One more 16g thread - few questions
Old Dec 11, 2010 | 10:22 PM
  #361
03lances's Avatar
Originally Posted by Demon_ni2
Hrmmm.. mine idles n runs just fine with the 399.. But i am also forced closed loop due to sensors not liking my setup..
But knock knock(on my head) i dont tune.. i let my local master touringbubble do all his voodoo work on my car with his mystical powers..
only thing that ive noticed on mine is that it seems like after the cars warm, (id say Well past the warm threshold for a few mins) it tries to dial the idle down from 1100-900. I donno why. i normally only notice it like, after i get off the highway, or some other form of abuse where its abviously well beyond jus tbeing warm.
Demon I assume you meant forced open loop on this correct? This is how I am too just because its making fuel tuning soo much easier and predictable.
Old Dec 12, 2010 | 10:08 AM
  #362
Demon_ni2's Avatar
yes i ment open. i always think of it backwards. it just stays on my one map and doesnt adjust.
For some reason, (we assumed it was a sensor going bad) when my car went into closed loop(for like idling) it was slowly raise the revs up to about 4k and hold it, then die down to 1k... then slowly build back up to 4krpm (over about a minute period it would go up)
could be for a few reasons, bad vacuum leak, boost leak, bad sensor.. i havent found any leaks, but im sure i do have a vac leak on my intake manifold becuase the flange on it is warped pretty bad, but i need to replace the gasket...
were gunna start tearing it all back down this week, if it wasnt so cold id be outside right now working on it.. But were gunna start workin on strippin it the rest of the way down, should be able to take another 100lbs out of it.
Old Dec 12, 2010 | 02:23 PM
  #363
Mitsu.kid.02's Avatar
I love running forced open loop, but latly my AFR have been 13.3 crusing, and the more and more i let off the gas pedal, the RICHER the AFR got, which do not make sense, as in ecuflash 20-70load 2000RPM-4000RPM are all 14.9 AFR and when open loop was working while crusing it would be 15.2 AFR on the actual WB, not sure what happened, but now i have to run closed/ open loop again, dont like it!
Old Dec 12, 2010 | 03:15 PM
  #364
steven121's Avatar
lean out your fuel a little more or jus increase the timing in that area since its open loop. Im setting mine as well tonight then I have to take off the exhaust. Im going to run open test pipe
Old Dec 12, 2010 | 04:02 PM
  #365
Demon_ni2's Avatar
wow.. ya lean it out a bit.. at cruising, im in around 15.5-16.7:1
Old Dec 12, 2010 | 04:07 PM
  #366
I would if i could... i cant seem to reflash my ecu now please read my thread in the lancer tuning section
Old Dec 12, 2010 | 05:02 PM
  #367
03lances's Avatar
Mine sits perfectly at around 15.0-15.2 cruising. Really big weather change perhaps?
Old Dec 12, 2010 | 05:19 PM
  #368
Demon_ni2's Avatar
Ummm.. weather change? its winter, so it would get a little leaner technically..
Old Dec 13, 2010 | 09:08 AM
  #369
03lances's Avatar
True but you never know especially with the hybrid rom mistu has what could be causing it. Have to take in all variables.
Old Dec 13, 2010 | 09:15 AM
  #370
Yeah i dont know what happened, Although i did find that my BOV was pretty loose, so im thinking that could have cause the richer AFR, because when the BOV popped off the ran peg rich 10.0 until it finally stalled out. If i can get my tactrix cable to revive, hopefully, i can change back to open loop
Old Dec 13, 2010 | 12:49 PM
  #371
steven121's Avatar
mine sits from 14.7-15.3 im going to check out your thread mitsu
Old Dec 13, 2010 | 12:52 PM
  #372
Thank you, any input is greatly appreciated!
Old Dec 13, 2010 | 01:53 PM
  #373
Demon_ni2's Avatar
lawl.. sell it and buy an evo :P
Old Dec 13, 2010 | 02:03 PM
  #374
Not funny demon
Old Dec 13, 2010 | 02:11 PM
  #375
HornstarBU's Avatar
Not funny demon
But I laughed....
