Yet another thread about Turboing a 03 lancer.
Ok question for yall. Just got a call from my exhaust guy and when he mounted my rear 02 sensor bung he didnt realize I had the spacers on it so it wouldnt fit. Does it matter if the wideband is behind the rear 02 sensor? They are gonna be really close together anyways as I am having both wiring harnesses go through the same hole to the cab. I told him he could probably put the wideband in that one then mount the rear 02 just ahead in front. I dont see and issue with this but thought I would run it by you guys
02 cheater
FMIC Lurking. The charge pipes stick out the bottom but oh well
front end lines back up pretty good
pic of the engine bay, it looks a little different now than in this pic ill get pics of that too
battery in trunk
blue underdrive pulley
massive 3" Downpipe
FMIC and slim fan
Evo 9 BOV
Yup this is just the basic install it looks a little cleaner now after these pics were taken. Runs awesome I must say but still waiting on a phone call that my car is done at the exhaust shop, then I can start the real tuning.
Ok so dude at the exhaust shop called me right before I had to go to work so I got a ride to pick it up and had to go straight to work. He said he couldnt fit the clip of the wideband through the hole going to the cab so after work I got the rear 02 and wideband hooked up. Although it was pretty late when I got it done so I started her up and just let her idle for probably 2 mins. Its telling me cold idle is measuring about 16.1 16.2 afr so still a little lean looks like but I guess I will have to drive it tomorrow before work and see the afrs on the road. Isnt the afr supposed to be at 14.7 though? If so wouldnt this mean my trims should be wayyyyy positive?
I think I am almost there, my idle trim is at about +4 and change and my cruise trim is around -1 to -3. Gonna bump my latency up one or two increments and see if that gets my trims closer together then maybe bump my scaling up one increment. Here is my injectors as of now, if anyone out there that has tuned there 440cc injectors see an issue please let me know.
One issue I am having is my wideband logging. I have everything hooked up right and setup up correctly but for some reason evoscan will log my afrs fine for maybe a minute or 30 secs or maybe 5 minutes and then it freezes. everything else continues to log like normal and my AEM Uego gauge clearly displays the changing afrs but the number in evoscan stays the same???? Anyone else experience this before?
So got my trims pretty close,
low: 5.85
Mid: 4.10
dropped my scaling from 344 to 336 gonna see if I can get a little closer to zero.
So from my research sounds like evoscan 2.6 has uego logging issues but cant find where to drop back to 2.5 anyone know?
low: 5.85
Mid: 4.10
