How much power will my setup make [Mega Merge]
^ And me...
OP: you will be hard pushed to get 500 (safely) on 93. I think 475 is reasonable with a Black, yes there has been a few to break 500 on pump. I think if I got a Black I would be over 500 on pump with my mods.
However, and yes I'll say it, the MAGNUS v5 would really help you. There has been a few people to make 50+hp with the Magnus on meth,Q, and E85. I think pump the magnus on a black would give you 25+hp.
Also getting larger bump stick would help a lot. That is whats hurting me right now! POS HKS cams.
Mikey
Mikey
Mikey
i would suggest a stand alone, bigger injectors, and run it on e85 and you would pass the 500 mark easily. you probably can make it with your current set up however, just get it done correctly good luck!
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Sorry no meth right now I have a baby on the way so my mods this year have been limited to a new clutch that's it
who feeds you this information? Meth if setup properly is very safe
Originally Posted by RockmanX
who uses meth seriously unless you want to do damage
Care to elaborate as to why not running meth. There are so many people here who have had nothing but success with meth and some of my personal friends too.
To the OP I was looking at your setup in your sig again. The biggest problem or killing factor in your setup is the high flow cat. Get ride of it and put in a test pipe.
I have my current mods in my signature, will I be able to make 500whp safely without meth?
06' MR IX TB
mods:
Greddy Ti-c
Hallman MBC
ARC Forced Induction box
Perrin Down Pipe
Perrin High Flow Cat
ARP head studs
HKS Mivec Cams 272's
1000cc injectors
AMS intercooler
FP Black Turbo
Invidia o2 housing
Reflash by Sean Ivey
06' MR IX TB
mods:
Greddy Ti-c
Hallman MBC
Perrin Down Pipe
ARP head studs
1000cc injectors
AMS intercooler
FP Black Turbo
Invidia o2 housing
I'd make a few changes to increase the likelyhood of getting anywhere near 500awhp.
change the ARC box to a hard intake pipe and cone filter
change the high flow cat to a test pipe
ported bits will help too:
exhaust mani
intake mani
throttle body
larger cams would help too.
Tuners feed me this information if you want to rock with meth thats your business but there are many risks to running it and if your car is set up properly meth will not be needed upgrade your turbo with the proper bolts ons you can get the power your looking for. Meth is just a cheap excuse to blow your motor because you dont want to pay for race gas etc all the time. Again if you want to use it and recommend it thats your business but i for one will never recommend it. Not needed.
