New BW EFR Turbo Thread
Old Apr 24, 2016 | 04:01 AM
  #3946
mrfred's Avatar
Originally Posted by SWOLN
Black E had an interesting comment somewhere that made perfect sense in relation to the size of the turbine wheel. Basically, the larger size of the wheel on the 9180 made it more susceptible to breakage, compared to the 9174 or even the 8374. I think it's still a bad omen no matter how you look at it and it sucks. I hope my 8374 stays together after seeing this carnage.
Sorry to say, but an 8374 will do the same thing if pushed. Stay under the prescribed wheel-speed limit.
Originally Posted by spdracerut
It is also a fact that TiAl has much less ductility than Inco and is much more susceptible to impact damage as shown by the FP video.
The issue with TiAl is that it is notoriously difficult to cast and manufacture. As such, you can end up with strength reducing things like porosity and surface imperfections. So, it's my guess with the larger 80mm turbine wheel, they are just having issues getting it to cast properly, probably ending up with pockets of porosity in the middle of the wheel which weaken it significantly (the thicker something is, the harder it is to cast it without imperfections).
Cool info. I imagine that fatigue response also matters. So many possible contributors to the mechanism causing the EFR turbine wheels to grenade.
Old Apr 24, 2016 | 06:34 AM
  #3947
2winscroll's Avatar
S369-SXE also has a different turbine wheel. Still inconnel, but uses a cupped design with more flow even though it is unclipped like the original s366 which is clipped. Like MrFred said if you don't exceed the rated rpm of the turbo it should be all good. thinking about an upgrade too a 369-SXE if I can't get 800 out of the 366.
Good read on SXE
http://www.agpturbo.com/blog/the-bor...n-inside-look/
Old Apr 24, 2016 | 06:37 AM
  #3948
2winscroll's Avatar
369 also has a flow rating of 105lbs, opposed to the 9180's 95lbs.
Old Apr 25, 2016 | 01:16 AM
  #3949
BiFfMaN's Avatar
Originally Posted by mrfred
S
I am thinking Vibration, High speed harmonics inherent with the Ball Bearing design.
All turbos will vibrate at certain wheel speeds, they can be at higher wheel speeds or Low wheel speeds, and sometimes multiplied by engine harmonics.
Old Apr 25, 2016 | 08:07 PM
  #3950
chetrickerman's Avatar
Veteran: Army
The only reason he oversped on the 8374 is because the silicone coupler on the compressor inlet collapsed.
Old Apr 25, 2016 | 08:35 PM
  #3951
x622's Avatar
Again, according to Geoff they haven't blown up any 74mm turbine wheels due to overspeed and it can supposedly it can handle a full 10% overspeed. The only problem is, its just him saying this. He's the same guy that told me that "he'd handle it" just like he did for black e, but 2 months later here I am with no turbo so his credibility is a bit shaky. Now I hear that an 8374 blew up because of a collapsed inlet coupler so...
With this being said, my customer is never going to go with a BW turbo ever again and has an extremely negative taste in his mouth from it. As for me, It looks like I'm going to rip off the 9174 for a custom GT35 with a p trim turbine wheel and a custom extended tip compressor wheel. I don't think it will spool the same as the EFR, but I hope it's close since it's a 62/84 vs a 67/91 compressor wheel and I have more variety with my turbine hotside selection. I know I'll make more power but meh. Just can't do this Bob Wagner support that they got going on for myself or any of my customers.
Old Apr 26, 2016 | 05:21 AM
  #3952
way2qik's Avatar
Originally Posted by RWD4G63
Yes, yes there is. I have held it in my hands. Just because you haven't heard of it yet doesn't mean it doesn't exist. I sell BorgWarners all the time.
Oh, would you look at this:
http://whalenspeed.com/collections/b...1mm-super-core
I stand corrected. This must be quite new. I haven't seen anything else about it.
Do you know when they came out with this wheel?
Old Apr 26, 2016 | 06:51 AM
  #3953
SWOLN's Avatar
nevermind
Old Apr 26, 2016 | 07:44 AM
  #3954
mrfred's Avatar
We're not talking about the same person.
Old Apr 26, 2016 | 08:47 AM
  #3955
spdracerut's Avatar
So the ideal wheel pairing is 9180 which falls between the GTX4088 and GTX4594. I'd venture a guess the GTX4088 is close in power to the 9174; compressor of the 4088 is a bit lower flowing, but the GT40 turbine flows more freeing up the backside. The 4088 has a better wheel speed match for better turbine efficiency than the 9174; or said another way, the wheel speed match/blade speed ratio of the 9174 is poor (again, 9180 is the more ideal sizing) which results in lower turbine efficiency which offsets the response of the low mass TiAl turbine wheel a bit.
Or if you're looking for a high power, low cost option, check out the GTW3884R.
Old Apr 26, 2016 | 11:05 AM
  #3956
x622's Avatar
On my platform I 'm looking for the highest power fastest spool. I was looking at the 4088 too but I have a feeling it'll be pretty laggy.
Old Apr 26, 2016 | 12:40 PM
  #3957
LetsGetThisDone's Avatar
I think everyone is always looking for that within their power goal...lol
Old Apr 26, 2016 | 02:26 PM
  #3958
way2qik's Avatar
Actually, having called Jon and talked with him about this turbo it turns out that it is not a Borg Warner S371SXE turbocharger. John is taking an FMW compressor wheel (or a KTS wheel) and putting it on this S300 chassis. Obviously, he has to machine the cover in order for it to fit. So this is not an SXE compressor wheel inside this turbo.
So, you might sell Borg Warner turbochargers, but you will not sell this particular turbo direct from Borg Warner because they don't make it. Since you held it in your hands, that must mean that you work for John there at Waylon speed. I think it's a cool turbo and I really like the idea of putting this 71 mm wheel in this chassis. But you shouldn't come here on the Internet and represent the turbo as if it is a direct purchase from Borg Warner because it is not.
Old Apr 26, 2016 | 02:29 PM
  #3959
Dave W.'s Avatar
I hope you're kidding. The P trim turbine wheel is antique, heavy and not efficient. I tried one several years ago paired with a PTE billett 62mm comp wheel in a ball bearing housing and it was laggy with poor transient response. I compared it against 5 other turbos that year and the one I kept on my car is the 6466. I'm not trying to sell you a turbo, just keep in mind that the newer tech wheels from various manufacturers are worth it.
Old Apr 26, 2016 | 10:36 PM
  #3960
x622's Avatar
I have my same hangups but just want to experiment. I'm next door to Joe @ Locash racing and he has made 940fwhp on that turbo @ 40psi. I'm looking for something with an extended tip that would max out at around 35psi before making contact. I'm also considering doing a GT40 turbine wheel with a smaller 62mm compressor instead because of how the P-trim turbine wheel works (it's inducer is almost the same size as it's exducer).
