec's Avatar
nice very good to know
Old Jan 6, 2009 | 02:20 PM
  #126
eTiLiKo's Avatar
Ok,thanks,I have to measure because my idea was to install filter + MAF adapter with the MAF in stock position, because i have a metal intake pipe for stock airbox.
I have no idea if it is possible
Old Jan 6, 2009 | 02:36 PM
  #127
cinek's Avatar
thanks guys for the results....i found my old buschur filter so k&n is going back to the box
Old Jan 6, 2009 | 03:12 PM
  #128
MPACT's Avatar
I don't know if this has been asked already but can you comment on sound quality differences from filter to filter? Like noise levels, tone, etc...
TIA
Old Jan 6, 2009 | 03:27 PM
  #129
Kracka's Avatar
TIA
In they dyno room they all sounded identical with the exception of the small K&N which was making a high-pitched noise since it was obviously struggling to take in enough air. After installing the Perrin foam filter on my car in place of the Vibrant I noticed no change in sound; the turbo inhaling and the BOV venting are still perfectly audible in a nice aggressive manner
In theory I suppose a pad of foam should absorb more sound than a layer of cotton, but in the real-world I don't think the difference is enough to notice.
Old Jan 6, 2009 | 03:29 PM
  #130
Kracka's Avatar
Let me know how much space you have between the MAF and the ACD tank or IC sprayer tank and I'll take measurements of how long the MAF adapter + air filter is.
Old Jan 6, 2009 | 04:44 PM
  #131
Oil Doc's Avatar
Should also work with the Injen Intake seeing they now come with the AMSOIL Filter.
Doc
Old Jan 6, 2009 | 09:11 PM
  #132
wizzo 8's Avatar
You have a picture of a generic filter but its not tested
Old Jan 7, 2009 | 04:39 AM
  #133
Kracka's Avatar
It would not fit any of the adapters I had available.
Old Jan 7, 2009 | 07:56 AM
  #134
Davo's Avatar
with a samco tube, amsoil 4560 works EXCELLENT
Amsoil FTW!
Old Jan 7, 2009 | 09:57 PM
  #135
R0ME0's Avatar
Wish you guys tried out the AEM Dry Flow Filter also.
