New BW EFR Turbo Thread
Old Aug 3, 2016 | 05:58 AM
  #4231
awhit17's Avatar
Update on 7163 downpipe fitment with the Full-Race manifold. This is a 3" CLR mandrel, fitment is good but close lol
Untitled by Alex Whitacre, on Flickr
Old Aug 3, 2016 | 06:24 AM
  #4232
mrfred's Avatar
that's close. have you considered carefully ovalizing by the ac compressor? for the amount needed to get >1/4 inch clearance, there would be negligible change in x-sec area.
Old Aug 3, 2016 | 06:58 AM
  #4233
mrfred's Avatar
Originally Posted by Brianawd
I will be doing a rewire on the pump tomorrow using 10ga with a 30amp relay and 20amp fuse. I already have a fuel lab fpr so I don't have to worry about over running the fpr.
no fpr will save your fuel system from overrun with a full voltage hardwire of that pump, not even with a drilled siphon. it flows way too much for the stock return line. overrun will be massive. fuel may even leak from the spring clamp connections on the return line.
the solution is to create a boost-activated circuit that is spliced into the factory wiring. so rather than cut the factory powe wire at the pump power plug, do a manual mil spec splice or a use a high quality, high amperage t-splice to join your power to the factory power wire. ok to cut off the factory ground if you want, but could splice that too. then add a high quality boost-activated pressure switch to your power circuit. spoolinup.com sells very nice pressure switches and may be able to help with sourcing a suitable splice. the ignition-activated relay can be eliminated from the circuit if you want to maximize the voltage that the pump sees (even very high quality cube relays steal about 0.2 V at high current.) set pressure switch to 8 psi.
if you do this and have no intention of running higher base fuel pressure, you can return the aftermarket fpr and save money. (the factory fpr actually regulates very well.)
also, go with a 30 amp fuse. the w450 can draw more than 20 amps at high load.
Old Aug 3, 2016 | 06:59 AM
  #4234
RalliartRsX's Avatar
That is tight..........did you not go with the full race downpipe??
Old Aug 3, 2016 | 07:31 AM
  #4235
Brianawd's Avatar
The fpr is already on the car. It was a left over part off my galant vr4 after I parted it out.
I'm a little lost as this is the same set up I have used in the past in ref to hard wiring the pump. In my vr4 I ran this same set up with a 255 then added a 044 inline and -8
Feed line. I used the stock return and never had a issue. Both were rewire. The vr4 had a smaller return like then the evo does. So am I missing something on the evo. I was planing on just running this set up for a short time then adding -6 feed and using the stock feel line as the new return.
Old Aug 3, 2016 | 07:37 AM
  #4236
awhit17's Avatar
We have thought about it, but clearance is about 1/4 inch currently so I think it will work well. Just need to put some heat shielding around the compressor. It is not off the table though.
No, I'm having this one custom made. I really like Origin's work. I want to see the Full-Race one for comparison though - I bet it is almost the same because according to my fabricator a 3" CLR bend is one of the tightest you can get, and the Full-Race one uses a mandrel if I am not mistaken.
Old Aug 3, 2016 | 07:55 AM
  #4237
mrfred's Avatar
If the base pressure is set now and you know your fuel trims, you'll know soon enough if there is overrun at idle/cruise. I'll be curious to know. One last comment is that your fuel pump will run cooler and last longer with a dual/multi-voltage configuration.
Old Aug 3, 2016 | 09:46 AM
  #4238
Looking @ the FR site, not much on the FR downpipe as well
Old Aug 3, 2016 | 09:52 AM
  #4239
RJones's Avatar
Update on 7163 downpipe fitment with the Full-Race manifold. This is a 3" CLR mandrel, fitment is good but close lol Untitled by Alex Whitacre, on Flickr
Ooh. Now I'm glad my car has no AC.
Old Aug 3, 2016 | 10:49 AM
  #4240
Dallas J's Avatar
Veteran: Army
There has been very few times an Autocrosser has said "I'm glad my car has no AC" while sitting out on the tarmac in 90+ deg ambient weather...
Old Aug 3, 2016 | 03:09 PM
  #4241
kikiturbo's Avatar
I wonder why they did not move the turbo bit more..
Old Aug 3, 2016 | 04:03 PM
  #4242
Brianawd's Avatar
I don't know how that would be the case as its been proven over and over on dsm's that running a large high volume pump or pumps rewire with a after market fpr Provents over run.
Just a FYI got the 450 installed base fuel pressure is the same with and with out the rewire. I tested it today. With factory wiring I'm seeing 43psi with the vacuum line disconnected. I then ran a line from the battery to the pump to test. With the pump getting 13.9v I still have a solid 43psi of base fuel pressure
Old Aug 3, 2016 | 04:19 PM
  #4243
Brianawd's Avatar
Old Aug 3, 2016 | 06:11 PM
  #4244
RJones's Avatar
Interesting... When I installed my 450 with the rewire a couple years ago I was seeing something like 70psi base until I drilled out the return siphon in the pump housing to get it back down to 45-47psi.
Old Aug 3, 2016 | 06:22 PM
  #4245
Brianawd's Avatar
Being a old school DSM guy one of the first things I did to my evo was a modded 255 and a fuel lab fpr. DSM would get over run with anything larger then a stock pump. So when you upgraded pump you upgraded FPR
