Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Evo X Boost Gauge Install ,No splicing, No firewall drilling,Pics+Vid= Clean As Hell
Old Feb 24, 2009 | 08:25 AM
  #76
Brewster's Avatar
for the life of me i couldn't get the hose down through that little opening, and i was scared to drill in to the car for my guage, so right now my guage is just electrical taped to my steering wheel. I don't want to screw into anything, im thinking some sort of adheasive caulking. any ideas?
Old Mar 7, 2009 | 04:02 PM
  #77
ZWingerRyRy's Avatar
I didnt drill into the steering wheel i just used adhesive double side tape, Its still holding to this day it wont even budge, stayed in garage through winter also, didnt release.
Old Mar 7, 2009 | 04:10 PM
  #78
skylinegtr35's Avatar
there are orange, red, white, and a black ground. Where do I connect the ground?
Old Mar 7, 2009 | 05:05 PM
  #79
Bear.914's Avatar
0k used this to smooth out the install and everything you said is correct +5
Old Mar 7, 2009 | 05:36 PM
  #80
There should be a bolt inside the console fuse box to use for grounding.
Old Mar 7, 2009 | 05:42 PM
  #81
Is it that bolt right under the fuse box?
Old Mar 7, 2009 | 07:59 PM
  #82
Bear.914's Avatar
yup, its like a 14 I belive.
Real simple install and just need to find a good mounting spot...Might just fab. a a-pillar guage since the airbag is on the top of the a pillar
Old Mar 9, 2009 | 04:52 AM
  #83
aftershock141's Avatar
Install definitely helped. I did mine this weekend with no troubles at all.
I wish they would've provided a longer vacuum line though so I could've mounted the sensor where I wanted to. I'll be picking one up sometime this week so I can do it properly.
Old Mar 15, 2009 | 06:55 PM
  #84
gibsonsg's Avatar
I just installed Prosport electrical boost gauge. Have everything installed and working. i just can't figure out have to wire it so that it turns orange when the lights are on. I have the red on door locks, white on the cig. lighter. and black grounded. Where have people been putting the orange wire? I have heard that you need to splice into the harness coming out of the steering column but i have no idea how to do this. Please HELP!!
Old Mar 16, 2009 | 04:45 AM
  #85
reggiesd's Avatar
this isn't probably that helpful..but you probably wire it to something that turns on when you turn your lights on (eg. lights for a/c knobs, dash lights, etc.). you just find the wire for those and wire the orange wire there.
Old Mar 16, 2009 | 06:13 AM
  #86
kingu's Avatar
someone mentioned splicing it into the "ASC" button...it only lights up when the headlights are on. of course this is a good solution only if yours is located to the left of the steering wheel...i believe some are located in the center console.
Old Mar 16, 2009 | 10:31 AM
  #87
gibsonsg's Avatar
This is probably a very stupid question but how would you splice into the ASC. I mounted my gauge on the left of the column and the ASC is on the left so this would be the best place.
Old Mar 16, 2009 | 11:48 AM
  #88
kingu's Avatar
i'm not sure which wire it is, i've never even looked behind the asc button. i have mine running red all of the time. the white has a blue tint to it and doesn't match the dash gauges at all (IMO).
if i get a chance i'll look tonight and see if i can figure it out.
Old Mar 16, 2009 | 12:52 PM
  #89
gibsonsg's Avatar
How do you have yours wired to be red all the time. I tried wiring mine to be always red but then the gauge wouldn't turn off even when the car was off and the key was removed. I had red to door locks, orange to cig lighter, black to ground, and white unused.
Old Mar 20, 2009 | 01:50 AM
  #90
evosoh's Avatar
Great job
