RECALL- Manual trans Evo X's
You have mods that directly interfere with the recall. At best, they will still do the recall, removing all non-standard parts in the process.
With regard to having already done the work and asking for repayment, as I explained earlier (see post 75 on page 5), it depends on when you did the work.
"If you have already encountered a problem with the CMC and had it replaced as a result of this specific condition and have paid for the repair, you may send your original receipts and/or adequate proof of payment to the following address for reimbursement consideration: Mitsubishi Customer Relations Department, P.O. Box 6400, Cypress, CA 90630-0064"
In the recall letter it states:
Then again, since the CMC replacement does not require opening the transmission they may have not know you had an aftermarket clutch installed at all. I'd really like to know how that would shake out as there are probably many owners in this situation.
Hey guys,
I just had my CMC replaced yesterday. I have stock clutch and I noticed that after the install that the pedal is much softer. There is also a little bit more dead pedal when you push initially. Lastly, the catch point seems to be when the pedal is 75% pushed instead of around 50% like before the install.
I included a video showed how much dead pedal there is now
I know many people have experienced the same thing after the CMC install but I am wondering if it would be worth having the system re-bled?
Hey guys,
Evo X Clutch Pedal After CMC replacement - YouTube
Just to reiterate what most have said,
Picked up mine yesterday and the clutch felt feather-light leaving the parking lot.
half mile down the road and it went back to normal. I was surprised the service tech didn't take it for a test ride after the work was done. Just parked it out front and on to the next job.
I'm assuming that portion of the letter is under the pretense that owners are on the stock clutch. If you had an aftermarket part cause a CMC failure then one could assume that it was because of a result of said aftermarket modification - they may apprehensive to reimburse you due to this.
They took out your whole transmission to replace the CMC? I call bs. That's a 4+ hr job
No, they did not take out my transmission. They opened up something while the car was on the lift. You could barely see the clutch (yellow) and said that's aftermarket. It was back in 2010 after I had the car for a couple months (bought used from a dealership). Didn't know aftermarket clutch was installed.
In any event, this is a recall, not a warranty repair. If the things that you have done to the car do not DIRECTLY interfere with the recall work, they must do it.
