EVO 11.5 Hotside, anybody try it?
Old Aug 2, 2011 | 03:58 PM
  #286
wshihdnevo's Avatar
Originally Posted by Guerillah
What kind of boost control problems you having?
They started a month ago before the install. I need to do a boost leak test. I couldn't make over 20 psi on the dyno. Still made 350 at 20 psi though. I checked the puck on my housing and when it's full open it didnt hit anything on my O2 housing.
Old Aug 2, 2011 | 04:08 PM
  #287
mrfred's Avatar
I ask because I just received my 11.5 housing and the puck comes out quite a bit from the housing, I am wondering if it will have interference issues with O2 housings. .
Another thing I noticed, it has A3N cast on the housing. A little research turned this up....
http://www.cbmm.com.br/portug/source...s/pdfs/053.pdf
Nice find. Looks like its a cast stainless steel with higher Cr and higher Ni content than 304 SS. Interesting.
Old Aug 2, 2011 | 04:56 PM
  #288
Guerillah's Avatar
Checked clearance on my map o2 eliminator, and the puck does indeed clear. The turbine outlet is larger by 2mm on this casting compared to the stock 10.5, I have to grind my o2 housing gasket in order to not obstruct flow. The wastegate ports are much larger as well (more area pressing against the wastegate), as previously mentioned.
Old Aug 2, 2011 | 05:25 PM
  #289
Guerillah's Avatar
Maybe a good candidate for extrude honing? The A3N seems highly tolerant to heat/cracking.
Old Aug 2, 2011 | 06:56 PM
  #290
mrfred's Avatar
Less likely to crack but it seems a bit dicey for what final product might come out of it. Some parts of the scroll might get heavily worn (e.g., scroll exits) while other areas may not.
Old Aug 2, 2011 | 07:13 PM
  #291
211Ratsbud's Avatar
We as a group should contribute to a grand test ie b2b on dyno.. I have reservations about it being legitimate a3n...
Old Aug 2, 2011 | 07:28 PM
  #292
Guerillah's Avatar
Someone should weigh the two as a comparison. I would, but lack a scale.
Old Aug 2, 2011 | 07:38 PM
  #293
Fast_Freddie's Avatar
Veteran: Navy
Someone should just get results first LOL
Old Aug 2, 2011 | 08:23 PM
  #294
wshihdnevo's Avatar
Wish I could...
Old Aug 2, 2011 | 08:33 PM
  #295
Veteran: Navy
I know bro...
Old Aug 2, 2011 | 08:42 PM
  #296
211Ratsbud's Avatar
Lol, I'm screwed my 10.5 is cracked severely. My 11.5 is going on the white being upgraded to a 71hta cause the white is not enticing enough for robert to do ..
Old Aug 3, 2011 | 09:02 AM
  #297
Guerillah's Avatar
Weighed both housing at work on a UPS shipping scale...
OEM 10.5cm - 10.8 lbs
ebay 11.5 - 9.6 lbs
I won't be able to do a before and after dyno, I have added this housing, a FP FAC compressor cover, FID tubular manifold, 4" intake and converted to speed density since my last dyno. Sorry.
Old Aug 3, 2011 | 09:29 AM
  #298
killerpenguin21's Avatar
^^^im still interested in dynos on your setup. i was thinking of doing something similar.
Old Aug 3, 2011 | 10:08 AM
  #299
Guerillah's Avatar
I'll be sure to post it up, although it won't be until its colder out. Its 100+ degrees here right now with 50% humidity, horrible.
Old Aug 3, 2011 | 10:31 AM
  #300
Aby@MIL.SPEC's Avatar
Originally Posted by fast_freddie
someone should just get results first lol
+1
