View Poll Results: Choose which ones will influence your decision
Wow, 300hp, 300 ft-lbs from 2.5L Subaru boxer engine
152
22.25%
Proven tuning potential of the Mitsubishi 4G63
355
51.98%
Subaru\'s strong 6-speed manual tranny
138
20.20%
Mitsubishi\'s dependable 5-speed tranny
109
15.96%
DCCD on the STi... wish Evo had ACD
132
19.33%
Stock FMIC on the Evo
164
24.01%
Exterior looks
305
44.66%
Interior quality
148
21.67%
Gross Vehicle Weight
79
11.57%
I want to test drive both before deciding
165
24.16%
Price
261
38.21%
Body Shell Rigidity
133
19.47%
Brakes
163
23.87%
0 - 60 mph and 1/4 mile times
201
29.43%
Multiple Choice Poll. Voters: 683. You may not vote on this poll
Evo vs. STI | Anything and Everything [ALL THREADS MERGED]
Old Dec 30, 2002 | 07:23 AM
  #241
KK's Avatar
KK
EvoM Administrator
We're just going to have to wait for the Evo and Sti to arrive before we jump the gun and compare our versions of these cars (which are the ones that matter).
Mark
Old Dec 30, 2002 | 12:24 PM
  #242
BoxerSTi's Avatar
Originally posted by Claudius
Andy, they arent. Although the turbocharged version you mention has good torque, boxer engines are inherently torque weak. Just look at NA Porsche specs.
Then can you tell us why Porsche, Ferrari and some F1 formula car use Flat layout? If I give you some example of I4 engine's torgue, are you going to change your mind?
Numerous Subaru WRX STIs in Europe (LHD versions) blow their engines. There's a problem with the map in the ECU. I wouldnt call that reliable...
Where you get this info? We know Subaru have trans problem, but EVO got its overheat problem too, but both car have great engine.
Old Dec 30, 2002 | 12:32 PM
  #243
BoxerSTi's Avatar
Originally posted by astondg
Finally many of the STI's racing out here have weak gearbox's that need to be rebuilt after every event, or replaced with a racing box. Reliable?
I m sure the STi 6 speeds trans is stronger then the EVO 5 speeds tran. and i own 2002 WRX for almost 2 years, no problem at all. By the way, my friend bought a 2000 eclipse GSX when it was brand new, 2000miles later, moonroof leak, less then 2 years later, tranmission leak, then he got so upset with the car and sold it. But who know, the EVO is going to be made in japan, i hope is going to be more reliable.
Old Dec 30, 2002 | 12:55 PM
  #244
HobieKopek's Avatar
That'd take some doing because the GSX's last year was '99 and in '00 they went to the V6. I guess it was a '99 or the new fish-styled GT?
I'm with the more or less equal thing here. It's not that Mitsubishi or Subaru lack the technology to one up each other or to have one build a better car than the other, it's that they both have the same/similar restrictions for production cars. That means they try to use every bit of the limit to its fullest and keep both driving and prices competative. I dunno if I stated that clearly, but I think most of you get my drift.
EDIT: And ask Andy (BADWRX) about his WRX tranny. I don't think you'll find that you had similar experiences.
Old Dec 30, 2002 | 01:06 PM
  #245
BoxerSTi's Avatar
Yeah, my bad, it was a 99.
Old Dec 30, 2002 | 07:28 PM
  #246
sblvro's Avatar
please enlighten me, do ferrari and F1 race cars have boxer engines? i do know the old VW beetle have boxer engines.
Old Dec 30, 2002 | 07:54 PM
  #247
BoxerSTi's Avatar
http://www.scudi.com/dalia312TEngine.html
Old Dec 30, 2002 | 08:13 PM
  #248
sblvro's Avatar
hmmm, good point, there were some ferrari engines with flat engines, the last one was the testarrosa but even before they started racing, the V12 and V10 were their engines. if you look at ferrari.com, those were yesteryears engine. V10 and V12 have been their staple, why is that??
Old Dec 30, 2002 | 08:17 PM
  #249
evo_dan's Avatar
That is a very old engine.
Old Dec 30, 2002 | 08:18 PM
  #250
sblvro's Avatar
my point exactly!
Old Dec 30, 2002 | 08:35 PM
  #251
BoxerSTi's Avatar
Yes they are, and i just kinda did a simple yahoo search for it, didn't really look into it. But we all know Porsche is still using Flat layout and is not something old. However, i don't recall Prosche or Ferrari use an I layout engine.
Old Dec 30, 2002 | 08:39 PM
  #252
BoxerSTi's Avatar
here is a link that tells you where flat engine has its advantage.
http://www.subaru-global.com/about/awd/3300/index.html
Old Dec 30, 2002 | 09:21 PM
  #253
evo_dan's Avatar
The example for the inline engine is not completely honest, because for every cylinder going up, there is also one going down. Their example would only be true if it was a one cylinder engine.
Old Dec 30, 2002 | 09:25 PM
  #254
evo_dan's Avatar
I forgot to add, I do see the advantage of the lower center of gravity for the boxer engine.
Old Dec 30, 2002 | 09:45 PM
  #255
BoxerSTi's Avatar
The key here is "Are the cylinders going up and the cylinders goind down creating same weight? No, it isn't. "I" layout engine's cylinders doesn’t nessesory have equal weight going up and down at the same time which will cancel each other out, but the Subaru Flat layout does. And yes you are right about the lower center of gravity for the boxer engine.
http://www.subaru-global.com/about/awd/1200.html
