COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Dec 18, 2008 | 05:56 PM
  #151
John83's Avatar
Originally Posted by Rob@cobbtuning
Until I can test with the HKS filter I have to lean on the safe side and say no, we do not currently suggest you run the HKS drop-in filter with the AP.
As soon as I have tested the filter, I will post the data collected.
Thanks,
Rob
how about the works drop in? that in the same boat? thanks
Old Dec 18, 2008 | 06:33 PM
  #152
smoothevo's Avatar
Originally Posted by Papi4baby
Hey you got one too huh, yeah i am the same way. Maybe i'll reset the ECU see what that does, it mean it did increase the HP, but i don't know about 300 WHP, my stage 2 SRT4 felt stronger than this.
I don't know about 300 WHP that's hard to say without a dyno. What I can say is that there was a big difference between resetting the ECU and not resetting it.
Make sure you disconnect from the trunk battery and pump the brakes. Wait a couple minutes and reconnect the battery. Then start the car let it idle for about 7-10 minutes making sure you don't press the gas. Turn the car off and start it again if you want to take it out for a drive.
If you don't turn the car off after the reset above your RPM idle will bounce around like crazy. I tried this a few times and you have to turn the car off and restart it so you don't get the bouncy idle.
Old Dec 18, 2008 | 07:24 PM
  #153
sne2040's Avatar
you can just go into the accessport setting and reset the ECU back into learning mode as well. 150x easier and quicker
Old Dec 19, 2008 | 05:29 AM
  #154
dcasandman's Avatar
Originally Posted by shyong
Rob,
Just a quick question. I live in Plano, TX where you opened up your new shop. Are the fellows over here capable of tuning my X w/ the Accessport? Might be a stupid question but I figured I would ask since I haven't visited the new shop yet. If so, I will definitely pick up the Accessport.
Tim just tuned my X at Plano. Jeff @ Perrin highly reccomended him to me as well. The shop and employees where very nice. I say get it done there I got great results. They will be posted some time tonight or this weekend.
Old Dec 19, 2008 | 08:42 AM
  #155
shyong's Avatar
good to hear guys. Now I'm debating on purchasing a cat-back and downpipe. lol. All I wanted was a stock tune with only a drop in air filter. It's good to know there's some folks around here who are capable of tuning these cars.
Old Dec 19, 2008 | 10:53 AM
  #156
lowkey's Avatar
Registered User
Rob, still planning on releasing the Stage 2 maps this week (today)?
Old Dec 19, 2008 | 11:11 AM
  #157
Rob@cobbtuning's Avatar
For Stg II we currently have a setup being beta'ed be several people. Cobb will be on holiday from Dec 24th through the first of the year. We will be releasing Stg II maps and boost line configurations the first part of January when we get back.
Once released, customers will be able to source reconfigured boost lines from us as well as make your own for Stg II. We will be releasing the boost line specs as well.
Thanks,
Rob
Old Dec 20, 2008 | 02:59 PM
  #158
dosperado's Avatar
Originally Posted by smoothevo
I only have about 900 miles so I haven't taken it above 5k yet
Huh? Manual states the 5k limit break in period is first 600 miles... Are you you being extra conservative or maybe reading the Canadian part of the manual
Old Dec 20, 2008 | 03:19 PM
  #159
dosperado's Avatar
Didn't see it anywhere, but I know the stock Evo X map has a pair of mappings which are automatically selected in case detonation is detected. In other words, if you are stuck and can't get 93, or are sold bad gas, or whatever, the ECU switches to the low octane, low performance map, as a safety precaution, then later (?) switchs back to the standard 93 octane mapping if it's deemed safe by the ECU.
Is this safety feature gone once the AP map gets loaded, or do they do something similar?
thanks!
Old Dec 22, 2008 | 09:04 AM
  #160
thanks!
All of the ECUs safety features are still active with the AP.
Thanks,
Rob
Old Dec 22, 2008 | 09:33 AM
  #161
RazorLab's Avatar
thanks!
They don't switch, they interpolate, depending on knock counts, etc
Old Dec 28, 2008 | 10:52 PM
  #162
nhoj's Avatar
Originally Posted by Trey@COBB
Our HQs is not open this Friday. Most shops will begin receiving the software and APs at the beginning of next week.
If you contact our wholesales department, they'll start the process for you and discuss pricing.
Otherwise, the RACE software is FREE and we're in the process of adding links to our website so it may be downloaded by anyone who wants it. You need an AccessPORT to use it, but there are no additional costs associated with it. It gives you the same level access as the Pro software. The key difference being anyone with the RACE software can open/modify the maps created in RACE. The PRO software locks the maps to the tuner, so Tuner X can't see maps from Tuner Y and visa versa.
Cheers,
Trey
Regarding the above Underlined quotes:
So say I have "Company/Person A" PROtune my car (obviously using ProTuner software)..
Later on, I purchase some more parts, thus need/want to do some minor adjustments to my tune, but I don't want to use "Company/Person A" again.
Are you saying that it would not be possible for me to modify the tune myself/have "Company/Person B" do the minor adjustments since the maps were "locked" by the PRO Software?
Old Dec 29, 2008 | 10:22 AM
  #163
Yes, one tuner will not be able to see/open the others tune. This is/was requested by the tuners themselves to protect what work they have done learn tuning on a particular vehicle/setup.
Thanks
Old Dec 29, 2008 | 11:23 AM
  #164
chase123's Avatar
I think the Tuner also has the option to save your map into Race format using the ProTuner software. So it's up to them if you are locked out or not.
I have an Accessport and was planning on getting a tune at Cobb in Plano. I hope that they will do an unlocked tune, otherwise I will be selling my Accessport.
Old Dec 29, 2008 | 11:29 AM
  #165
I curious why an unlocked tune would be important to you?
Talk with the tuner there, I'm betting it would not be a problem to save your map as a race map.
