Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Evo X Boost Gauge Install ,No splicing, No firewall drilling,Pics+Vid= Clean As Hell
Old Apr 3, 2009 | 07:19 PM
  #91
shaggadelic's Avatar
just did this on my friends evo x mr and it was super easy
Old Apr 3, 2009 | 07:21 PM
  #92
ZWingerRyRy's Avatar
Great glad i can help =) If anybody needs anyother write ups ive done just about every bolt on lol. Lemme know ill take the time to go step by step.
Old Apr 5, 2009 | 07:19 PM
  #93
REDEVO08's Avatar
Old Apr 18, 2009 | 04:11 PM
  #94
Clark_Kent's Avatar
Thanks for this write up. I just finished it up with a buddy of mine. It only took about 2 hours with a run to AutoZone.
Old May 2, 2009 | 12:54 AM
  #95
EndlessRed's Avatar
tip for those that want the dimmer function on the gauge to work with the car (for the defi gauges) or color change (for prosport):
tap the wire that's responsible for the dimming (white for defi, not sure for prosport as i have a defi gauge) into the GREEN-WHITE (green w/ white stripe) wire on the ASC button. for those that has the SSS package, the GREEN-WHITE wire is on the leveling switch as well. either one works. i believe there's a GREEN-BLACK wire on the buttons as well, but that's most likely a ground, and thus won't work. make sure you got the right wire.
those that has the ASC button on the center console, you might have to dig for the harness, but it should be there, and should still work even if it's not plugged into a button.
Old May 11, 2009 | 12:22 PM
  #96
alex3dworld's Avatar
Humm....this is so wierd.
i'm installing the perring gauge package
it cames with prosport performance premium series.
i'm doing first the Boost gauge
everything looks good but it never shutdown. is always on
what do you think guys is going on?
Old May 11, 2009 | 12:25 PM
  #97
Dakoop's Avatar
Pick a different power source. One that switches off with the key.
Old May 11, 2009 | 12:34 PM
  #98
so...what is the point to use the continue 12 volt source?
i know it is causing that the gauge is still on. but why thr instructions ask for it?
Old May 11, 2009 | 01:21 PM
  #99
sne2040's Avatar
well this still is gonna be slightly suckier with the rallyarmor mudflaps on.....
Old May 11, 2009 | 01:26 PM
  #100
Red Dragon's Avatar
Edit never mind
Old May 11, 2009 | 01:45 PM
  #101
jls0711's Avatar
ya kinda crazy huh... only thing i can think is to avoid running excess wire
Old May 11, 2009 | 03:20 PM
  #102
EndlessRed's Avatar
because yours is not a defi gauge. defi turns off on its own when it detects ign is off. for gauges that do not have a wire to detect ign, you might want to put your + wire into the cig wire.
Old May 23, 2009 | 12:05 PM
  #103
350ZEvolved's Avatar
Excellent thread! Inspired me to do it myself. Not that bad of a job took about 1.5hrs with someone else helping.
Old May 24, 2009 | 07:19 PM
  #104
swingarm's Avatar
Well I used this guide to install it and it worked pretty well, a big thank you to the author.
Couple of things, I accidentally chose the red back lit meter instead of the white but we'll see how it works out since I have a Rally Red car and it matches the center display it may grow on me.
Old May 25, 2009 | 08:45 AM
  #105
Thanks, Im glad this thread was of use. It might seem pointless, but i prefer not to drill into a $30k+ car or have wires all over the place.
