The Official Wide Tire Thread
Old Mar 27, 2012 | 07:47 PM
  #256
Blue91lx's Avatar
Originally Posted by Rondata.
Can anyone help me out or give me any advise. My car rubs on every bump on the highway and is making me nuts. I love my wide tires but I don't know what else to do. I'm running my 04 evo with RPF1'S 18x9.5+15 with 265/35/18 tires. I already rolled and pulled the rears and running camber -1.8 and -1.3 rear on stock springs in the rear and Hotchkis springs in the front. Is there anything I can do other then changing my tire size. Maybe someone can tell me where I can cut my rears but don't know where. Help plzz
I'd like to see some pictures of this setup.
Old Mar 27, 2012 | 07:50 PM
  #257
Rondata.'s Avatar
My computer is down and for some reason I cant post pics using my iPhone. If u want u can send me a email address and I can shot u a few pics.
Old Apr 5, 2012 | 02:35 PM
  #258
PAdutch's Avatar
Alright fellas I need some help from the experts in here. I found a deal on some 18 x 10s with a 28 offset. Im thinking Id like to run a 275/35 tire and was wondering how much it would take to run this. Is the offset to little?
Old Apr 5, 2012 | 02:39 PM
  #259
griceiv's Avatar
Originally Posted by PAdutch
A I found a deal on some 18 x 10s with a 28 offset. Im thinking Id like to run a 275/35 tire and was wondering how much it would take to run this.
a lot of work to fit in the rear.
Old Apr 5, 2012 | 03:07 PM
  #260
n2oiroc's Avatar
what tires? as far as clearance, look here. its rub city and will need a lot of work but it can be done. not an amateur job. look at my post on the top of page 13.
https://www.evolutionm.net/forums/ev...thread-13.html
Old Apr 5, 2012 | 03:52 PM
  #261
hokiruu's Avatar
You're about 10mm too low offset to fit that easily in the rear, and that's all fender. You're going to need the usual roll and or cut, rear bumper bolt relocation, trim or remove front fender liners, trim front fender side of side skirt flange, and PULL your rear fenders a lot. Or use overfenders.
Old Apr 5, 2012 | 03:58 PM
  #262
n2oiroc's Avatar
btw, how do the side skirts come off? im wearing clean clothes and dont want to crawl under to look.
Old Apr 6, 2012 | 09:29 AM
  #263
PAdutch's Avatar
I have my settings amount of post/page setup differently, post numbers work better. Iget that it might be some work.
Well it seems like alot of people rum the rpf1s with a 38 offset and a 5mm spacer in the rear, ending up with a 33 offset. I guess I didnt think the that extra 5mm wouldnt be that much more work.
I dont mind rolling the the fenders but I get nervous when I need to start pulling. I guess I need really think about it. What about running a 265 tire?
Old Apr 7, 2012 | 08:29 AM
  #264
in the red's Avatar
Originally Posted by R/TErnie
your tires are too big in OD , they will rub a lot up front.
You can run the +27's all around with a spacer up front. I think a 10mm. If you run the +38's you'll need a bigger spacer up front (20mm or 25), but I think your rears will fit much easier in the rear.
I run GTC01's, 18x9.5 +38 with 275/35-18 NT555 on all four corners with no fender mods and no rubbing. Lowered on GTWorks springs and stock MR bilsteins with suspension settings recommended by Andrew. I have also ran Toyo T1R's in the same size with no rubbing. FWIW.
Old Apr 7, 2012 | 09:20 AM
  #265
R/TErnie's Avatar
I've ran 18x9.5 +38 NT03's with 265/35/18's and it rubbed on the skirts AND on the pinch weld. that was on OEM shocks/Works springs & Skunk2 Pro-C's & on Ohlin DFV's.
So either you don't turn your wheels, don't turn your car at speed, you're not aware that you're rubbing, or you're full of ****.
Old Apr 7, 2012 | 12:15 PM
  #266
n2oiroc's Avatar
Yeah, i dont see how many of you dont rub. With 255/40R17 star specs, 17x9 +30's on spec r's and i can rub the rear with some hooliganism.
Old Apr 7, 2012 | 01:56 PM
  #267
SWOLN's Avatar
Originally Posted by r/ternie
i've ran 18x9.5 +38 nt03's with 265/35/18's and it rubbed on the skirts and on the pinch weld. That was on oem shocks/works springs & skunk2 pro-c's & on ohlin dfv's.
Amen!
Old Apr 9, 2012 | 10:47 PM
  #268
fightex's Avatar
just put on some 265/40R17 Z1* and love them
Old Apr 9, 2012 | 11:01 PM
  #269
bigboybusa's Avatar
My new setup, 18x10.5 -1offset work wheel meister m1r wrapped in 315x30 615k Falkens
Old Apr 9, 2012 | 11:03 PM
  #270
wshihdnevo's Avatar
Great thread! Hopefully Ill have something to add here in a couple months.
