5 speed into MR swap thread!
Old Sep 13, 2011 | 09:15 PM
  #91
deeman101's Avatar
Originally Posted by blackenedwings
Anybody else lazy and just left the 6-spd shift knob on their 5-spd swap? I guess its a good thing I don't let anybody else drive my car, because with my luck they would try and catch 6th at speed. :P
Better than putting a 5spd knob on a 6 spd. Can't count the # of times a tech has gone to back my car out of a bay and inched forward instead.
Old Sep 21, 2011 | 07:41 PM
  #92
nytalonTSi's Avatar
Awesome writeup!
I'll be getting the 5 speed swap done this winter.
I was wondering I'm looking to pick up a IX trans, I have an VIII any issue may arise? I understand now I need a IX harness.
Am I better off picking up a VIII trans?
Thanks!
Old Sep 21, 2011 | 11:50 PM
  #93
ticogsr's Avatar
wish i had this thread good luck with everything bros
Old Sep 22, 2011 | 05:12 AM
  #94
B.J.@ToxicFab's Avatar
Originally Posted by nytalonTSi
Awesome writeup!
Thanks!
VIII trans has a longer 3rd & 4th gear....IX trans has a longer 1st gear...
Old Sep 22, 2011 | 08:11 AM
  #95
deeman101's Avatar
And shorter 5th.
And I'm not totally sure but I don't think you need a IX harness for your VIII. The speed sensor and the reverse switch is the same, but the connector that connects to the main harness is different from VIII and IX.
Old Sep 22, 2011 | 09:24 AM
  #96
Originally Posted by deeman101
And shorter 5th.
Correct...
Old Sep 22, 2011 | 10:15 AM
  #97
deeman101's Avatar
Correct...
Can you tell I'm in the process of swapping in a 5spd too?
As an aside, if you waited one more week to buy Chris's trans it would have been mine! Heck, 3 more days even lol. Now I have to wait 3+ weeks to ship another trans to shep and basically build the same trans you have now.
Old Sep 22, 2011 | 10:40 AM
  #98
Haha, nice! I'm not even doing my swap soon...Still need to send my non acd t-case out to be built, decide & purchase a clutch plus a bunch of other goodies I am looking into that I will do all at once with the trans...
Old Sep 22, 2011 | 04:19 PM
  #99
deeman101's Avatar
Yup I hear ya. I'm basically building out my whole drivetrain from flywheel to wheels (excluding axels and front LSD). I'm on a short timeline though since my evo is my only car. And I usually average 2k miles driving a month....hard to do with it sitting on a lift.
Old Sep 22, 2011 | 07:11 PM
  #100
nytalonTSi's Avatar
And shorter 5th.
Thanks for the info guys.
So on the 5 speed, the speed sensor and reverse switch are interchangeable between both the VIII and IX? And I could get away using the harness on my VIII MR?
Old Sep 25, 2011 | 06:38 AM
  #101
nytalonTSi's Avatar
Bump.
Are the speedo sensors and reverse switches interchangeable between both the VIII and IX? I'm getting yes and no from different sources.
Old Sep 25, 2011 | 11:30 AM
  #102
CharlieGsanD's Avatar
Bump.
speedo sensor on 5 speed is gear driven, 6 speed is magnetic.
Old Sep 25, 2011 | 04:04 PM
  #103
nytalonTSi's Avatar
I understand that both the speed sensor and reverse switch are different on the 5 speed vs the 6 speed.
My question is are the speed sensors and reverse switches interchangeable between the VIII and IX 5 speed? Different sources are telling me yes and then no. They do look the same.
Old Sep 25, 2011 | 04:43 PM
  #104
TXEvo8chris's Avatar
You guys swapping out from 6 to 5 speed.. Is this because your 6speed gives out?
Is it because of the ratio's? personal preference?
Old Sep 25, 2011 | 07:48 PM
  #105
nytalonTSi's Avatar
I've never been a fan of the 6 speed for starters, dislike the extra gear. And yeah I dislike the short gears.
But mainly because my 6 speed shifted like crap. They have lubrication problems. In racing they over heat and blow 4th. They're also very loud.
