How much power will my setup make [Mega Merge]
Old Oct 25, 2010 | 06:31 PM
  #466
Ckjeepin's Avatar
Originally Posted by Mellon Tuning
I really don't like the fuel setup, a single walbro isn't going to be able to keep the fuel pressure up. I highly recommend upgrading to the BR twin pump kit and go ahead and do the fuel rail since they are cheap. Then you have the potential for 500+awhp depending on how far you want to push the fp black. I've seen a trend where people couple huge injectors with a single walbro and that's okay for some hp levels but may cause a funky fuel map at high boost high hp levels.
Money ran out.. Need moar funds.
Old Oct 26, 2010 | 11:13 AM
  #467
Mellon Racing's Avatar
donate plasma
Old Oct 27, 2010 | 02:49 PM
  #468
PITCHBLAK9's Avatar
Need an answer quick. Just had a new Injen Intake and intercooler kit put on my Evo IX. The guy didn't tune it. I had a tune from 3 months ago running 21.8lbs boost on Injen full TB exhaust, walbro 255, and halman pro. Do i need a tune for my new kit to work? Is it bad for my car not getting it tuned? He said I dont need one. I currently have rough idle i didnt have before. :-/
and if not how much HP will i have from 299hp?
Old Oct 27, 2010 | 02:59 PM
  #469
yes you do, changing the intake can often drastically change the way the maf reads...hence the idle problem. You could put your old intake on to check the theory.
Old Oct 27, 2010 | 03:06 PM
  #470
PITCHBLAK9's Avatar
Thank you! One more question? could I turn up my boost and approximately how far? Rough estimate for what i can expect mabe
Old Oct 29, 2010 | 10:12 AM
  #471
MrHouse's Avatar
What can I expect from the following setup
Stock block Evolution 8
HKS 280 cam, springs and retainers
AMS 35r Turbokit
BR Street core FMIC with upper and lower IC pipiing
AMS F1 intake manifold
Boomba throttle body
HKS hi-power exhaust
1200cc injectors
Walbro fuel pump
Old Oct 29, 2010 | 01:38 PM
  #472
I don't recommend raising the boost without logging/tuning to ensure it's safe to do so.
Old Oct 29, 2010 | 01:39 PM
  #473
most of my customers get 475-525awhp with a 35R on 93 octane, the tb and f1 intake make push that up a little. A bigger cam would help too.
AMS 35r Turbokit
1200cc injectors
Walbro fuel pump
Old Oct 31, 2010 | 03:44 PM
  #474
avo3vom's Avatar
How Much Power?
Current:[LIST=1][*]Open Intake Filter[*]TBE Straight Through[*]MBC[*]Walboro[*]CBRD Tuned, 302 HP, 293 TQ, 24 psi, Mustang Dyno
Next:[LIST=1][*]PPI Extreme Ported OEM Exhaust Mani[*]Perrin FMIC[*]Map 02 Dump[*]Retuned
This is a IX SE, would like feedback on both Mustang and Dynojet #s, thanks.
Old Nov 7, 2010 | 06:59 AM
  #475
navysandsquid's Avatar
Ok so I made some Big Mods to my setup need new opinion. It's in the Shop now
MAP 2.4 Stage 2
MAP Stage 1 Head
Kelford 272
E85
Stock ECU
FP BLACK
Buschar Double Pump
MAP HP 8740 Head Studs
FIC Blue Max 1450cc
ARP Main Studs
Supertech Valve springs/retainers/Valves
Vinshu Cam gears
HKS DII Ignition
Zietronix o2/boost/egt
Forge Unos MBC
ETS 3.5" Intercooler
injen intake/intercooler piping
XSPOWER TB Exhaust
Forge Rs BOV
ACT HDSS TTP 6 Puck
JACKS TRANSMISSION Rebuild
How much and opinions?
Old Nov 7, 2010 | 07:02 AM
  #476
tscompusa2's Avatar
MAP 2.4 Stage 2
MAP Stage 1 Head
Kelford 272
E85
Stock ECU
FP BLACK
Buschar Double Pump
FIC Blue Max 1450cc
ARP Main Studs
Vinshu Cam gears
HKS DII Ignition
Forge Unos MBC
XSPOWER TB Exhaust
Forge Rs BOV
ACT HDSS TTP 6 Puck
which fuel? e85? 500whp+ easy.
Old Nov 7, 2010 | 07:13 AM
  #477
BLKCarbonEVO's Avatar
I agree with Tscomp, however you should be able to get 600.
btw are you are LR2.4?
Mikey
Old Nov 7, 2010 | 07:47 AM
  #478
n2oiroc's Avatar
10:1 long rod 2.23L 4g64 with 94mm crank
headgames race head
custom cams
Intake
Total Duration 274
Duration @ 1mm 236
Peak Lift 12mm
Exhaust
Totan Duration 274
Duration @ 1mm 236
Peak Lift @ 11.7mm
driven innovations large plenum intake
full race t4 twinscroll manifold with 1.05 a/r ts efr 83/74d (79 lb compressor)
aem series 2
double pumper
fic 2,150's
ets 4" ic
etc.....
93 and e85.
Old Nov 7, 2010 | 08:35 AM
  #479
tscompusa2's Avatar
headgames race head
custom cams
Intake
Total Duration 274
Duration @ 1mm 236
Peak Lift 12mm
Exhaust
Totan Duration 274
Duration @ 1mm 236
Peak Lift @ 11.7mm
aem series 2
double pumper
fic 2,150's
ets 4" ic
etc.....
93 and e85.
in kill mode 700+
  #480
tscompusa2's Avatar
Mikey
I agree. he should beable to hit around 650whp+ in kill mode.
