***ECUFlash Now For Base Lancers!***
Old Feb 10, 2007 | 05:11 PM
  #391
Silens's Avatar
ok, i got bored today so i put in the injectors i got, they are 420cc stock wrx injectors, they are a light blue color, i read on some threads that the ones that worked for us where 440cc and green, but these were a straight swap, no longer bolts or anything needed so great, but when it comes to trying to tune them no luck , no matter how much fuel i added or removed from the fuel tables it still runs lean, which is surprising because bigger injectors should be spitting out more fuel, Zlancer could you send me your tune so i could work off of that? i really want to try and get this set at a base tune this week, i have pistons & rods on the way!
Last edited by Silens; Feb 10, 2007 at 05:17 PM. Reason: clicked on submit instead of advanced edit :/
Old Feb 10, 2007 | 07:31 PM
  #392
Z_Lancer_Man's Avatar
Sure thing. The thing you have to adjust is the Injector Voltage Latency Values. Basically the values that tell the car how long it takes the injectors to open when the voltage is applied on them. This in turn affects how much fuel is being sprayed. You also have to adjust the Injector Scaling Factor. I'll send you a copy of my ROM and you can start with that. You should be able to idle well though it still runs rich under WOT. I haven't had a chance to fine tune it under load.
Old Feb 12, 2007 | 08:22 AM
  #393
andirkanod's Avatar
hey guys just wondering if i got my car turbo'd and used the RRM piggyback to tune the car or if i should go a different route and just get the ECU flashed instead of taking the time to learn the piggyback software.
Old Feb 12, 2007 | 08:46 AM
  #394
Silens's Avatar
ok something just came to me, the 04s have the returnless fuel system, i have no fpr, im problably not getting enought fuel pressure and starving the injectors???
Old Feb 12, 2007 | 09:31 AM
  #395
It depends on how much you'd like to tune. The piggyback is good for a small range. And it actually doesn't change anything other than make the car think its running leaner/richer than it really it by altering the MAF reading. Its a very expensive ($400+) method of running a tune that isn't really a tune in the first place. However, with ECUFlash (free) and the cable ($90 shipped) you have the freedom to change/tune everything on your car. However, like all powerful tools, there is greater risk of serious and even catastrophic damage that can be done to the engine if you don't know what you're doing. But if you read a lot, ask questions, and take your time, you, like many others including myself, can safely tune your Lancer. This thread is a great resource as well as the ECUFlash forums themselves: openecu.org
Do you have the Walbro 255 or another larger fuel pump? If not, you definitely need to get one.
Old Feb 12, 2007 | 01:21 PM
  #396
Silens's Avatar
yes i have a walbro 255, but im going to put the stock inj back on until i figure out more about the returnless fuel systems...
Old Feb 12, 2007 | 01:43 PM
  #397
Wallesasuaz's Avatar
You need something to regulate the fuel. Higher the pressure the more fuel to the injectors. The 255 pump supplies the suffiecient amount of fuel but U need something at the Engine side to regulate it to the injectors.
Old Feb 14, 2007 | 06:35 PM
  #398
Silens's Avatar
well i know that, but im trying to figure out an easy way of doing it without having to run fuel lines and other stuff, anybody know how the fuel pressure is kept steady on the lancers?
ive done some searching and most returnless systems ive read about are controlled by the ecu with the help of sensor feedback, which means we should be able to program it with ecuflash to raise the pressure, no? Maybe i should just keep it simple and just do a return conversion
Old Feb 14, 2007 | 09:16 PM
  #399
Yeah, I'm not too knowledgeable about this conversion. I know that there are many Ralliarts out there who do a EVO fuel system swap so they can also have a return.
Old Feb 15, 2007 | 06:34 AM
  #400
wickdaddy's Avatar
Originally Posted by wickdaddy
sweet just tried that and a bunch of the stuff I got readings for... don't quite know what they mean, but it is looking like it is starting to work! Let me know when you guys get the whole thing completed! Thanks so much!
any update on my rom?
Old Feb 17, 2007 | 12:03 PM
  #401
krnzzang84720's Avatar
anybody have good na tune??
Old Feb 18, 2007 | 08:59 AM
  #402
nem187's Avatar
Its definitely awesome that there an inexpensive and powerful tool to tune our Lancers now.
I was reading that some people were having problems getting ECUFlash to work right with their cars. I shouldn't have any problems if I get a shop thats experienced with ECUFlash to do my tuning right?
Old Feb 18, 2007 | 06:34 PM
  #403
Correct. Basically all tuning tools are very similar, so any experienced tuning shop will be able to tune efficiently and effectively using ECUFlash. I'm starting to think that come this spring, I'll just have a shop tune my car. That way I have a good solid base to tweak as I see fit.
Old Feb 19, 2007 | 12:28 AM
  #404
nem187's Avatar
Z Lancer,
Thanks man. It looks like this is prolly going to be the route I take. Now to go shopping for a new laptop, lol. Thanks for the info.
Old Feb 22, 2007 | 11:07 AM
  #405
hey z lancer i am about to turbo my car and have quick question!!
i already have this ecu cable i bought, do i still need 12:1 fmu??
i remember you telling me i still do need it, right?
and i need help how to tune, can somebody help me tunning with stock injector with gt28 turbo
