How much power will my setup make [Mega Merge]
depends on dyno brand and octane
What numbers would i be looking at?
ok swo i set a date to get dynoed May 1st, i was wondering to all experts what i may be looking at for tq/hp.
mods:
stock motor
stock turbo
255 walbro
880 injecters
upgraded 3.5 intercooler
ams licp
hallman mbc
cobb intake
3 inch dp
perrin hfc
magnaflow 3 in cat back
grimmspeed bcs (mine was messed up only allowed 14 psi)
most of these parts are not installed yet waiting for a couple days before the tune. i would love for it t be a surprise. but i also wanna know if this tuner is good. a couple people i have talked to said they are great but this is my car.
thanks
Sean
mods:
stock motor
stock turbo
255 walbro
880 injecters
ams licp
hallman mbc
cobb intake
3 inch dp
perrin hfc
thanks
Sean
350+ area
I have a JDM EVO 7 in Pakistan.
I have the following mods installed...
93 octane
8MR Stock turbo
Hks Intake
Hks Carbon TI-Exhaust(with downpipe)
Blitz i-color Boost controller
Walbro 255
Built Block 2.0 ( Carillo Rods and Ross Pistons)
Exedy Twin Plate HD
HKS 272 with BC springs and retainers
ETS 3.5" IC and LP2
what numbers should i expect? and also do i need sumthing else?
93 octane
8MR Stock turbo
Hks Intake
Walbro 255
Exedy Twin Plate HD
ETS 3.5" IC and LP2
500-550 at best I'm guessing though, not that much 2.4l 9:1 data a 2.0 8:1 is commonly 475-525 for reference. This is if you have enough fuel (need twin walbro + PTE 1000cc for 93)
How much will this make on 93:
4g64 block 2.4l
Wiseco 9:1 pistons
Manley H-beams
arp main and head studs
stock 8 head
BC 280 cams
stock 8 intake mani & tb
stock 8 turbo
stock 8 exh mani
megan o2
3" TBE
780cc PTE
Walbro 255
stock ecu w/ maf
31"x12"x4" intercooler
2.5" intercooler piping
Looking to get 350-400whp with this setup at 28psi or so, before i upgrade the fuel system and install kelford 280s and my 6262 setup and go for 600whp+.
4g64 block 2.4l
Wiseco 9:1 pistons
Manley H-beams
stock 8 head
BC 280 cams
stock 8 turbo
stock 8 exh mani
megan o2
3" TBE
780cc PTE
Walbro 255
stock ecu w/ maf
I think you have a good shot at touching 400awhp/400tq which makes for one wicked ride, power everywhere
here's the thread adWRXi 11.5 @ 118 407/404 30psi on e85
https://www.evolutionm.net/forums/ev...404tq-e85.html
4g64 block 2.4l
Wiseco 9:1 pistons
Manley H-beams
stock 8 head
BC 280 cams
stock 8 turbo
stock 8 exh mani
megan o2
3" TBE
780cc PTE
Walbro 255
stock ecu w/ maf
31"x12"x4" (real 4"thick) intercooler
custom 2.5" intercooler piping
custom 2.5" intake
Looking to get 350-400whp with this setup at 28psi or whatever i get away with using sunoco 93 gas.
4g64 block 2.4l
Wiseco 9:1 pistons
Manley H-beams
stock 8 head
BC 280 cams
stock 8 turbo
stock 8 exh mani
megan o2
3" TBE
780cc PTE
Walbro 255
stock ecu w/ maf
custom 2.5" intake
I edited my post as it was a little deceptive. As i will be going with a 6262 in the future. I was seeing a full boost of 22psi around 2700rpm on the stock 4g64 i had with the SOHC. How much will a 10.5 hotside help hold the boost?
I don't think the 10.5 is going to make enough difference to warrant the amount of work to install it.
spoolup will be incredible!!!
