Anyone know how to update nav firmware?
Old Mar 1, 2013 | 02:24 AM
  #91
chamonix's Avatar
i know that treads is old but thx a lot for the explaination and i will try it as soon as possible
Old Mar 1, 2013 | 02:34 AM
  #92
chamonix's Avatar
''Once the update is done, it will reboot and it'll say update successful and you should have version 9.0.0. Then simply press back until you get back exit that especial menu.''
you said you should have version 9.0.0, but the upgrade was not supose to upgrade us to version 11.0.0???
Old Mar 3, 2013 | 01:34 PM
  #93
chamonix's Avatar
my mistake its because i saw on internet they are at version 11.0.0 so i taught the version evoch3n give to us was 11.0.0
on that website they said we are at version 11.0.0
http://www.mitsubishifuse.com/support.taf?p=7&n=1#howTo
do someone know if we can have the update
Old Sep 14, 2013 | 12:12 PM
  #94
kckid's Avatar
Anyone find version 11?
Old Apr 2, 2014 | 06:00 PM
  #95
tazz33's Avatar
Originally Posted by evoch3n
TSB-11-54-007
Instructions
Prep:
  1. Format the USB to FAT32
  2. Put the update.package file in the root of the USB
Updating:
  1. Turn the car to ON (don't really need to start it up)
  2. DO NOT PRESS BRAKES
  3. Wait for everything to be loaded on Nav.
  4. Plug the USB in with the update.package file in the USB drive
  5. Press and hold set + navi at the same time for about 3-4 seconds
  6. Go to Hands Free Module
  7. Press S/W Update
I forgot when, but at some point it will ask you for a password/code, just input 1234 (in that order).
Instructions for non-nav system WITH USB port:
  1. DO NOT PRESS BRAKES
  2. Turn audio system "OFF"
  3. Press the following in order: CH1 preset Button, |<< (seek down) button, >>| (seek up) button, and then CH4 preset button.
  4. "HFM DIAG" should be displayed on the system, if not repeat previous steps.
  5. turn the volume to 0
  6. press the "CH4" preset again to toggle through the diagnostic functions
  7. then look for any PN lower than 8785A035 or S/W lower than 0900000
  8. Once you see "HFM OK" displayed, press CH3 preset button to toggle back until "HFM DIAG"
  9. Once you see "HFM DIAG" again press "PAGE" button to enter update mode.
  10. To enter the update security code, press CH1, CH2, Ch3, Ch4 in that order
  11. and the update should start updating.
  12. once that's done press "PAGE" button to return to "HFM DIAG"
  13. turn off the ignition and remove the USB flash drive
  14. test to see if it worked.
If all of this didn't work, let me know.
PS: You don't need this update if you don't have a USB port. This update is only for compatibility with iOS 4.0 or higher through the USB port!
File: Download
Ok Im trying this but get no file every time I try it????? I get looking through the exact numbers you put " PN 8785A035 and S/W 0900000" is that wrong or something? Also gives me "H/W 08"? I have tried formatting the USB stick many times now and loaded the file again each time but still get no file?
I have been having problems with my blue tooth cutting out then reconnecting and the iPod worked for a short while then cut out then reconnects and goes back to iPod load again? Help please??????
Old Apr 3, 2014 | 03:32 PM
  #96
tazz33's Avatar
Anyone out there have any idea as to why I cant get the update to work? Please help????
Old Jun 29, 2014 | 12:48 PM
  #97
Rix's Avatar
Rix
Does anyone have the link to download the 11.0 update?
Old Dec 31, 2014 | 08:36 AM
  #98
menace1's Avatar
I just emailed the 2 addresses you provided about the issue too. I have a Note 4 that doesn't work and my gf's iphone doesn't work. It's annoying to spend "x" amount of dollars for the MMCS and not have any support.
Old Jan 23, 2015 | 08:19 PM
  #99
s_lancer_gts's Avatar
i have a 2008 and would love to know how to do it please let me know. please e-mail me
Old Jan 23, 2015 | 08:27 PM
  #100
i have a 2008 and i am need of a upgrade on my navi in a bad way any one able to help???
and in motion for BLD-NR-261um 1.09
Old Apr 11, 2015 | 09:32 PM
  #101
locha268's Avatar
Anyone know the sequence to factory reset the firmware? erasing all existing settings.
I can't seem to be able to delete/edit pairing devices, voice option to delete/edit devices stop at number 6 and drops out.
Old Sep 7, 2017 | 03:01 PM
  #102
will88cr's Avatar
I know this is a very old thread, but does any one have the file to bypass this in an NR-261UM navi sistem I just installed, all the links are very old and dont work
Old Feb 22, 2018 | 08:44 AM
  #103
LGM's Avatar
LGM
bump!
Old Feb 27, 2018 | 04:35 AM
  #104
hichamaziz's Avatar
thank you evoch3n for thread and explain
Old Apr 5, 2018 | 11:13 AM
  #105
RedEclipzeGsx's Avatar
Still looking on where to find the latest update for this. Thanks.
Darunt
Mar 16, 2026 02:44 AM
Mikeyy00
May 28, 2018 01:52 AM
lexa609
Dec 16, 2017 01:05 AM
Jtk0796
Nov 8, 2017 06:40 PM
8three
Lancer Troubleshooting
Jun 20, 2016 12:12 PM
