One more 16g thread - few questions
The tune is much more aggressive, seeing knock at partial throttle, but not WOT. I'm going to adjust a little more, but overall, I like feeling a difference.
You know that "blinker/change lanes" people do, when they think they are going to come up on you before you get up to speed with the rest of traffic.....had someone change lanes as I pulled out, and I really got up on it, to 65 (the speed limit) waaaay faster than he thought I would get there....and just slid right back over a few hundred feet behind meh!
Also, the BOV sounds a lot better with my timing increased, which I'm assuming just means I was sloppy before. I still think I can tighten it up a bit more, but I also see why it's easier to tune on a dyno rather than open road.
I think before I'm racing anyone, I need to get a new clutch, and probably get the injectors in/raise boost.
You guys are both 12 psi + right? I'm sittin pretty at 7psi at WOT.
Still sitting at 12 psi and going strong. Really feel no need to up it without either LSD or AWD. If I pop the clutch I can break the tires loose doing 60mph consistently without any trouble.
lol
