Sponsored by:
Sponsored by: CARiD
RECALL- Manual trans Evo X's
Old Nov 26, 2013 | 08:35 PM
  #256
SpeedI2acerX's Avatar
Here's a silly guesting.. Can somebody show me where I can find the CMC? Or have picture of it. I want to make sure mitsubishi replace this sob! I don't want to get Oky doke aka jiffy lube.
Old Nov 27, 2013 | 05:47 AM
  #257
an2ny's Avatar
I better get my money back
So what happens when this new CMC fails?
Old Nov 27, 2013 | 06:21 AM
  #258
yorT's Avatar
Originally Posted by Iowa999
Wow, it only took you three tries before that got through my thick skull.
And that's an excellent question, but the way. We know that the CMC from an 8/9 can handle an upgraded clutch, but, as of now, we don't know if the redesigned CMC for an X can take it. Given the low engagement issue with the new version, this might make having the recall done rather unattractive to many.
Well, I have an am clutch and the EVO is with the dealership now getting the recall done. We'll see what happens, hopefully I'm not at a stop light and have the CMC bust on me when the light turns green.
FYI, they called me asking for the lug lock. Mine actually broke so don't know what or why they'd need to take the wheels off. Maybe to bleed the brake lines??
Old Nov 27, 2013 | 06:52 AM
  #259
khmerguyx's Avatar
Just dropped my car off
Old Nov 27, 2013 | 07:28 AM
  #260
Iowa999's Avatar
Correct. Because the brakes and clutch share a reservoir, the brakes must be bled.
Old Nov 27, 2013 | 09:22 AM
  #261
Ramphex's Avatar
Does anyone know if this affects 2014 models as well? Not listed in the recall but is it same part number as 2013 model?
Old Nov 27, 2013 | 09:33 AM
  #262
dragR5's Avatar
I just had cmc replaced and it took mt shift grinds away. Feels like butter now.
Old Nov 27, 2013 | 11:03 AM
  #263
Uscbryan's Avatar
I think somebody posted that it does not affect the 2014. It comes with the upgraded part. If I'm incorrect I'm sure somebody will correct me.
I'm going in tomorrow. Hopefully I don't have to sit there all day. Going to see if I can test drive a 8 or 9 since I never drove one. Help pass the time a little.
Old Nov 27, 2013 | 03:29 PM
  #264
Hotevo3's Avatar
update: clutch is back to its normal feel, my guess is they didnt bleed mine 100% :|
Old Nov 27, 2013 | 06:00 PM
  #265
Adli's Avatar
Originally Posted by shekaar
Now recall stuff should be honored regardless of mods we have done, correct? I dont need to worry about going back to stock just to get this done on mine?
I have a Shep Trans rebuild, with after market clutch and pressure plate... the mechanic was concerned "it hard to shift"
Did it for me. no issues, except the annoying little squeak on full clutch, and they disconnected my gauges..
Old Nov 28, 2013 | 10:15 AM
  #266
RoninR33's Avatar
had mine done yesterday at Bell Mitsu. I was the first car in the morning. took them 2 hours. the clutch was soft with a lower engagement when I drove it off the dealer lot, but gradually went back to near what it was after driving in traffic.
also saw 3 other Xs in the service parking lot when I left. almost had all the colors represented. white, red, black, and gray
Old Nov 28, 2013 | 11:26 AM
  #267
Alien Visitor's Avatar
I had the CMC recall along with some headlamp recall done at Prestige Mitsubishi. Both took the better part of 5 hours, but the clutch and brake pedals feel solid.
What annoyed me was on the work order, it stated the following:
-Exhaust system has been modified
-Car has been lowered
-Intake system has been modified
Old Nov 28, 2013 | 01:28 PM
  #268
sessllh's Avatar
I had the CMC recall yesterday. I know many ppl already mentioned that the clutch feels a lot softer and engagement point is significantly lowered. My car felt the same yesterday.
Today I drove my car and engagement is still almost right off the floor. I don't mind having a lower engagement point but will this get back to normal as I put more miles on it? I read few ppl said their clutch went back to normal after driving a few miles. But considering that I drove almost 50miles after the new CMC install and it's still the same, should I take my car back to the dealership? Why does this happen? does this mean that the work wasn't performed properly?
Old Nov 28, 2013 | 02:19 PM
  #269
Iowa999's Avatar
I can only assume that your ECU hasn't been flashed or that would have been mentioned, too.
Old Nov 28, 2013 | 02:25 PM
  #270
BehindSpace999's Avatar
Decided not to get the recall done, I'll take my chances on the old version and buy the new cmc and a power bleeder and change it myself if I ever need to.
Swore off having any dealer or shop wrench on my cars a long time ago after watching things always being done wrong or damaged time and time again. Hearing so many people say the engagement point is low and changing randomly after putting on some miles just reinforces my decision.
