***ECUFlash Now For Base Lancers!***
Old Jan 2, 2007 | 11:44 AM
  #346
wickdaddy's Avatar
then i guess my next question is, is if I power off the safc, do the values of the safc stay or does it go back to the way it was before the safc was implemented?
Old Jan 2, 2007 | 03:46 PM
  #347
senate6268's Avatar
The values on the SAFC should be kept even after you unhook it. You can leave your SAFC connected while you flash your ECU. What you should do is see what areas of the fuel curve you have modified. Then after you do some datalogging you can look to see how much load is at those points and then alter your ECU values accordingly. I've been phasing out my SAFC for the past few weeks with different flashes to my ECU. As soon as I figure out how to adapt my ROM values for my 501 MAF I will eliminate my SAFC completely.
Old Jan 2, 2007 | 04:23 PM
  #348
wickdaddy's Avatar
ok... well hooked up the ecuCable and followed Z's instructions, but after step 5, I clicked "ok" and the dialog box in step 6 did not show up... click here to see what I mean... anyone have an idea what's going wrong?
Old Jan 2, 2007 | 04:43 PM
  #349
senate6268's Avatar
The definition file you have does not have the correct address locations for your ROM values. Post a copy of your ROM up and someone should be able to get a working definition file to you.
Old Jan 2, 2007 | 05:01 PM
  #350
wickdaddy's Avatar
I believe this is the ROM data... can someone get this working? thanks in advance for the help!
Old Jan 2, 2007 | 07:10 PM
  #351
Z_Lancer_Man's Avatar
Yup, that will work! I'll get my friends working on it right away and we'll get you taken care of. Your patience is appreciated
Old Jan 2, 2007 | 07:46 PM
  #352
wickdaddy's Avatar
Thank you! I can't wait to get this thing going. I did some logging with your mitsulogger this evening and that worked like a charm!
Old Jan 6, 2007 | 12:53 PM
  #353
krnzzang84720's Avatar
hey guys i just installed DSM 1G 65mm TB and i am getting high idle.. do you think this cable can fix the problem by adjusting the idle on the ECU??
Old Jan 6, 2007 | 08:46 PM
  #354
Have you tried adjusting the idle screw on the TB as well?
Old Jan 6, 2007 | 11:08 PM
  #355
i saw post on SCLC.NET about members trying to fit 65mm DSM tb on Lancer and they also got high idle too... I belive boe and ryzine (i might be wrong) but when i read post on the mirage forum they fix it by connecting the close throttle wire to the sensors and idle was okey, but after i installed it our sensors and mirage sensors are different (lancer has three wire on TPS and mirges ahve four) so... everything is perfect on my car, just idle is resting at 2k. i have to find a device that could control idle or i might have to put stock tb back. man i really don't want to put stock back since power increase was very nice!!! so z lancer man, can you adjust idle with that software and cable?? when i saw it with the rom you gave me, there was a idle control option there!!?? or can RRM's piggy control idle?? or maybe some other Air Fuel controller or other piggyback??
Old Jan 7, 2007 | 06:19 AM
  #356
3gturbo's Avatar
Sounds like you need to adjust the idlestepper table.
Old Jan 7, 2007 | 05:34 PM
  #357
what do you mean idlestepper???
Old Jan 7, 2007 | 09:26 PM
  #358
Yeah, you should be able to adjust it on the ECUflash. No piggyback unit (RRM, APEXI, etc) is going to be able to control idle. Good luck!
Old Jan 8, 2007 | 10:10 AM
  #359
i bought the cable.... hope it works!!
Old Jan 11, 2007 | 12:55 PM
  #360
got the cable!!!
downloaded ROM, i played with some number but my idle is still high, i am not sure which ones i need switch,
