Some current oil analysis info, ongoing testing.
Old Mar 27, 2013 | 05:34 PM
  #241
Raptord's Avatar
One more analysis from me. Amsoil ZROD 20W-50
Attached Thumbnails Some current oil analysis info, ongoing testing.-2012-12-10.gif
Old Mar 29, 2013 | 05:51 PM
  #242
TommiM's Avatar
What oil was tested on that last one?
Old Mar 29, 2013 | 08:37 PM
  #243
Raptord's Avatar
Sorry, forgot to mention it.
Oil was Amsoil ZROD 20W50.
Old May 6, 2013 | 10:01 AM
  #244
cerevo's Avatar
I'd love to see some result of any of the Rotella oils. I've read great things about them on other forums for racing/dailying. I may try it and see.
Old May 6, 2013 | 02:58 PM
  #245
BBC's Avatar
BBC
Motul 300v
Perhaps slightly off topic but I've had excellent experience with Motul 300v. I ran it almost exclusively in my Husaberg 570 dirt bike from Chile to Montana last year. 21k miles and 430 hard hours only changing the oil at double the factory interval on a motor that the factory recommends piston replacement at 90 hours. Runs like new, burns no oil, and only required one valve adjustment.
Old May 6, 2013 | 07:11 PM
  #246
TommiM's Avatar
Motul 300v is a great oil. My only issue is just that its not easily accessible locally. Sure I can order a bunch online, but I like knowing I can go down the street and pick up a quart in an emergency. It is on my list of oils to try for sure though.
Old May 8, 2013 | 08:00 PM
  #247
talonesi95t's Avatar
This is my contribution. Was taken awhile back but anyhow it was Penzoil Platinum 5w30.
Uploaded with ImageShack.us
Old Sep 13, 2013 | 06:53 PM
  #248
Raptord's Avatar
Two more from me.
#1: Amsoil ZROD 5W-30
(These guys even manage to toss in a joke every now and then )
#2: Amsoil ZROD 20W-50
Attached Thumbnails Some current oil analysis info, ongoing testing.-2013-04.gif   Some current oil analysis info, ongoing testing.-2013-08.gif
Old Oct 9, 2013 | 12:20 AM
  #249
KurtVK's Avatar
very good-
Old Oct 9, 2013 | 12:43 AM
  #250
Robe55son's Avatar
I have a few prerequisites that I set forth in order to pull the trigger on a fairly modded one. and SBLVRO hit on a couple...
Old Oct 9, 2013 | 07:46 AM
  #251
TommiM's Avatar
Thanks again Raptord. I will get that updated on the first page.
Old Oct 9, 2013 | 08:08 AM
  #252
Raptord's Avatar
Images don't work...
Old Jan 24, 2014 | 08:26 PM
  #253
TommiM's Avatar
Thanks again for everyone who has contributed. I wanted to post some information on here from my own personal experiences. This is just to put the information out there, I don't have any agenda either way.
I have a build thread here where you can read more on it, but basically I have an oem shortblock with balance shafts deleted, with roughly 60k miles on it, the head was sent out to MAP for a stage 1 treatment, Tomei 270 cams, BC titanium retainers, BC springs, Supertech ss intake/Inconel exh vallves, Topline lifters, kiggly hla.
First initial fill, the shop used Eneos 5w30. here is a video of the car at idle.
This was a cold startup after the car had been sitting all day to make sure everything was cooled down. Yes, the car needs to be tuned still btw.
So next what I did, was changed the oil out. swapped out the Eneos 5w30 , and the denso oil filter for Amsoil zrod 10w30 and a Royal Purple oil filter. I drove the car back home and let it sit overnight to make sure everything was nice and cooled down as before.
Heres the video of idle with the Amsoil. Outside temps were pretty close to both days. Both times the car was pretty much equally cooled down.
Without running it even too much it seemed like just swapping out the oil had helped a lot with the ticking noise. In person it is even more noticeable of a difference. It pretty much is all gone. I think one part of it is due to ENEOS
looked like it is on thin side of a 5w30, similar to when I tried Penn Ultra 5w30.
Old Jan 24, 2014 | 08:34 PM
  #254
TommiM's Avatar
Here is a video of the Eneos 5w30 being drained out. This is with the oil warmed up, oil had maybe 35 miles on it. Reason I wanted to change the oil this early was because its a fresh build and wanted to make sure nothing weird was coming out--Im really ocd for stuff like this. Anyhow here is the oil. The description is wrong, it is actually Eneos 5w30.
Its almost scary how thin this stuff comes out. It had me worried, I had thought coolant got mixed in with the oil but after testing all is well.
Old Feb 9, 2014 | 06:24 PM
  #255
Drew1's Avatar
Z-rod 10-30 attached
File Type: pdf
