One more 16g thread - few questions
Old Nov 20, 2010 | 01:36 PM
  #301
steven121's Avatar
well i ran a corvette stock and kept up with it till about 2nd gear...
then I was dead on with a stock 03 camaro ahh life is good turboed
Old Nov 20, 2010 | 02:06 PM
  #302
03lances's Avatar
Nice man. I plan on running against my buddys rb25det powered 240sx now that I am becoming very satisfied with my tune. I have not had a chance to ride in it but am told its quick!!!!.
Old Nov 20, 2010 | 02:11 PM
  #303
Mitsu.kid.02's Avatar
you guys are so lucky... ill get there soon...one day hahah
Old Nov 20, 2010 | 09:15 PM
  #304
02-Lancer-Es's Avatar
Is it this bad?
lol
http://s269.photobucket.com/albums/j...6-11-26-17.mp4
Old Nov 20, 2010 | 09:20 PM
  #305
Originally Posted by 02-Lancer-Es
LOL was that like crazy timing retarded or something?
Old Nov 20, 2010 | 09:22 PM
  #306
Nope lol just 100% torque Hahaha
As far as the tune not sure man had a great tuner do it !
Old Nov 20, 2010 | 09:23 PM
  #307
Car will just light them up doing anything under 60 Haha Even if i floor it going 50 it does .
Old Nov 20, 2010 | 09:40 PM
  #308
03lances's Avatar
Mine is the same way although not as bad now with the new springs. I was actually getting quite annoyed with it to be honest. All that power just wasted burning up my tires lol. Better now though I can actually get on it in second when dry and it feels goooooooood
Old Nov 20, 2010 | 09:44 PM
  #309
I cant and have good tires , alignment , full coilovers , energy bushings and progress rear sway bar Haha Its Awesome after 60 thought !
Old Nov 21, 2010 | 01:49 PM
  #310
HornstarBU's Avatar
Here's the lastest as far as AFR's, knock, Timing and estimated HP/Torq. I think the latest HP estimate is either off, or more probable is that the previous one was inaccurate. I also need to log less items to get more accurate sample rates I think, and that might make it more "legit" as far as estimated HP goes.
Tell me what you think if I should lean the AFRs or move on to Timing advancing. There is 1 or 2 counts of knock, and on the knock map that's showing maximums. I also did some looking, and it feels like from some testing, I go into boost right at 95-100% load.
Also, my IDC went up as high as 104%, so I guess my previous thoughts on the IDC being maxed at 100 isn't entirely correct. Still, for safeties sake, I should leave more of a buffer to prevent running outta fuel.
Attached Thumbnails One more 16g thread - few questions-afr-tr.png   One more 16g thread - few questions-knock-tr.png   One more 16g thread - few questions-timing-tr.png   One more 16g thread - few questions-hp-tr.png
Old Nov 22, 2010 | 08:42 AM
  #311
HornstarBU's Avatar
And just for fun, here's the same data put into Virtual Dyno. I'm thinking HP just steadily rises throughout the entire pull...so that means my timing might be too conservative down low in the RPM range, so I'll start increasing there, and see if it adds power of if I get knock. I don't really see a "sweet spot" like most dyno graphs do, so that says something about either the tune (more likely) or the camshaft (which although is slightly less aggressive than it could be, ought to make fine power).
Maybe I need to pusha da peda a litta soona, 2k rpm range....
Old Nov 22, 2010 | 12:12 PM
  #312
jwick76's Avatar
so quick question, how well does evoscan work for the stock lancer? Better option than ecuflash, or just different options...?
Old Nov 22, 2010 | 12:19 PM
  #313
HornstarBU's Avatar
Diff programs. Ecuflash works great for the lancer, evoscan works great for the lancer...but they do different things. Ecuflash will flash and pull roms, edit them, and help you do everything "rom related". EvoScan will also edit data, no where near as advanced...basically just timing and fuel maps (still the same format as ecuflash uses, it even shares teh xml files), but it's more intended to log data. EvoScan will log your load/RPM/throttle/anything you want, and a time with it so you can review those logs to tell what you need to adjust. If it's just timing and fuel adjustments, you can edit them in evoscan. If it's more than that, you can edit it all in ecuflash. EvoScan claims to be able to flash new roms to the ecu as well, but I've not ever tried that, and don't have a reason to.
Old Nov 23, 2010 | 02:53 PM
  #314
HornstarBU's Avatar
You see my pic of where the intercooler and intake pipes are?
http://s875.photobucket.com/albums/a...t=DSCN2743.jpg
Umm...I just saw Zulu's video, and he's got the 2 reversed I think, intake is in front, and intercooler piping goes underneath it. He has the bov tube on the UICP facing upward instead of down like mine. Who else did it my way, who did it his way? I didn't really like the way mine was, but couldn't get it to fit the other way. My intercooler pipe rubs the hood a bit.
Old Nov 24, 2010 | 05:24 AM
  #315
This is how mine looks currently:
My BOV is VTA tho, so if your recirc the pipe would just be flipped around
