ATTN: FP Red & Black Users - What You Need to Know About Oil
Old Nov 9, 2010 | 09:23 AM
  #196
tscompusa2's Avatar
Originally Posted by Fireballix
Please help me,
i can't get amsoil here in Austria,
what i can get is this:
built motor + fp-black.
is this a good way to go for me?
b. r. ,
Luke
before using that oil send in oil sample to blackstone or someone else in your country dont chance it.
Old Nov 9, 2010 | 09:27 AM
  #197
420a-t's Avatar
Is the Amsoil with the higher zinc better for stock motors than the regular Amsoil?
And, I thought the different weights of oil greatly depend on what your bearing clearances are. And for a stock block car, 30 weight is the best chioce until you decide to change the bearing clearances (built motor)
Thanks
Old Nov 9, 2010 | 09:33 AM
  #198
211Ratsbud's Avatar
I'm running valvoline nsl 5-30. It's yellowed, and the label says balanced with detergent . Is this still good to use on the street ? I don't have a cat , so the nsl portion won't be a problem, just trying to figure out the detergent things..
Old Nov 9, 2010 | 09:34 AM
  #199
tscompusa2's Avatar
ya its safe.
Old Nov 9, 2010 | 03:24 PM
  #200
apagan01's Avatar
Originally Posted by tscompusa
ya its safe.
do i see someting different
Old Nov 9, 2010 | 06:49 PM
  #201
wizzo 8's Avatar
Originally Posted by wreckless969
If you can't order AMSOIL, then VR1 is probably your best bet. It isn't 100% synthetic but it does meet FP's standard for ZDDP. But being a racing oil you will need to change your oil more frequently.
How frequently? 3k miles? 2k miles?
Old Nov 9, 2010 | 06:53 PM
  #202
wreckless969's Avatar
Well I am unsure how much detergant it has if any. I know the AMSOIL Racing Dominator has a minimal detergant package and should be changed after no more then 3k miles. So unless you can figure out for the VR1 I would say 1000 to 1500 miles as I would be iffy about running it longer and not having the knowledge as to if the oil is contaminated or not.
Old Nov 9, 2010 | 07:05 PM
  #203
wizzo 8's Avatar
What about this? http://www.napaonline.com/Search/Det...083_0006411555
Its street legal unlike the NSL and its still synthetic
Old Nov 18, 2010 | 11:13 PM
  #204
wizzo 8's Avatar
Anyone?
Old Nov 19, 2010 | 12:15 AM
  #205
BEISSEN's Avatar
Im going to run the Non synthetic 10w30 Valvoline VR1 Racing oil as its listed in the Appoved oils from FP as other non synthetics are so I am assumeing this is ok. This comes in a Silver Bottle and has a high zink and phosphorus count and its higher then the Amsoil 10w40 AMO.
Here is what I have a case of now.
http://www.valvoline.com/products/co...ng-motor-oil/6
Old Nov 19, 2010 | 12:33 AM
  #206
BEISSEN's Avatar
Anyone?
If you look at FP's list of appoved oils in yellow my understanding is that the Non and the Synthetic are appoved due to the Zink and Phos count being high. The NSL is fine but what you showed is the VR1 Synthetic no the NSL as NSL=Not Street Legal and don't ask what that means I have no clue. There are several VR1 Racing Oils Non,Syn and NSL. I got a case of the Non and I am going to run it unless brian from FP tells me I can not lol. Then I will spend the extra money but I think I have the hook up if it was Synthetic from my frined who works at advance and I will pay bucks no 8.13 at Napa's rip off prices.
Old Nov 19, 2010 | 12:34 AM
  #207
The problem with the VR1 doesn't say how much detergent is in it so I am wary of running it for even 3k miles. I have the VR1 in my car now but will be changing it as soon as I get back to the states and putting the RD 15w-50 as it has enough detergents to last for 3k miles.
Old Nov 19, 2010 | 12:39 AM
  #208
BEISSEN's Avatar
I dont plan to run it more then maybe 2-2500 at max basiclly every 2 months change my oil as I can get a case of the VR1 at 60 bucks a case of 12 so it will be ok not a bad deal compaired to mobil 1 at 25.00 for a 5 qt jug times two is 50 plus as another 15 bucks for 2 more quarts and wala I save a few bucks. It was 82.75 over night for a case of valvoline and 2 purolator filters PL14610 so two oil changes for right over 40 bucks each. If you would stop playing with camel spiders you might be able to do better research lol HOOOAH.
Old Nov 19, 2010 | 12:43 AM
  #209
I did do research thats why I am only gonna put 100% synthetic in my car.
Old Nov 19, 2010 | 12:46 AM
  #210
BEISSEN's Avatar
Im sure you have as I am just going to change more often as I would with synthetic as well so why spend the extra $$$ if not need when on a stock motor. You have a 2.3 and need a bit more protection then I do lol.
