Modification Regrets?
Old Oct 18, 2014 | 09:52 PM
  #916
EVIL_EV0's Avatar
I 100% regret getting a built block. These things are nothing but nightmares. What a PITA to have to wait for it to warm up. They make all kinds of noise you are always worried about them grenading due to possible crappy build.
Unless you have plans for 500whp there is no reason at all to go with forged pistons.
Old Oct 19, 2014 | 10:11 AM
  #917
ODUB's Avatar
If you went to a reputable shop, you shouldn't have to worry about build quality. Also, sorry to break it to you, but the stock pistons are forged.
Old Oct 19, 2014 | 02:16 PM
  #918
d-bo's Avatar
You should bring it up to temperature before doing anything whether your motor is built or not
Old Oct 30, 2014 | 09:11 PM
  #919
AnabolicEVO's Avatar
Fact!!! Especially if you care anything about your car's engine lasting a long time.
Old Oct 30, 2014 | 09:27 PM
  #920
Sorry sir you're probably confusing it a bit. The U.S.-specification Evo's 4G63T has a revised and reinforced cast iron block filled with a reciprocating assembly consisting of a durable forged steel crankshaft, and 150 mm forged steel connecting rods, but the cylinders are filled with (8.8:1) compression ratio CAST pistons that are made out of a durable, lightweight AC8A (T6) aluminum designed to withstand forced induction cylinder pressures for an extended period.
Old Oct 31, 2014 | 09:35 AM
  #921
wjamyers's Avatar
I disagree with "anything". With the stock block, I start it up and give it few seconds to stabilize (S2 cams and an iffy aftermarket IAC means that in cold weather it may stall in the first minute).
But then, once I can tell it's stabilized, I just drive it gently (the car warms up faster this way and you're not adding significant wear) until it's up to temp.
Then I get on it.
Old Oct 31, 2014 | 12:42 PM
  #922
d-bo's Avatar
Yeah I shouldn't have said anything lol. I usually warm mine up anywhere from 30 second to a few minutes depending on temp and if it's a true cold start, just cuz. But I don't do any spirited driving until after the oils are fully warm to the temps they should be.
I see some people start their car up and just go WOT out of their driveway in the morning lol
Old Nov 2, 2014 | 11:05 PM
  #923
Grimgrak's Avatar
Just means it's not been modified enough
Originally Posted by Yuta
Modifying the car has been my biggest regret now that I am looking to move on to a different platform.
Old Nov 6, 2014 | 09:26 AM
  #924
sumopower87's Avatar
Regret getting rid of my OS Giken Twin plate clutch it died peacefully. This clutch worked and held for as long as it lived
Regret buying the ACT clutch that walked my crank not once but twice.
Regret buying a clutch masters clutch as I've had nothing but mixed emotions with this clutch.
So...I'm just going to suck it up and spend the cash to get me another OS Giken TS2B Twin plate clutch
Old Nov 6, 2014 | 12:21 PM
  #925
roach85's Avatar
I regret buying a QM 8 leg for daily driving in Chicago traffic. 15,xxx miles and left me stuck on the highway yesterday. LOVED the clutch just not the life span, daily driving killed it.
Old Nov 6, 2014 | 02:35 PM
  #926
d-bo's Avatar
I was worried about the life span but if I get that much I will b happy. Chi has much worse traffic than us probably and I avoid rush hour at all costs lol
Old Nov 12, 2014 | 12:25 PM
  #927
aregevo's Avatar
Not doing any!
Old Nov 17, 2014 | 12:33 PM
  #928
esad678's Avatar
the quarter master 8 leg is not for a daily haha
Old Nov 19, 2014 | 01:30 AM
  #929
roach85's Avatar
I actually probably would have gotten 30,000 miles total. The disc themselves had plenty of life left, it was the hub on the discs that wore out. The teeth wore out to almost smooth. Was just spinning on the inputshaft. Might not seem like an ideal clutch for daily but after you get used to the engagement it truly is amazing. I have a single disc in now and miss my twin more than I thought I would
Old Nov 22, 2014 | 03:16 AM
  #930
EvoTurboTurk's Avatar
How much power you putting down & whats it like driving with them?
