COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Jan 5, 2009 | 07:59 PM
  #196
Black-X's Avatar
Originally Posted by Rob@cobbtuning
The AP most definitely will smooth out the driving experience while adding a good dose of power. One point we really work on is the transition points and making them very smooth.
Thanks,
Thanks for the heads up. I'm trying to talk myself into pulling the trigger on one from Perrin before the sale is up tonight!
-X
Old Jan 5, 2009 | 08:36 PM
  #197
Yousef's Avatar
Question Cobb AP & Aftermarket Intake + IC pipes?
Hello,
I have a 2009 SST Evo X (GCC Spec - LHD JDM).
The car has the following mods:
-HKS Legamax
-HKS center pipe
-HKS SSQV
the following mods will be installed next month
-HKS racing suction kit
-HKS IC pipes
I have to go with HKS suction kit since HKS SSQV wont fit any other intake as I've been told!
I've got a COBB AP, not yet installed as it refused to (device does not support GCC). We've downloaded the stock maps and sent to cobb for support.
In their website they mentioned that the stage 1 maps will not work well with any intake other than stock, anyone here installed an AP with an aftermarket intake? any performance issues?
If COBB modified the maps to fit my GCC spec maps, how am I going to get new maps since the maps in their website will not work on my evo? custom maps?
Old Jan 5, 2009 | 08:43 PM
  #198
funks's Avatar
Is the access port for the EVO X the same as the one for the 08 STI? In other words, if I sell the EVO X access port (after removing it's maps from my car) will it reflash an STI?
Is the hardware universal?
Old Jan 5, 2009 | 08:48 PM
  #199
CBRD's Avatar
no.
cb
Old Jan 5, 2009 | 08:58 PM
  #200
LVSBB6's Avatar
Im running the stage 1 map with Gruppe M intake & ARC intercooler, AFR is still pig rich and in safe parameters.
Old Jan 5, 2009 | 09:19 PM
  #201
Japistani's Avatar
Originally Posted by Q15H
M<y results agree with yours [on the knock count numbers and frequency].
Did you mean to say that your results are the same as mine? If so, what are you running? Stock? Intake or some kind? More?
Old Jan 6, 2009 | 02:18 PM
  #202
Q15H's Avatar
I've run both the 91-ACN stage 1 map and the 93 octane stage 1 map with the AP on my all stock MR.
Additionally I've run the 91-ACN map with the AEM intake. It works just fine with that intake - never gets leaner than 11.5 in my dyno testing.
All of the above maps and combinations will show intermittent 0.35/.70 knock values - generally in the start of boost range while hte booist is climbing and peaking - in the 2500-3500 RPM range. Sounds like exactly what you're seeing.
HTH!
Old Jan 6, 2009 | 02:29 PM
  #203
Japistani's Avatar
HTH!
Great... thank you very much... I can't believe that it's been so difficult to find someone to do a simple mail tune for me... but, now, it looks like I'm ok until I get my exhaust... thanks again!
Old Jan 6, 2009 | 02:42 PM
  #204
CaliMR's Avatar
Originally Posted by hurstnova350
im sure thats well before V2 came out, the older ones have had some issues as with any piece of tech, but the new one is damn nice, can't wait for HBspeed to hook me up
Did they make a V1 for the Evo? Mine was a V2. Have they changed it so you can datalog even if it is on a locked custom map?
Old Jan 6, 2009 | 04:51 PM
  #205
dan@cobb's Avatar
Nope, the v1 AP's were only sold for the Subaru market for a while.
You can datalog with the AP unit itself but if you have a locked custom tuned map then you can't with the ATR software.
Old Jan 6, 2009 | 07:19 PM
  #206
Jblade's Avatar
^when's the ATR software for the X coming out?
Old Jan 6, 2009 | 07:31 PM
  #207
Yousef's Avatar
^ good to hear that...
what about HKS? anyone?
Old Jan 6, 2009 | 07:59 PM
  #208
jorgecuatro's Avatar
We just installed Cobb pipes on an X last week. Very satisfied customer
Old Jan 6, 2009 | 09:46 PM
  #209
0288's Avatar
i've pretty much got the same set up as u, and i'm still waiting for Cobb to come up with stage2 with intake, ic piping and catback. hopefully soon.
Old Jan 7, 2009 | 01:33 AM
  #210
Yousef's Avatar
Originally Posted by 0288
i've pretty much got the same set up as u, and i'm still waiting for cobb to come up with stage2 with intake, ic piping and catback. Hopefully soon.
jdm?
