E85 vs 93
Old Feb 24, 2011 | 06:18 PM
  #91
Jedi_Gill's Avatar
FCOTM Winner
Since you guys are curious about the E-85 Vs 93 pump difference.. Here is a Dyno Graph of my car with 612 HP VS 443HP on a FP Black. With subtle work done to the engine. This was actually done on E-70 not E85 as the weather in chicago prohibits me from finding any E-85.
https://www.evolutionm.net/forums/ev...tang-dyno.html
Old Feb 24, 2011 | 06:23 PM
  #92
KJS1820's Avatar
I ran E85 last year and loved it! I just wish it was closer to me! I drive 60 miles and fill up 8,
5 gallon cans every 2 weeks but the power is worth it imho I detuned to 25 psi on 93 for the winter since traction sucks in the cold weather. I will change back when it warms up outside!
Swapping back and forth it easy no need to drain the tank BUT when going to 93 turn down the boost and have a alternate map! The car may run a bit weird but a tank or two will get right! Then when going back to E85 or whatever blend you have run a couple tanks through before beating the **** out of the car again!
Another thing is most of you guys know (but a few don't)is E85 is SUPPOSED to be 85% ethenol and 15% gas BUT one station may have a different blend than the guy down the road! So mixing e85 and gas isn't a problem as long as your tune matches the fuel
Old Feb 25, 2011 | 12:32 AM
  #93
bigst1er's Avatar
How many PSI do you guys run on a stock IX turbo on E85?
Old Feb 25, 2011 | 07:14 AM
  #94
cheb evo's Avatar
Originally Posted by SmurfZilla
ANd the junk isn't from the gas....its from the gas cleaning out the gunk in your fuel system already,
The gunk is from the additives that some stations still add to their E85, which is required with 93 octane, but not required with the E85. Check out the thread in the alternative fuel forum concerning injector "gunk" and the causes behind it. If the gunk was based solely on the E85 cleaning out all of the carbon build-up, etc. in the fuel system, everyone would have this gunk buildup on their injectors...which simply is not the case.
Old Feb 25, 2011 | 08:21 AM
  #95
SmurfZilla's Avatar
Thumbs up
Originally Posted by tsidrift1
I know I can make more power if I want out of the turbo. Im still on stock block right now. So im not pushing any limits. A core charge is too expensive to be playing with a ticking time bomb. Thats why I am saying that my goals with the car, powerwise are where I want them. I can do the same numbers with 93 octane and a tune. So I am gonna go for it and ditch the e85 for now.
Now, if I get a built block, or decide to just run this block till it dies, I would go with e85, cause then my goal is just more power, for now, I am happy with what I got. As its a nice safe limit that I can still have a lot of fun with.
Considering what I'm going through now I completely understand
Old Feb 25, 2011 | 08:24 AM
  #96
SmurfZilla's Avatar
When I was on stock turbo I ran 28.5 PSI
Old Feb 25, 2011 | 08:25 AM
  #97
SmurfZilla's Avatar
Thank you for the correction. I was wrong.
Old Feb 25, 2011 | 09:27 AM
  #98
bigst1er's Avatar
Thanks!
Quicks916
E85 / Ethanol
16
Sep 13, 2012 06:22 PM
Alpha X
Pacific Northwest
15
Jun 6, 2012 05:28 PM
Silversmasher8
Jan 31, 2012 06:27 PM
vplukas101
23
Mar 17, 2011 06:30 PM
BCOZEVO
12
Oct 19, 2009 09:02 PM
