View Poll Results: Choose which ones will influence your decision
Wow, 300hp, 300 ft-lbs from 2.5L Subaru boxer engine
152
22.25%
Proven tuning potential of the Mitsubishi 4G63
355
51.98%
Subaru\'s strong 6-speed manual tranny
138
20.20%
Mitsubishi\'s dependable 5-speed tranny
109
15.96%
DCCD on the STi... wish Evo had ACD
132
19.33%
Stock FMIC on the Evo
164
24.01%
Exterior looks
305
44.66%
Interior quality
148
21.67%
Gross Vehicle Weight
79
11.57%
I want to test drive both before deciding
165
24.16%
Price
261
38.21%
Body Shell Rigidity
133
19.47%
Brakes
163
23.87%
0 - 60 mph and 1/4 mile times
201
29.43%
Multiple Choice Poll. Voters: 683. You may not vote on this poll
Evo vs. STI | Anything and Everything [ALL THREADS MERGED]
Old Dec 31, 2002 | 04:34 AM
  #256
sblvro's Avatar
Originally posted by BoxerSTi
here is a link that tells you where flat engine has its advantage.
http://www.subaru-global.com/about/awd/3300/index.html
those pictures are misleading, the in line or I engines have counterweights in the crankshaft that there is no movement in the horizontal plane as the picture tries to project, the same thing with the V engines. The flat motor mislead everybody by looking at the horizontal plane but if you look at the vertical plane, there should be some movement. the flat motor doesn't have a straight crankshaft! the only advantage i see is the low center of gravity, that's it.
Old Dec 31, 2002 | 04:41 AM
  #257
TOMMY B's Avatar
BoxerSTI,
Why ????? For what are your reason being on this board ? We all know you like Subaru's better then , There are pro's and negatives for both, So stop beating the dead horse !! Its fine to talk about the differents of both cars, But to say one of the two cars is totally deficient is plain foolish both cars are very good. Both cars have benefited from each other. I'm just happy that we are going to have both cars here in the U.S.A. Its all Good !!!
RALLY ON ////////////////////////
Old Dec 31, 2002 | 05:47 AM
  #258
sblvro's Avatar
Old Dec 31, 2002 | 06:29 AM
  #259
HobieKopek's Avatar
BoxerSTi has as much a right to be here as anyone else so long as he follows the rules...which he's done. He has brought up some valid points. What's wrong with a little argument/discussion? I'm a sucker for a nice boxer engine. Once I pay off the Lancer I think I'm picking up an older 2.5RS.
Old Dec 31, 2002 | 10:41 AM
  #260
BoxerSTi's Avatar
Look at this and you can see only Flat layout's engine will creat equal weight from left and right cylinders at the same time WHICH with cancel each other so there is no vibration.
http://www.subaru-global.com/about/awd/1200.html
Quote from Subaru.co.jp
Because the opposed pistons mutually counteract vibration and give superior balance. This results in smoother engine performance throughout all speed ranges - with no need for a balancer shaft - as well as giving unparalleled response to the driver.
The next advantages are the size and weight. Obviously, the Horizontally-Opposed piston layout means an engine that is both shorter and lower than a conventional in-line design. In addition, you have a more compact shape, lighter weight and the ability to mount the engine much lower in the chassis. The overall result is a low centre of gravity and balance that cannot be matched with other engine types.
Originally posted by TOMMY B
BoxerSTI,
Well, did i say i don't like the EVO?, I like EVO too and thats why I m here looking for EVO's updates, just because early someone was beating on the boxer engine, there why i m here to explain how it works.
Thank You very much!
Old Dec 31, 2002 | 11:22 AM
  #261
HobieKopek's Avatar
Yeah, I'm still gonna argue that l4's are really well known for their good harmonics esp when turbocharged or in the high revs, but I give the Subaru boxer credit where credit is due.
I do have to say though that a more neutral source (as opposed to directly from Subaru who has a boxer engine in almost every car and therefore a reason to praise them to no end) would probably benefit your cause a bit more. I'm sure there's still plenty of backing info.
Old Dec 31, 2002 | 06:12 PM
  #262
BurnOutz's Avatar
Hey, did you all play their "game" on steering and handling. I think that its extremely exaggerated... the RWD car, even though its going slow, acts as though it always swerves. I don't think the rear tires turn do they?
Old Jan 1, 2003 | 12:08 PM
  #264
BoxerSTi's Avatar
Originally posted by Claudius
From a French Subaru owners club website and from my tuner who sells lots of forged internals to all the people who blow their engines. I think he said 27 cars so far blew.
Are those WRX or STi? Because STi has closed block design which hold alot more HP. By the way, does EVO have closed block design? I think it does but does anybody have a pic of the engine block?
Old Jan 2, 2003 | 05:52 AM
  #265
2GTSiAWD's Avatar
Why do manufacturers leave out a real boost guage? Does it cost that much to put on in instead of a voltmeter or a dummy guage that tells you that you are driving a Lancer? Curious!
Old Jan 2, 2003 | 12:17 PM
  #266
elgorey's Avatar
technically it is semi-closed deck.
Old Jan 2, 2003 | 11:16 PM
  #267
MaxR's Avatar
3300 lbs, "just 80mm longer than VII"?, thats 3 ****in inches. this car is a ****ing boat. if i wanted a mercury marauder I'd buy a ****ing mercury marauder. what a joke. this piece of **** will not be able to beat a stock wrx without weight reduction. its not a sport compact car its a ****ing audi wannabe. see ya mitsubishi, hello lotus.
Old Jan 3, 2003 | 12:28 AM
  #268
RA29's Avatar
Yea, the US Evo8 is quite a joke.
As you put it, a bloated pig and even longer than before.
Although i think the extra 8 cm comes from the bigger bumpers.
Man, the Evo8 is actually 400 lbs more than the Evo6!!
A bit ridiculous.
The WRX is looking more and more intriguing. Much lesser weight, $6k cheaper at least and not that much power difference. 50hp is so easy to make up for with a turbo engine.
Old Jan 3, 2003 | 12:45 AM
  #269
BoxerSTi's Avatar
It should beat a stock WRX, but look for a facelifted WRX with 250HP this summer. It should weight around 3085lbs like last year's model.
Old Jan 3, 2003 | 03:51 AM
  #270
suave3747's Avatar
The weight of the Evo 7 with fluids loaded is nearly the same as the Evo 8's weight. If you removed your spare tire from the car, and installed lighter wheels and a lighter flywheel, you would already lose a good bit of weight, and most of that weight loss would be unsprung. The Evo 8 is going to romp on a stock WRX. It has significantly higher torque numbers and an additional 44 HP. The Evo 8 is still going to compete with the STi. This car is not here to fight the stock WRX.
Here we are posting in the forum for one of the fastest and most moddable cars in the world. One that can be boosted to 300+ bhp and much less unspring weight for less than $5000.
I am sure this car is going to dominate.
