Factory reflashes, hesitation, stalling, and everything you need to know [merge]
Old May 1, 2008 | 02:29 PM
  #391
kimletrim's Avatar
Registered User
Originally Posted by Steve@NrgTech
i got 230 miles to a full tank after the flash whereas before i wasnt even hitting 190
I will concur with the above statement.
Before the flash, I barely got 190 miles on a tank (meter was completly empty) with mostly highway miles. Average of 16 mpg.
I changed my oil to 10-30 after about 300 miles. After the flash, I was able to register 250 miles on a tank averaging almost 20 mpg.
Old May 1, 2008 | 02:49 PM
  #392
SilverEvoX's Avatar
Here is the sticker, scanner FTW!
File Type: pdf
Old May 1, 2008 | 02:52 PM
  #393
meffiez28's Avatar
Registered User
-Pull car into bay
-Open driver door
-Get out of car
-Power Mutt tool on
-Connect cable from Mutt tool to OBD diagnostic part located on driver side
-click Here (download button)
-Wait
-go outside to customer and bust his ***** about warranty because he has Tinted windows
-Disconnect cable
-Test drive his car with your dirty hands
-rudely give the customer his keys with the implication that he is not welcome to come back to your service dept.
-Go home and hate life as a mitsu Tech
This is what makes a Subaru, a Subaru! Ha.
Welp I got a case opened with MMA, so hopefully that will solve my woes. I'm still opposed to them running the fuel trim tomorrow, as a few different service managers said theres no point, but I'm still going to take the car in tomorrow. The damn staples are falling out of my seats too, sigh, so I got more to complain about.
I'll keep you updated as to what happens
Old May 1, 2008 | 02:57 PM
  #394
Moostafa29's Avatar
I am experiencing this as well. Still have the rpm fluctuation at idle from time to time. It hasn't stalled yet thank God.
Old May 1, 2008 | 03:01 PM
  #395
logonzojls's Avatar
Thanks for the help silver evo!
Old May 1, 2008 | 03:02 PM
  #396
no0odlez623's Avatar
my rpm jumps around a little...but not to where it feels like its going to stall...and my top end feels better so im happy with it.
Old May 1, 2008 | 03:06 PM
  #397
logonzojls's Avatar
I will def. be going back to the dealer. Apparently the dealer is supposed to lay a sticker somewhere on your car with the tsb on it. Can t find one on mine anywhere so I think I got shafted to drive an hour of my time to the dealer just so they could see if my car really did need to be flashed if I would call back and complained about the same stuff. Either that is whats up or the reflash has fell way short of fixing the issues.
Old May 1, 2008 | 05:28 PM
  #398
SpeedI2acerX's Avatar
i heard there's a way to check by your vin to see if you really need a reflash. last vin below 40000 i think.
Old May 1, 2008 | 06:06 PM
  #399
dustin03's Avatar
I got my car flashed and the idle still jumps around but the car has not died since
Old May 1, 2008 | 06:11 PM
  #400
love9sick's Avatar
Stalled once after the flash and never before. The rpm jumps a bit but not as much as before flash. The car feels much better up top though so I don't think they lied about the flash.
Old May 1, 2008 | 06:56 PM
  #401
evostang's Avatar
I only had a pre flash stalling problem a couple times, both times were when I stalled it by accident, and then restarted it, and then it stalled a couple times on it's own after that. Other than those times, no problems at all.
Also, my car post flash is a whole lot faster from about 5000 RPM through 7000 RPM. It used to be tha tth car would sputter along from 5000 to 7000, and I could easily anticipate when 7000 was coming around. Now the tach just sweeps past 7000 pretty quickly. It is a huge difference. My manufacture date is some time in Feb 2008, are your cars earlier? You guys may be having some other problems?
Old May 1, 2008 | 08:04 PM
  #402
StevenStarke's Avatar
my car never stalled, but the MPG is def better and the car feels a lil bit faster
Old May 2, 2008 | 05:35 AM
  #403
CC16's Avatar
I think a lot of the power gains are placebo effect. I got mine "reflashed" and my idle sucks worse now and the car feels no different, almost worse.
Old May 2, 2008 | 05:52 AM
  #404
scottatyamaha's Avatar
Yea my idle is still a little jumper but has not stalled after the flash, however I am having hard starting issues. The other day it took 4 times to get the car to start!
Old May 2, 2008 | 02:34 PM
  #405
meffiez28's Avatar
Registered User
Welp, I took the car in for the Fuel trim appointment and got turned away. They said since there is a case opened, they could not touch the car, not even open an RO until they heard from MMA. So I left.
I get a call from a tech, or whatever they call them and she said they were told they CANNOT perform the reflash without a CEL period..... She said to reschedule the fuel trim and go from there....
WTF?!? This is so pissing me off beyond belief, I don't know what to do. sigh
