RECALL- Manual trans Evo X's
Thanks
I just got mine done at El Cajon Mitsu in San Diego. I dropped the car off and they dropped me off in an electric car. When it was ready for pickup, then they picked me up in the same electric car. I just wish they would have washed the car. I got an oil change, cmc recall, and the headlight alignment recall completed. I will definitely consider using them again for the free drop off and pickup service. I live 10-12 miles from the dealership. They stated they are doing 2-3 Evo cmc recalls a day.
@Shekaar
Correct. A recall must be performed unless an unauthorized mod DIRECTLY prevents it. None of the "vaguely related" crap that they pull WRT warranty work can be used in this case. Thus, they cannot say No because of your aftermarket clutch, for example. They can only say No if you have some funky STB, for example, that gets in the way.
ps. my lack of a JD or license (or malpractice insurance) should be noted, as usual
BOBBY (TrogdorWBL) where you at! Man I just called Mitsu at the Bloomington location and they do not do it over the weekend. They said its suppose takes about 4 hour but in actuality about 7. Does your place do the same thing?
Just to be sure, I have an aftermarket clutch which caused my mater cylinder to bust back in 2010. When they replaced the master cylinder I had them also install the AMS support ring to prevent it from busting again. Will they still perform the recall and will they also refund me for the previous work ($485)?
With regard to having already done the work and asking for repayment, as I explained earlier (see post 75 on page 5), it depends on when you did the work.
