COBB AccessTUNER Pro for 2008 EVO X (merge)
I have an accessport on the way. Question though.. Do I need a boost gauge? I bought the AP only to help drivability and stop the fuel from being dumped into the motor. I'm totally stock and I'll be running the 93octane stage 1 map. Do I need to worry about overboost or anything like that requiring a boost gauge? Or am I fine without a boost gauge and there are no worries with the AP on my setup?
Thanks,
-X
Thanks,
-X
As Rob mentioned previously that it's not necessary for a boost gauge when running the stg1-2 OTS maps; but people do tend to buy them to know exactly what's going on. Also the AP monitors boost if you'd like.
Sorry, I must have missed that. I might have also missed this as well, but does the AP moniter boost correctly now? I thought I read that it only goes to 18 or 22psi (something like that).
-X
Change map in 20-40 sec.We're working to have that all tested and out by the end of next week. At worst case, the following week.
Rob
We're finishing up the boost fix and adding other useful monitors for both AccessTuner Pro and Race along with the AP logging. Lots of other cool stuff is coming out at well. AP install will take ~3mins with saving the stock ROM
Rob
Rob
Unfortunately, not the way the current hardware is setup. We are working on creating a better naming scheme for the log files to help quell confusion.
Rob
Rob
After saving your stock map onto the AP, how long does it take to flash currently?
Thanks.
